iplayfast wrote: ↑Fri Jan 27, 2023 6:16 am So I've tried using synaptic complete removal of pivy.so and soqt.so, and even went so far as to remove the directoriesI then in the pivy/build directory didCode: Select all
/usr/lib/python3/dist-packages$ sudo rm -rf pivy
and it seemed to install to Installing: /usr/lib/python3/dist-packages/pivy/Code: Select all
cmake .. make sudo make install
On running freecad (after making it)I've tried recompiling fresh from @realthunder's coin, and fresh from the original coin3d coin.Code: Select all
reeCAD: /home/chris/github/freecad-source/src/Mod/Part/Gui/TaskDimension.cpp:1343: static void PartGui::ArcEngine::initClass(): Assertion `SoEngine::getClassTypeId() != SoType::badType()' failed. /home/chris/bin/freecad: line 2: 89991 Aborted (core dumped) bin/FreeCAD
In every case I'm getting the same crash.
so I'm obviously missing a step here.
I'm sorry to be such a newb, but how would you take a fresh linux install, and build freecad from source? I can't seem to do it anymore.
What is the deal with pivy?
Re: What is the deal with pivy?
Working on...
https://github.com/iplayfast/CycloidGearBox
- adrianinsaval
what version of pivy are you compiling? minimum version for python 3.10 is 0.6.8
I've tried latest from https://github.com/coin3d/pivy as well as installing latest coin from there, and also realthunder's coin (which I believe was the start of my problems).
I've also tried using latest from apt-get (python3-pivy) which is 0.6.5-1build6.
Working on...
A fixed package has been released in Ubuntu 22.04. Please try pivy 0.6.5-1ubuntu0.22.04.1.
https://bugs.launchpad.net/ubuntu/+sour ... ug/2000840
I have been able to compile it recently (using github versions of pivy and coin), so I'm not inclined to potentially break it again.
Working on...
Would you be so kind as to guide me on how to compile pivy for Ubuntu 22.04. I too am having lots of difficulty. I've spent days on it already. Thanks.
