Well, but in general reviewing the errors and warnings is more important then the recommendations... Things can always be better but in general I would say we are doing quite ok
GitHub CodeQL (formerly Semmle LGTM)
Re: LGTM (split from 'Code quality checker' thread)
Context: https://forum.freecadweb.org/viewtopic. ... 16#p354621
Edit: Actually, I think the answer is in https://lgtm.com/help/lgtm/showing-hiding-query-results
First, is there a consensus about this?
vocx wrote: ↑Tue Dec 17, 2019 7:59 pmKunda1 wrote: ↑Tue Dec 17, 2019 3:52 am @furti heads-up:
https://lgtm.com/projects/g/FreeCAD/Fre ... c3c40525:1Code: Select all
for i in range(8): parts.append(Part.makeBox(20, 20, 1000 - 60, FreeCAD.Vector((2000 / 9 * (i + 1)) - 10, 15, 30)))
This is a warning about Python 2, because in Python 2 the division operator truncates the decimal part if both quantities are integers. That is, 2000/9 = 222.LGTM wrote:Result of division may be truncated as its left and right arguments may both be integers.
In Python 3 it works as expected, 2000/9 = 222.222.
To solve this for Python 2, at least one value must be a float, 2000.0/9
See pull request #2788.
I can't seem to discern if there is a way to tell LGTM to ignore python2 warnings/recommendations/errors.
It's not like a hard deprecation, but de-facto Python 2 is done. We should move forward with only Python 3.Kunda1 wrote: ↑Thu Dec 19, 2019 10:11 am I can't seem to discern if there is a way to tell LGTM to ignore python2 warnings/recommendations/errors.
https://pythonclock.org
The only thread where this is mentioned lately is this: Python2 in FreeCAD 0.19 is being abandoned
Werner says we should use Py3/Qt5. Small fixes, to make it compatible with Python 2 can still be done, but nothing major. This is the case of my fix above.
@saso IMHO I think we should make a step by step tutorial for external workbench authors that makes it easy to get them to implement LGTM in their repos. Thoughts ?
There is really nothing to it, when you are logged in to LGTM just go to the "My projects" page, there you can add any project you want. This will start the LGTM to regularly analyze the project and can be enough for most cases... If there is the need for more specific configuration then it is best to first look in to LGTM Help pages https://lgtm.com/help , ask in the LGTM community https://discuss.lgtm.com/ or ask here so we can try to find the solution together.
Here are a few of our related projects (one can also use the LGTM Search to find out if a project is already there)
https://lgtm.com/projects/g/FreeCAD/FreeCAD/
https://lgtm.com/projects/g/yorikvanhav ... Workbench/
https://lgtm.com/projects/g/tomate44/CurvesWB/
https://lgtm.com/projects/g/wonderworks ... re/PyFlow/
https://lgtm.com/projects/g/microelly2/NodeEditor/
https://lgtm.com/search?q=freecad
Update: A note about the shut down of LGTM.com
https://github.blog/2022-08-15-the-next ... -scanning/
Re: LGTM (Semmle CodeQL)
I've been slowly making PRs to various FreeCAD add-ons. I'm tracking LGTM integration in upstream add-on repos in the ticket below for anyone that is interested or wants to help:
https://github.com/FreeCAD/FreeCAD-addons/issues/163
LGTM (CodeQL) supports the export of results to the Static Analysis Results Interchange Format (SARIF). There is a SARIF viewer for Visual Studio and VS Code. For VS Code, release 3.0.0 or newer of the SARIF viewer should work ok. I didn't test the Visual Studio version yet. Below is a screenshot of the LGTM report saved in the SARIF format and opened in VS Code.
https://sarifweb.azurewebsites.net/
https://github.com/microsoft/sarif-vscode-extension
https://github.com/Microsoft/sarif-visu ... extension/
https://github.com/microsoft/sarif-python-om
https://pypi.org/project/sarif-om/
https://docs.oasis-open.org/sarif/sarif ... -v2.0.html
https://github.com/chennes/CleanSARIF
Thanks for the heads up
Another small note, in the online LGTM report one can get more information about the individual alerts from the links to the help pages of the related queries, but one can also search for this from the "Search LGTM" (top left in the main page https://lgtm.com/ or from the freecad project https://lgtm.com/projects/g/FreeCAD/FreeCAD/), for example, this search https://lgtm.com/search?q=Missing%20hea ... rd&t=rules gives some details on this rule -> https://lgtm.com/rules/2163210746/
New report from build 0.19.22366 has been created, differently then the python results that are build automatically and available on the LGTM website, I am building the cpp results manually, similar to the Coverity and PVS-Studio...
