Debug Python
Re: Debug Python
It looks like it was not properly installed. Therefore I ran:
C:\Winpdbsource\winpdb-1.4.8>python setup.py install -f
running install
running build
running build_py
running build_scripts
copying winpdb.bat -> build\scripts-2.6
copying rpdb2.bat -> build\scripts-2.6
running install_lib
copying build\lib\rpdb2.py -> C:\Python26\Lib\site-packages
copying build\lib\winpdb.py -> C:\Python26\Lib\site-packages
byte-compiling C:\Python26\Lib\site-packages\rpdb2.py to rpdb2.pyc
byte-compiling C:\Python26\Lib\site-packages\winpdb.py to winpdb.pyc
running install_scripts
copying build\scripts-2.6\rpdb2.bat -> C:\Python26\Scripts
copying build\scripts-2.6\winpdb.bat -> C:\Python26\Scripts
copying build\scripts-2.6\winpdb_.pyw -> C:\Python26\Scripts
copying build\scripts-2.6\winpdb_inst.py -> C:\Python26\Scripts
running install_egg_info
Writing C:\Python26\Lib\site-packages\winpdb-1.4.8-py2.6.egg-info
Right now when I
import rpdb2
I get:
C:\Python26\lib\site-packages\rpdb2.py:308: DeprecationWarning: the sets module is deprecated
import sets
C:\Python26\lib\site-packages\rpdb2.py:313: DeprecationWarning: The popen2 module is deprecated. Use the subprocess module.
import popen2
File "C:\Python26\lib\site-packages\rpdb2.py", line 343, in <module>
import xmlrpc.server as SimpleXMLRPCServer
ImportError: No module named xmlrpc.server
Thanks.
running install
running build
running build_py
running install_lib
Right now when I
import rpdb2
I get:
import sets
import popen2
Thanks.
Jair Santos
Re: Debug Python
This is the relevant part of rpdb2.py
So, you see that for Python2 you need the modules inside the try/except block, i.e. SimpleXMLRPCServer, ...
Is this a proper Python installation under C:\Python26\ or did you install only WinPdb there?
try:
import SimpleXMLRPCServer
import xmlrpclib
import SocketServer
import commands
import copy_reg
import httplib
import thread
except:
# The above modules were renamed in Python 3 so try to import them 'as'
import xmlrpc.client as xmlrpclib
import socketserver as SocketServer
import subprocess as commands
import copyreg as copy_reg
import http.client as httplib
import _thread as thread
Re: Debug Python
Hello.
Yes, that's exactly what I have in in rpdb2.py in the directory C:\Python26\Lib\site-packages. Python is installed under C:\Python26.
When googling the rror I've found this issue reported as a bug on winpdb. See below.
https://code.google.com/p/winpdb/issues/detail?id=6
https://code.google.com/p/winpdb/issues/detail?id=13
I believe that there is something wrong with my installation.
thanks.
thanks.
Jair Santos
Re: Debug Python
Hi.
I uninstalled both python and wxPython. The I reinstalled again.
On FC, the comand import rpdb2 still returns
import rpdb2
import sets
import popen2
Thanks.
import rpdb2
import sets
import popen2
Thanks.
Jair Santos
Re: Debug Python
Here are the steps how I did it:
1. Use the LibPack and create a directory DLLs inside the "bin" folder
2. Download https://winpdb.googlecode.com/files/winpdb-1.4.8.zip and copy the files rpdb2, rpdb2.py, winpdb, winpdb.py to DLLs
3. Download http://switch.dl.sourceforge.net/projec ... 1-py26.exe and choose a fresh directory. You don't need to install it into an existing Python installation.
4. From this installation copy "wxversion.py" and the directories "wx" and "wxPython" to DLLs
5. In DLLs create the file wx.pth with the content: wx-2.8-msw-unicode
6. Open a terminal window and cd to DLLs. Run "python winpdb.py"
Make sure that FreeCAD\bin is in your system path so that it finds the python.exe
Re: Debug Python
Thanks.
I followed the procedure step by step:
C:\FreeCADLibs_8.0_x86_VC9\bin\DLL>python winpdb.py
C:\FreeCADLibs_8.0_x86_VC9\bin\DLL\rpdb2.py:308: DeprecationWarning: the sets mo
dule is deprecated
import sets
C:\FreeCADLibs_8.0_x86_VC9\bin\DLL\rpdb2.py:313: DeprecationWarning: The popen2
import popen2
File "winpdb.py", line 297, in <module>
import rpdb2
File "C:\FreeCADLibs_8.0_x86_VC9\bin\DLL\rpdb2.py", line 343, in <module>
dule is deprecated
import sets
import popen2
import rpdb2
Jair Santos
Re: Debug Python
I guess you have set some environment variables or some strange settings in your registry which have an impact on Python. That's the only explanation I have.
Re: Debug Python
It's a real pain.
I started to clean up the mess like PATHs , uninstall programs, etc.. I looks like there was a trap somewhere. When I ran FC , VS said that we should update the build. Running it I got errors like Error 1 error PRJ0019: A tool returned an error code from "VectorPy.xml" FreeCADBase FreeCADBase . They are all over the place.
It seems that it is something related with the manifest. I am googling around but so far no solution.
Regards.
Regards.
Jair Santos
Re: Debug Python
We run python code in our build process to compile the .xml to cpp files. so in order to compile you need a python installed or the VS use the one from LibPack...
Stop whining - start coding!
