[fixed] Arch/Bin/Draft V0.19 "No module named 'DraftLayer'"
nic
Postby nic » Fri Jun 07, 2019 12:19 pm
I hope I'm in the correct forum...
I cannot switch to Bim and Arch WB anymore. I guess it's linked to last Layers addition by Yorik.When I download ``src/Mod/Draft/DraftLayer.py`` to ``/usr/share/freecad-daily/Mod/Draft``, everything looks fine. I therefore suspect a packaging issue...
Anyway, here is the full Traceback from the view report:
File "<string>", line 70, in Initialize
File "/usr/share/freecad-daily/Mod/Draft/DraftTools.py", line 41, in <module>
import sys, os, FreeCAD, FreeCADGui, WorkingPlane, math, re, Draft, Draft_rc, DraftVecUtils
File "/usr/share/freecad-daily/Mod/Draft/Draft.py", line 74, in <module>
import DraftLayer
Version:
OS: Ubuntu 18.10 (i3/i3)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.11.1
Locale: French/Switzerland (fr_CH)
% apt-cache policy "freecad-daily"
freecad-daily:
Installé : 0.19~pre1~201906062118~ubuntu18.10.1
Candidat : 0.19~pre1~201906062118~ubuntu18.10.1
Table de version :
*** 0.19~pre1~201906062118~ubuntu18.10.1 500
500 http://ppa.launchpad.net/freecad-mainta ... ily/ubuntu cosmic/main amd64 Packages
500 http://ppa.launchpad.net/freecad-mainta ... ily/ubuntu cosmic/main i386 Packages
100 /var/lib/dpkg/status
** EDIT ** fixed with "0.19~pre1~201906091812~ubuntu18.10.1"
Re: Arch/Bin/Draft V0.19 "No module named 'DraftLayer'"
Postby Kunda1 » Fri Jun 07, 2019 1:13 pm
yorik wrote:
CC @yorik
yorik
Site Admin
Postby yorik » Fri Jun 07, 2019 3:53 pm
This is strange, everything is correct on the FreeCAD side...
I cant find the PPA recipe, but it is unlikely that it specifies filenames manually?
kkremitzki wrote:@kkremitzki
kkremitzki
Postby kkremitzki » Fri Jun 07, 2019 5:02 pm
No, it does exactly that, because we want to separate the different types of files by package to help out the build infrastructure. If, for example, new Python files are added, they need to be added to this file:
https://salsa.debian.org/science-team/f ... me.install
So if people were to make pull requests against that repo to update debian/*.install files for their new packages it would be picked up automatically by the daily builds.
abdullah
Postby abdullah » Fri Jun 07, 2019 5:49 pm
So everytime a developer adds a py file, for example in the Path WB or the FEM WB, a PR must be done to the repo in salsa.debian.org. Is this right?
If it is like this, is there a procedure to be followed to do that PR?
Not that I am Python competent, but I did not know this. Maybe some other Developers are not aware either, so maybe it is good to raise some awareness...
kkremitzki
Postby kkremitzki » Fri Jun 07, 2019 8:31 pm
Where possible, specific listings of .py files can be replaced, judiciously, with *'s in the paths, so long as we don't end up with files getting sucked up into the wrong packages. Python runtime files should stay in freecad-runtime, images, icons, etc, and other common resources should go in freecad-common, shared library files should go in libfreecad-pythonX-0.19, etc.
Anyone can create an account on Salsa and open a merge request just like you would a pull request on Github. I think they even have an interface for editing files directly on the website so you may not even need to clone anything. Once you create a merge request I should get notified in which case I'll review and merge, which will automatically get synced into the next daily build.
abdullah
Postby abdullah » Fri Jun 07, 2019 8:55 pm
Thanks Kurt!
Well, non-automatised deployment is quite a hurdle. Specially because we run daily builds. Applying what you have just written, maybe it can be compartmentalised per workbench directory level, so having something like:
usr/share/freecad-daily/Mod/Draft/*.py
usr/share/freecad-daily/Mod/Fem/*.py
usr/share/freecad-daily/Mod/Fem/femresult/*.py
usr/share/freecad-daily/Mod/Fem/femobjects/*.py
The rationale behind it is that *.py may only be runtime, if I understood it correctly, still a change to packaging is only necessary when a new directory is created.
This idea might be extended to other categories too (if it makes sense).
In any case, you are the packaging master. So I fully trust whatever you decide :)
Ok. Duly noted. :)
yorik
Site Admin
Postby yorik » Sun Jun 09, 2019 5:21 pm
Hmm I indeed wasn't aware of this either... It's a wonder such error hasn't appeared earlier (some parts of Draft have been split out of monstrous Draft.py and DraftTools.py already).
kkremitzki wrote: ↑
07 Jun 2019, 17:31
Ok. Duly noted. :)
Duly noted as well :) I'll open a PR for this one (if you didn't do it already) and the next ones
*EDIT* PR: https://salsa.debian.org/science-team/f ... requests/7
kkremitzki
Postby kkremitzki » Sun Jun 09, 2019 5:57 pm
Thanks, I've merged it and triggered a manual import on Launchpad (https://code.launchpad.net/~freecad-mai ... ecad-salsa) and triggered a manual build for the daily builds recipe (https://code.launchpad.net/~freecad-mai ... dual-build)
nic
Postby nic » Mon Jun 10, 2019 4:56 am
Fixed with with PPA version 0.19~pre1~201906091812~ubuntu18.10.1! Thanks
