What is the deal with pivy?
looo
Re: What is the deal with pivy?
Post by looo »
What is realthunders privy? Does he have a replacement?
iplayfast
Post by iplayfast »
looo wrote: Thu Jan 19, 2023 9:02 pm What is realthunders privy? Does he have a replacement?
I must have been thinking of coin, https://github.com/realthunder/coin
looo
Post by looo »
Would be nice to have these changes merged with the main coin repo...
adrianinsaval
Post by adrianinsaval »
I think he ended up making a full separate renderer due to coins limitations, eitherway, just adding more code to freecad is not a real solution, if the problem is with maintaining the code putting it inside FreeCAD's source would do nothing to improve that (in fact it might make it worse). In reality you are not facing a FreeCAD or a pivy problem, you are facing an Ubuntu problem...
iplayfast
Post by iplayfast »
adrianinsaval wrote: Thu Jan 19, 2023 11:52 pm I think he ended up making a full separate renderer due to coins limitations, eitherway, just adding more code to freecad is not a real solution, if the problem is with maintaining the code putting it inside FreeCAD's source would do nothing to improve that (in fact it might make it worse). In reality you are not facing a FreeCAD or a pivy problem, you are facing an Ubuntu problem...
I understand that we can't be responsible for ubuntu's release schedule.
I'm thinking if we added the coin repo, to the source as a sub-git. (I don't know much about them but I've seen it done in other projects). Where the coin repo is pulled in as git submodule update --init
(borrowed from this cool project) https://github.com/curv3d/curv/blob/master/BUILD.md
This way we aren't maintaining the code, but have the latest without waiting on Ubuntu.
from chatgpt
The command 'git submodule update --init' is used to fetch the latest changes from a submodule, if your project is utilizing them. A submodule is a repository or project contained within another repository. This command will recursively fetch all submodules of the current project and update them to the latest commit referenced by the parent repository.
onekk
Post by onekk »
iplayfast wrote: Fri Jan 20, 2023 5:49 am ...
from chatgpt
Appimages already do why complicate things to dolve problem of old code in recent distributions?
And chatgpt is like citying "spread sentiments" as it simply suggest most found concept expressed "around"
without doing "fact checks" if you know what a GPT3 system is. (Artificial deficiency).
Regards
Carlo D.
- Various other stuffs.
adrianinsaval
iplayfast wrote: Fri Jan 20, 2023 5:49 am I'm thinking if we added the coin repo, to the source as a sub-git. (I don't know much about them but I've seen it done in other projects). Where the coin repo is pulled in as git submodule update --init
Won't help because Ubuntu wouldn't update FreeCAD either, and would likely package coin and pivy separately anyways
iplayfast
Post by iplayfast »
onekk wrote: Fri Jan 20, 2023 6:23 am Appimages already do why complicate things to dolve problem of old code in recent distributions?
I'm talking as someone who like to compile FreeCAD on a daily basis, but currently can't due to Pivy/Coin issues. Appimages don't solve this problem.
I cited chatgtp to let you know that it's NOT a trusted source.
onekk
Post by onekk »
Once I had Debian and probably there are chances that there is around something backported.
And that you could easily compile a new version yourself.
Regards
Carlo
looo
Post by looo »
What's the problem with compiling pivy? Which system are you using?
