I tried it and are stuck. When calling
(base) D:\FreeCAD-feedstock>conda debug . -m .ci_support\win_cxx_compilervs2015p
ython3.7.yaml
No numpy version specified in conda_build_config.yaml. Falling back to default
numpy value of 1.11
WARNING:conda_build.metadata:No numpy version specified in conda_build_config.ya
ml. Falling back to default numpy value of 1.11
Adding in variants from internal_defaults
INFO:conda_build.variants:Adding in variants from internal_defaults
Adding in variants from D:\FreeCAD-feedstock\recipe\conda_build_config.yaml
INFO:conda_build.variants:Adding in variants from D:\FreeCAD-feedstock\recipe\co
Adding in variants from .ci_support\win_cxx_compilervs2015python3.7.yaml
INFO:conda_build.variants:Adding in variants from .ci_support\win_cxx_compilervs
2015python3.7.yaml
Collecting package metadata (repodata.json): ...working... done
Solving environment: ...working... failed
File "C:\Miniconda\lib\site-packages\conda_build\environ.py", line 757, in get
_install_actions
actions = install_actions(prefix, index, specs, force=True)
File "C:\Miniconda\lib\site-packages\conda\common\io.py", line 88, in decorate
d
return f(*args, **kwds)
File "C:\Miniconda\lib\site-packages\conda\plan.py", line 474, in install_acti
ons
txn = solver.solve_for_transaction(prune=prune, ignore_pinned=not pinned)
File "C:\Miniconda\lib\site-packages\conda\core\solve.py", line 117, in solve_
for_transaction
should_retry_solve)
File "C:\Miniconda\lib\site-packages\conda\core\solve.py", line 158, in solve_
for_diff
force_remove, should_retry_solve)
File "C:\Miniconda\lib\site-packages\conda\core\solve.py", line 275, in solve_
final_state
ssc = self._add_specs(ssc)
File "C:\Miniconda\lib\site-packages\conda\core\solve.py", line 555, in _add_s
pecs
explicit_pool = ssc.r._get_package_pool(self.specs_to_add)
File "C:\Miniconda\lib\site-packages\conda\resolve.py", line 523, in _get_pack
age_pool
pool = self.get_reduced_index(specs)
d
File "C:\Miniconda\lib\site-packages\conda\resolve.py", line 544, in get_reduc
ed_index
explicit_specs, features = self.verify_specs(explicit_specs)
File "C:\Miniconda\lib\site-packages\conda\resolve.py", line 280, in verify_sp
ecs
raise ResolvePackageNotFound(bad_deps)
conda.exceptions.ResolvePackageNotFound:
- qt=5.12
- doxygen
- netgen
- coin3d
- hdf5=1.10.5
- boost-cpp=1.70.0
- blas=[build=openblas]
- occt=7.3
- smesh
- pivy
- pyside2
During handling of the above exception, another exception occurred:
File "C:\Miniconda\Scripts\conda-debug-script.py", line 10, in <module>
sys.exit(main())
File "C:\Miniconda\lib\site-packages\conda_build\cli\main_debug.py", line 94,
in main
return execute(sys.argv[1:])
File "C:\Miniconda\lib\site-packages\conda_build\cli\main_debug.py", line 70,
in execute
activation_string = api.debug(thing_to_debug, verbose=(not _args.activate_st
ring_only), **_args.__dict__)
File "C:\Miniconda\lib\site-packages\conda_build\api.py", line 451, in debug
metadata_tuples = render(recipe_or_package_path_or_metadata_tuples, config=c
onfig, **kwargs)
File "C:\Miniconda\lib\site-packages\conda_build\api.py", line 45, in render
permit_unsatisfiable_variants=permit_unsatisfiable_variants)
File "C:\Miniconda\lib\site-packages\conda_build\render.py", line 819, in rend
er_recipe
allow_no_other_outputs=True, bypass_env_check=bypass_env_check)
File "C:\Miniconda\lib\site-packages\conda_build\render.py", line 725, in dist
ribute_variants
File "C:\Miniconda\lib\site-packages\conda_build\metadata.py", line 1018, in p
arse_until_resolved
File "C:\Miniconda\lib\site-packages\conda_build\metadata.py", line 940, in pa
rse_again
bypass_env_check=bypass_env_check),
File "C:\Miniconda\lib\site-packages\conda_build\metadata.py", line 1528, in _
get_contents
rendered = template.render(environment=env)
File "C:\Miniconda\lib\site-packages\jinja2\asyncsupport.py", line 76, in rend
er
return original_render(self, *args, **kwargs)
File "C:\Miniconda\lib\site-packages\jinja2\environment.py", line 1008, in ren
der
return self.environment.handle_exception(exc_info, True)
File "C:\Miniconda\lib\site-packages\jinja2\environment.py", line 780, in hand
le_exception
reraise(exc_type, exc_value, tb)
File "C:\Miniconda\lib\site-packages\jinja2\_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "D:\FreeCAD-feedstock\recipe\meta.yaml", line 43, in top-level template c
ode
- eigen
File "C:\Miniconda\lib\site-packages\conda_build\jinja_context.py", line 230,
in pin_compatible
pins, _, _ = get_env_dependencies(m, 'host', m.config.variant)
File "C:\Miniconda\lib\site-packages\conda_build\render.py", line 154, in get_
env_dependencies
channel_urls=tuple(m.config.channel_urls))
File "C:\Miniconda\lib\site-packages\conda_build\environ.py", line 759, in get
_install_actions
raise DependencyNeedsBuildingError(exc, subdir=subdir)
conda_build.exceptions.DependencyNeedsBuildingError: Unsatisfiable dependencies
for platform win-64: {'occt=7.3', 'boost-cpp=1.70.0', 'smesh', 'blas=[build=open
blas]', 'pyside2', 'hdf5=1.10.5', 'netgen', 'qt=5.12', 'coin3d', 'pivy', 'doxyge
n'}
I could install miniconda successfully in advance. I have MSVC 2017 installed and can successfully use it to build FC using the LibPack.
