Why does App::MaterialObjectPython needs a Shape?
furti
Re: Why does App::MaterialObjectPython needs a Shape?
Postby furti » Tue Aug 27, 2019 5:27 am
realthunder wrote:
Mon Aug 26, 2019 11:30 pm
If there isn't, it uses Part.getShape() to obtain shape
But this is exactly the harmful thing. Wgen a simple group has no shape, it shouldn't have a shape property at all.
so you can now simply use App.Link, App.Part, or even plain group to do modeling if you want, for Python code that is
But there is no need to have a Shape by default. When i want to turn a plain group into a shape, i can add a shape with the newly introducec dynamic properties beforehand. No need to "pollute" everything with a shape :)
realthunder
Postby realthunder » Tue Aug 27, 2019 6:33 am
But you'll need logic to populate the shape, simply adding a dynamic property is not enough. The default 'Shape' is so that existing features, like Fuse, Cut, or other exotic Part Python features can work on these new types of objects without modification.
Any concrete example of having an extra Shape property breaking anything? I mean I have already modified the logic so that if Part.getShape() can't get anything, it won't provide the default 'Shape'. But if it can, will it break anything?
furti
Postby furti » Tue Aug 27, 2019 7:14 am
The first post links to a help request where this caused a problem.
And given the huge amount of external workbenches there might be a lot of unspotted bugs because of this. Or maybe everything is fine. Nobody knows this.
But as DeepSOIC and yorik pointed out, they think they used the same check for shape properties too.
And despite the fact that this can cause problems, giving something a shape that is not an actual shape is not a good design decision in my opinion.
Where to stop when we once start with such things?
realthunder
Postby realthunder » Tue Aug 27, 2019 7:30 am
I have mentioned that I have already changed logic. In other word, the material object will no longer have a Shape.
Part.getShape() cannot just pull out some shape from nowhere. It currently support link and group. If for any reason you do actually want to differentiate real Shape property vs. Shape attribute, call obj.getPropertyByName('Shape'), and catch the AttributeError.
furti
Postby furti » Tue Aug 27, 2019 8:02 am
Oh sorry for that. I didn't understand your post like that :oops:
Will check this changes when available :)
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 11:36 am
From my perspective, not much. I have found only one place in my addons, where having a Shape attribute on Part object breaks something: MuxAssembly feature of Part-o-magic. which is essentially a replacement of that missing .Shape property, except it isn't affected by visibility, and has a few options such as flattening the resulting compound.
In there, the main use of hasattr(.., 'Shape') was to a) pick the objects to include in the compound, and b) tell apart Bodies (which totally have a useful Shape and should not be explored inside), from Parts, which didn't have a useful shape, and should be explored by the tool.
Fixing it shouldn't be a problem, I guess, as I can use something like 'Shape' in .PropertiesList instead. Or even leave it as is (but I'm not a fan of Part's Shape being affected by visibility of stuff inside; there should be another Visibility-like property for that, like child.Enable, or aPart.Tip)
Since my two addons are very shape-centric, having Shape property on Parts is generally a new feature for the workbench, not a problem.
realthunder
Postby realthunder » Tue Aug 27, 2019 12:04 pm
Use getPropertyByName(), a lot faster.
Yes indeed. I'll implement that soon.
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 12:19 pm
:D
:D :D
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 2:19 pm
Also, PoM Exporter and PoM ShapeGroup need patching because of this.
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 2:44 pm
… PoM's ShapeGroup, Exporter and MuxAssembly should be working as before now, I have pathed them.
