Add ons manager - development and bugs topic
mnesarco
Re: Add ons manager - development and bugs topic
Postby mnesarco » Fri May 22, 2020 11:14 pm
sgrogan wrote:
Fri May 22, 2020 11:04 pm
mnesarco wrote:
Thu May 21, 2020 7:33 pm
I hope you like it.
I was able to install the WB using Addons-manager. When activating the Extension Manager WB is empty.
OS: Windows 10 (10.0)
Version: 0.19.21189 (Git)
Hash: 0d416c807bfb12e27806e375c432a3ed08ba8701
Python version: 3.6.8
Qt version: 5.12.1
Hi sgrogan, Thank you for testing. I have not tested yet in windows environment because i have not finished yet. It should be some path related thing or something like that but I will check it later. I am trying to make it on par with current AddonManager usecases in my local environment, then i will fix portability issues.
BTW my environment is:
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.21125 (Git) AppImage
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
BTW, have you restarted FreeCAD after install?
mnesarco
Postby mnesarco » Sat May 23, 2020 12:10 am
I have tried to run FreeCAD 0.19 on windows without any success:
Windows 10, 64Bits dev image provided by Microsoft on VirtualBox6
FreeCAD_0.19.21125-Win-Conda_vc14.x-x86_64.7z
- Downloaded the .7z
- Extracted
- Run freecad.exe in bin dir
- Splash appears, then just disappear. No start
- No errors in console
- No errors in debug.log
FreeCAD_0.19.21189_x64_LP_12.1.6_PY3QT5-WinVS2015.7z
- Extracted
- Run FreeCAD.exe in bin dir
sgrogan
Postby sgrogan » Sat May 23, 2020 2:54 pm
Two things to try;
1) run FreeCADCmd.exe
If this doesn't work try installing the vcredist. https://support.microsoft.com/en-us/hel ... -downloads
2) in the bin folder rename openglsw.dll to opengl.exe and run FreeCAD.exe
I agree and will also look myself. I have restarted FreeCAD after installation of your WB.
Syres
Postby Syres » Sat May 23, 2020 3:20 pm
I think you mean:
2) in the bin folder rename the file opengl32sw.dll to opengl32.dll and run FreeCAD.exe
mnesarco
Postby mnesarco » Sat May 23, 2020 4:30 pm
I think you mean:
Yes, this worked.
sgrogan
Postby sgrogan » Sat May 23, 2020 4:38 pm
I think you mean:
Yes, this worked.
Thanks @Syres!
mnesarco
Postby mnesarco » Sat May 23, 2020 4:45 pm
It looks like the blank screen on windows problem is not related to path issues.
It appears to be related with qt packaging in the windows distribution. I need to investigate it more:
https://stackoverflow.com/questions/385 ... on-windows
mnesarco
Postby mnesarco » Sat May 23, 2020 6:54 pm
Qt version: 5.12.1
it was a Path issue after all :mrgreen:
Workspace 1_123.png (165.31 KiB) Viewed 130 times
Qt version: 5.12.1
I will push a fixed version in few hours
mnesarco
Postby mnesarco » Sat May 23, 2020 8:42 pm
Hi Friends,
Last commit fixed the windows path problem. It runs on windows now, needs a lot of testing of course, but at least you can try it.
https://github.com/mnesarco/FreeCAD_ExtMan
Cheers,
Frank.
Syres
Postby Syres » Sun May 24, 2020 11:12 am
This is what I had to hack https://github.com/mnesarco/FreeCAD_Ext ... 16:patch-1 to get the Wb to start using:
OS: Windows 7 SP 1 (6.1)
Qt version: 5.12.1
The macro that tripped up the start phase was https://wiki.freecadweb.org/Macro_FC_Convert_Lines I'm sure there's a much cleaner solution but at least you know where there's differences between your fresh Win 10 and my several years old Win 7 setup.
