FreeCAD 0.19 ignores active container color setting
adrianinsaval
Post by adrianinsaval »
OS: Windows 10 (10.0)
Version: 0.19.18024 (Git)
Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
Python version: 3.6.8
Qt version: 5.12.1
Locale: Spanish/Paraguay (es_PY)
Freecad ignores the active container setting as shown in attached screenshot, making it really ugly and hard to see with some stylesheets (in this case, Darker-blue). I have confirmed the same behavior exist with the AppImage in Manjaro.
After some digging and after taking a quick look at https://github.com/FreeCAD/FreeCAD/comm ... 1a53b3fe6b I believe
void DocumentItem::slotHighlightObject (const Gui::ViewProviderDocumentObject& obj, const Gui::HighlightMode& high, bool set)
    FOREACH_ITEM(item,obj)
        QFont f = item->font(0);
        switch (high) {
        case Gui::Bold: f.setBold(set);             break;
        case Gui::Italic: f.setItalic(set);         break;
        case Gui::Underlined: f.setUnderline(set);  break;
        case Gui::Overlined: f.setOverline(set);    break;
        case Gui::Blue:
            if (set)
                item->setBackgroundColor(0,QColor(200,200,255));
            else
                item->setData(0, Qt::BackgroundColorRole,QVariant());
            break;
        case Gui::LightBlue:
            if (set) {
                ParameterGrp::handle hGrp = App::GetApplication().GetParameterGroupByPath("User parameter:BaseApp/Preferences/TreeView");
                unsigned long col = hGrp->GetUnsigned("TreeActiveColor",3873898495);
                item->setBackgroundColor(0,QColor((col >> 24) & 0xff,(col >> 16) & 0xff,(col >> 8) & 0xff));
            else
            break;
        default:
            break;
        item->setFont(0,f);
    END_FOREACH_ITEM
in src/Gui/Tree.cpp should not have different behaviors for Gui::Blue and Gui::LightBlue but always use the user's preference. I must clarify that I have very little knowledge of C++ and FreeCAD's source code so don't take my word for it.
Captura de pantalla (10).png (176.14 KiB) Viewed 1414 times
adrianinsaval
Re: FreeCAD 0.19 ignores active container color setting
adrianinsaval wrote: Tue Sep 03, 2019 1:26 amAfter some digging and after taking a quick look at https://github.com/FreeCAD/FreeCAD/comm ... 1a53b3fe6b I believe
        switch (high) {
        case Gui::Blue:
            if (set)
            else
            break;
            if (set) {
            else
            break;
        default:
            break;
        item->setFont(0,f);
    END_FOREACH_ITEM
Nevermind, turns out I was looking at the file from that commit, the current one is quite different
adrianinsaval
I think one of the commits here is supposed to fix this, can you confirm @realthunder?
realthunder wrote: Mon Sep 02, 2019 3:01 am ping
realthunder
Post by realthunder »
adrianinsaval wrote: Thu Sep 05, 2019 2:05 am I think one of the commits here is supposed to fix this, can you confirm @realthunder?
Yes, it is.
Try Assembly3 with my custom build of FreeCAD at here.
Petrikas
Post by Petrikas »
realthunder wrote: Thu Sep 05, 2019 2:49 am
Is Active Container accessible from the QSS stylesheet? I can't seem to be able to describe it.
Should be something along the lines of
QTreeView::item
I sometimes make FreeCAD Tutorials | VertUI | MidnightUI
realthunder
Petrikas wrote: Fri Jan 14, 2022 5:12 pm
QTreeView::item
No. It is configurable through parameter BaseApp/Preferences/TreeView/TreeActiveColor (unsigned type). The font can be configured through parameters TreeActiveBold/Italic/Underline/Overlined (all boolean types). You may also want to change TreeEditColor, the background color for the editing object.
Petrikas
Post by Petrikas »
realthunder wrote: Mon Jan 17, 2022 4:20 am
QTreeView::item
Thanks for the reply.
The issue arises when I try something fancy with the tree, like adding borders or rounding corners.
Doesn't matter, just checking. Thanks again!
