File->Revert crash
Giovanni Bianchessi
File->Revert crash
Postby Giovanni Bianchessi » Wed Aug 21, 2019 3:04 pm
File->Revert drive Freecad too crash.
Example sequence:
Run FreeCAD
New project
Create a simple cube using NewBody, Newsketch, Pad
Save the project
File->Revert
(requester to confirm) press Yes
-Crash-
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000160
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0x160:
    __TEXT                 0000000104651000-0000000104659000 [   32K] r-x/rwx SM=COW  /Grafica/FreeCAD.app/Contents/Resources/bin/FreeCAD
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libFreeCADGui.dylib           	0x00000001046ea884 Gui::Document::getViewProvider(App::DocumentObject const*) const + 4
1   PartDesignGui.so              	0x000000015110706e PartDesignGui::ViewProviderBody::updateData(App::Property const*) + 318
2   libFreeCADGui.dylib           	0x0000000104a79e8b Gui::ViewProvider::update(App::Property const*) + 107
3   libFreeCADGui.dylib           	0x00000001046e142f Gui::Document::slotChangedObject(App::DocumentObject const&, App::Property const&) + 143
4   libFreeCADApp.dylib           	0x00000001059b57f8
Creating an empty project only, saving it and reverting does not crashes the program.
OS: macOS High Sierra (10.13)
Version: 0.19.17798 (Git)
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
Locale: Italian/Italy (it_IT)
Last edited by Giovanni Bianchessi on Fri Aug 30, 2019 5:48 pm, edited 1 time in total.
Re: File->Revert crash
Postby Kunda1 » Thu Aug 22, 2019 4:25 pm
This may be related to that info but reported after the "Big Merge"
https://forum.freecadweb.org/viewtopic.php?f=19&t=38746
Postby chrisb » Thu Aug 22, 2019 9:20 pm
Crash confirmed.
Same with similar use case: Open an existing file, change nothing, revert -> crash.
Qt version: 5.9.7
Locale: English/Germany (en_DE)
Postby chrisb » Thu Aug 29, 2019 9:55 am
While the undo issue linked above is fixed, the revert crash is still present. I have investigated it further and found the following behaviour.
Precondition: FreeCAD is started and Start WB is open.
  • Use case: new document
    - create a new document
    - switch to Part WB
    - create a standard cube
    - save it
    - revert it
    After the confirmation the tab is closed and I see only Start WB tab
    The cube is still available in the tree, I have to open a new view to show it
  • Use case: simple existing document
    - open the cube from above
    - change something, e.g. height to 20
    - revert
    -> same situation as previous use case
  • Use case: existing more complex document
    - load file 20190828-bathroom.countertop.FCStd attached to bejant's post https://forum.freecadweb.org/viewtopic. ... 63#p330163
    - revert without changing anything-> Crash!
  • Same use case as before with changing something
    ->Same behaviour: crash!
Version: 0.19.17904 (Git)
Hash: ffcac528d54195092a8ab2e9ab6f4ed39bcaebbc
Qt version: 5.12.1
There are different places where issues are reported. The tracker is the right place to track these. Users can see if they are fixed or not. I would vote for a new project "Link" where the Big Link Merge issues are collected.
To keep realthunder's back as free as possible I encourage other users to keep track of the state of those tickets.
Giovanni Bianchessi
Postby Giovanni Bianchessi » Thu Aug 29, 2019 5:07 pm
With release 17904, also opening a recent file lead to crash:
Process:               FreeCAD [22374]
Path:                  /private/var/folders/*/FreeCAD.app/Contents/Resources/bin/FreeCAD
Identifier:            ???
Version:               ??? (0.19-17904)
Code Type:             X86-64 (Native)
Parent Process:        ??? [22370]
Responsible:           FreeCAD [22374]
User ID:               507
Date/Time:             2019-08-29 19:03:00.991 +0200
OS Version:            Mac OS X 10.13.6 (17G8030)
Report Version:        12
Anonymous UUID:        B86CC982-2F52-FB9B-B3CE-5EBB7D92DE4B
Sleep/Wake UUID:       D1DF9A21-3056-4583-A879-488FBB439DC8
Time Awake Since Boot: 20000 seconds
Time Since Wake:       1300 seconds
System Integrity Protection: enabled
Notes:                 Translocated Process
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Regards
Giovanni Bianchessi
Last edited by Giovanni Bianchessi on Fri Aug 30, 2019 5:46 pm, edited 3 times in total.
Postby chrisb » Thu Aug 29, 2019 8:56 pm
If you use code tags </> the post's readability is improved. You can edit your post.
