FEM unit test failure in Cmd mode
bernd
Re: FEM unit test failure in Cmd mode
Post by bernd »
same build but copy the code --> on error
output:
>>> # code to copy
active_doc=App.newDocument()
box = active_doc.addObject("Part::Box", "Box")
fixed_constraint = active_doc.addObject("Fem::ConstraintFixed", "FemConstraintFixed")
fixed_constraint.References = [(box, "Face1")]
active_doc.recompute()...
import Fem
ref = fixed_constraint.References[0]
femmesh = Fem.FemMesh()
from femmesh.meshtools import get_femnodes_by_refshape as getnodes
getnodes(femmesh, ref)
>>> >>> >>> >>> >>> 2
>>> >>> >>> >>> >>> >>> >>> (<Part::PartFeature>, ('Face1',))
  ReferenceShape ... Type: Face, Object name: Box, Object label: Box, Element name: Face1
<Face object at 0x556db96a92b0>
<class 'Part.Face'>
Face
bernd
Post by bernd »
BTW: I must admit it is quite easy to add a new unit test module to FreeCAD FEM :D
bernd
Post by bernd »
next found:
- start FreeCADCmd
- run the unit test --> failure
- copy the code --> it runs
- run the unit test --> it runs
- close FreeCADCmd, restart
- and so on
Founder
Post by wmayer »
What about this?
import Part
box=Part.makeBox(1,1,1)
face=box.Face1
issubclass(type(face), Part.Face)
bernd
Post by bernd »
the command to add a box
box = self.active_doc.addObject("Part::Box","Box")
seams to return a PythonFeature with a NullShape inside the unit test method in CMD (only inside unit test in FreeCADCmd !) ... whereas the Part.makeBox() returns a solid box shape
see branch https://github.com/berndhahnebach/FreeC ... femunitcmd commit (ATM) https://github.com/berndhahnebach/FreeC ... it/d696a42
import unittest
unittest.TextTestRunner().run(unittest.TestLoader().loadTestsFromName("femtest.testcmdproblem.TestCmdProblem.test_face_subclass1"))
unittest.TextTestRunner().run(unittest.TestLoader().loadTestsFromName("femtest.testcmdproblem.TestCmdProblem.test_face_subclass2"))
>>> import unittest
<Solid object at 0x55c9fa644250>
Solid
True
Ran 1 test in 0.004s
OK
<unittest.runner.TextTestResult run=1 errors=0 failures=0>
<Shape object at 0x55c9fa63d2d0>
E
ERROR: test_face_subclass2 (femtest.testcmdproblem.TestCmdProblem)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/testcmdproblem.py", line 85, in test_face_subclass2
    fcc_print(box.Shape.ShapeType)
Base.FreeCADError: cannot determine type of null shape
Ran 1 test in 0.005s
FAILED (errors=1)
<unittest.runner.TextTestResult run=1 errors=1 failures=0>
Founder
Post by wmayer »
This is correct behaviour and it's also the same with the GUI version.
box=App.ActiveDocument.addObject("Part::Box","Box")
box.Shape.isNull() # True
App.ActiveDocument.recompute() # 1
box.Shape.isNull() # False
Adding a Box feature just adds a new object and marks it as touched to be re-computed in the next update cycle.
bernd
Post by bernd »
ok with a recompute I am another step further, but I tested the recompute before ... it works in even more use cases, but I am still able to break it somehow. I will post later on.
bernd
Post by bernd »
this works ...
import unittest
>>> import unittest
>>> import TestCmdProblem
Shape: <Shape object at 0x562bd4eb9840>
isNull: True
Shape: <Solid object at 0x562bd4eb9840>
isNull: False
ShapeType: Solid
Subclass: True
<Face object at 0x562bd4ebf140>
<class 'Part.Face'>
Face
Ran 1 test in 0.009s
OK
restart FreeCAD Cmd, but this does not, the second one should be ok at least it has just above been ok:
import unittest
unittest.TextTestRunner().run(unittest.TestLoader().loadTestsFromName("femtest.testccxtools.TestCcxTools.test_1_static_analysis"))
# wait for output than
>>> import unittest
>>> import TestCcxTools
--------------- Start of FEM tests ---------------
Checking FEM new analysis...
Checking FEM new solver...
Checking FEM new material...
Checking FEM new fixed constraint...
Checking FEM new force constraint...
Checking FEM new pressure constraint...
Checking FEM new mesh...
MechanicalMaterial has empty References.
FemConstraintFixed has Face reference shapes.
FemConstraintForce has Face reference shapes.
FemConstraintPressure has Face reference shapes.
Setting up working directory /tmp/FEM_unittests/FEM_ccx_static
Checking FEM inp file prerequisites for static analysis...
Checking FEM inp file write...
Writing /tmp/FEM_unittests/FEM_ccx_static/Mesh.inp for static analysis
writerbaseCcx --> self.file_name  -->  /tmp/FEM_unittests/FEM_ccx_static/Mesh.inp
Constraint fixed: FemConstraintFixed
  Finite element mesh nodes will be retrieved by searching the appropriate nodes in the finite element mesh.
<Face object at 0x563252070d60>
<class 'Part.Face'>
Face
Unexpected error when writing CalculiX input file: <class 'TypeError'>
E
ERROR: test_1_static_analysis (femtest.testccxtools.TestCcxTools)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/testccxtools.py", line 143, in test_1_static_analysis
    error = fea.write_inp_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtools/ccxtools.py", line 650, in write_inp_file
    self.inp_file_name = inp_writer.write_calculix_input_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 113, in write_calculix_input_file
    self.write_calculix_one_input_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 143, in write_calculix_one_input_file
    self.write_node_sets_constraints_fixed(inpfile)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 501, in write_node_sets_constraints_fixed
    self.get_constraints_fixed_nodes()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/writerbase.py", line 133, in get_constraints_fixed_nodes
    femobj
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 48, in get_femnodes_by_femobj_with_references
    node_set = get_femnodes_by_references(femmesh, femobj['Object'].References)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 84, in get_femnodes_by_references
    references_femnodes += get_femnodes_by_refshape(femmesh, ref)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 114, in get_femnodes_by_refshape
    nodes += femmesh.getNodesByFace(r)
TypeError: argument 1 must be Part.TopoShape, not Part.Face
Ran 1 test in 0.029s
FAILED (errors=1)
Shape: <Shape object at 0x563251ff24e0>
isNull: True
Shape: <Solid object at 0x563251ff24e0>
isNull: False
ShapeType: Solid
Subclass: True
<Face object at 0x563251ff4da0>
<class 'Part.Face'>
Face
E
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/testcmdproblem.py", line 106, in test_face_subclass2
Ran 1 test in 0.015s
FAILED (errors=1)
very strange ...
bernd
Post by bernd »
I still have the problem on my Debian Buster even on a clean rebuild, but I do not have it on a Virtual Machine of a clean fresh Debian Buster.
Tried once again to narrow it, but it does not happen all the time, or in all circumstances ...
bernd
Post by bernd »
had to reinstall my Debian Buster after four years. As espected the problem is gone.
