howetuft wrote: ↑Sat Sep 21, 2019 3:41 pm @furti and @nocturnial: Thank you, I finally succeeded, with your help!
Here is the result:
As you see, I dressed a cube with a Marble texture, a cube with a Wood texture, and a cylinder with the same Marble texture as the first cube... (all textures picked from Internet).
I'll write some more comments later (for instance, you can see something weird happens to the cylinder), but to me, at this stage, there is something cool in @furti's proposal!
Hello, can you explain me step by step how you have done the rendering with the textures?
I am using luxcore in freecad, but even if I apply the textures using ArchTexture, they are not rendered.
I need to render textures in my projects. I am using luxcore as render engine.
Thanks
