The Travis test failure thread
abdullah
Postby abdullah » Sun Jun 09, 2019 12:41 pm
Hi, one thread for reporting test failures :)
So as the title says we have a failing tests in the wild:
ERROR: test_tetra10_yml (femtest.testmesh.TestMeshEleTetra10)
  File "C:\Users\travis\build\FreeCAD\FreeCAD\build\Mod\Fem\femtest\testmesh.py"
, line 474, in test_tetra10_yml
    write(self.femmesh, outfile)
  File "C:\Users\travis\build\FreeCAD\FreeCAD\build\Mod\Fem\feminout\importYamlJ
sonMesh.py", line 203, in write
    mesh_data = importToolsFem.make_dict_from_femmesh(fem_mesh)
  File "C:\Users\travis\build\FreeCAD\FreeCAD\build\Mod\Fem\feminout\importTools
Fem.py", line 288, in make_dict_from_femmesh
    for e in femmesh.Edges:
AttributeError: 'str' object has no attribute 'Edges'
FAIL: test_1_static_analysis (femtest.testccxtools.TestCcxTools)
  File "C:\Users\travis\build\FreeCAD\FreeCAD\build\Mod\Fem\femtest\testccxtools
.py", line 220, in test_1_static_analysis
    "ccxtools write_inp_file test failed.\n{}".format(ret)
AssertionError: 'Comparing C:/Users/travis/build/FreeCAD/FreeCAD/build/Mod\\Fem\
\femtest\\testfiles\\ccx\\cube_static.inp to C:\\Users\\travis\\AppData\\Local\\
Temp\\FEM_unittests\\FEM_ccx_static\\Mesh.inp failed!\n--- \n+++ \n@@ -590,0 +59
1,5 @@\n+** outputs --> dat file\n+** reaction forces for Constraint fixed\n+*NO
DE PRINT, NSET=FemConstraintFixed, TOTALS=ONLY\n+RF\n+\n' is not false : ccxtool
Comparing C:/Users/travis/build/FreeCAD/FreeCAD/build/Mod\Fem\femtest\testfiles\
ccx\cube_static.inp to C:\Users\travis\AppData\Local\Temp\FEM_unittests\FEM_ccx_
static\Mesh.inp failed!
@@ -590,0 +591,5 @@
+*NODE PRINT, NSET=FemConstraintFixed, TOTALS=ONLY
+RF
FAIL: test_2_static_multiple_material (femtest.testccxtools.TestCcxTools)
.py", line 408, in test_2_static_multiple_material
\femtest\\testfiles\\ccx\\multimat.inp to C:\\Users\\travis\\AppData\\Local\\Tem
p\\FEM_unittests\\FEM_ccx_multimat/Mesh.inp failed!\n--- \n+++ \n@@ -1282,0 +128
3,5 @@\n+** outputs --> dat file\n+** reaction forces for Constraint fixed\n+*NO
DE PRINT, NSET=ConstraintFixed, TOTALS=ONLY\n+RF\n+\n' is not false : ccxtools w
ccx\multimat.inp to C:\Users\travis\AppData\Local\Temp\FEM_unittests\FEM_ccx_mul
@@ -1282,0 +1283,5 @@
+*NODE PRINT, NSET=ConstraintFixed, TOTALS=ONLY
+RF
FAIL: test_3_freq_analysis (femtest.testccxtools.TestCcxTools)
.py", line 524, in test_3_freq_analysis
\femtest\\testfiles\\ccx\\cube_frequency.inp to C:\\Users\\travis\\AppData\\Loca
l\\Temp\\FEM_unittests\\FEM_ccx_frequency\\Mesh.inp failed!\n--- \n+++ \n@@ -464
,0 +465,2 @@\n+** outputs --> dat file\n+** reaction forces for Constraint fixed
\n' is not false : ccxtools write_inp_file test failed.
ccx\cube_frequency.inp to C:\Users\travis\AppData\Local\Temp\FEM_unittests\FEM_c
cx_frequency\Mesh.inp failed!
@@ -464,0 +465,2 @@
FAIL: test_4_thermomech_analysis (femtest.testccxtools.TestCcxTools)
.py", line 756, in test_4_thermomech_analysis
\femtest\\testfiles\\ccx\\spine_thermomech.inp to C:\\Users\\travis\\AppData\\Lo
cal\\Temp\\FEM_unittests\\FEM_ccx_thermomech\\Mesh.inp failed!\n--- \n+++ \n@@ -
199,0 +200,5 @@\n+** outputs --> dat file\n+** reaction forces for Constraint fi
xed\n+*NODE PRINT, NSET=FemConstraintFixed, TOTALS=ONLY\n+RF\n+\n' is not false
ccx\spine_thermomech.inp to C:\Users\travis\AppData\Local\Temp\FEM_unittests\FEM
_ccx_thermomech\Mesh.inp failed!
@@ -199,0 +200,5 @@
+RF
FAIL: test_solver_framework (femtest.testsolverframework.TestSolverFrameWork)
  File "C:\Users\travis\build\FreeCAD\FreeCAD\build\Mod\Fem\femtest\testsolverfr
amework.py", line 178, in test_solver_framework
    self.assertFalse(ret, "ccxtools write_inp_file test failed.\n{}".format(ret)
Temp\\FEM_unittests\\FEM_solverframework\\Mesh.inp failed!\n--- \n+++ \n@@ -590,
0 +591,5 @@\n+** outputs --> dat file\n+** reaction forces for Constraint fixed\
n+*NODE PRINT, NSET=FemConstraintFixed, TOTALS=ONLY\n+RF\n+\n' is not false : cc
ccx\cube_static.inp to C:\Users\travis\AppData\Local\Temp\FEM_unittests\FEM_solv
erframework\Mesh.inp failed!
@@ -590,0 +591,5 @@
+RF
Ran 334 tests in 32.523s
FAILED (failures=5, errors=1)
As they appear to be FEM, I ping the FEM master:
bernd wrote: ping
wandererfan
Re: The Travis test failure thread
Postby wandererfan » Sun Jun 09, 2019 1:18 pm
Cross post re potentially missing libraries for QtXmlPatterns on Travis Win builds.
abdullah
Postby abdullah » Mon Jun 17, 2019 12:01 pm
abdullah
Postby abdullah » Sat Jul 06, 2019 11:45 am
We are having a new issue with test failure.
https://github.com/FreeCAD/FreeCAD/commits/master
Failure is:
.py", line 268, in test_1_static_analysis
    "Invalid results read from .frd file"
AssertionError: True is not false : Invalid results read from .frd file
Ran 336 tests in 34.143s
FAILED (failures=1)
Full log:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/554842187
I guess this one goes to bern...
bernd wrote:... ping ...
Russ4262
Postby Russ4262 » Wed Jul 10, 2019 2:43 pm
Starting prior to PR #2330, or there abouts, Travis CI is failing due to FEM related test.
Russ
bernd
Postby bernd » Wed Jul 10, 2019 7:19 pm
:o :oops: My one ... I missed it. As soon as I am on a computer I will try fix it. For me on linux test run fine must be on windows ...
bernd
Postby bernd » Wed Jul 10, 2019 8:09 pm
mlampert
Postby mlampert » Wed Jul 10, 2019 9:19 pm
Does the trick for me - thanks.
apeltauer
Postby apeltauer » Thu Jul 11, 2019 5:25 am
also works again on windows 10...
thanks...
