Should every Unit have an App::Property?
vocx
Postby vocx » Fri Oct 25, 2019 3:21 pm
In this thread FreeCAD as pre-post procesor for MBDyn developers are trying to implement a graphical interface for a body dynamics solver.
One of the properties that a scripted object could have is Mass. The author realizes that there is no App::PropertyMass, but there are properties for other physical quantities
App::PropertyDistance
App::PropertyLength
App::PropertySpeed
App::PropertyAcceleration
App::PropertyForce
App::PropertyPressure
These are defined in src/App/PropertyUnits.h.
These all seem to be based on App::PropertyQuantity, which are just derived from App::PropertyFloat (a numeric value).
My question is, since those properties above use Units, shouldn't there be an App::Property for every single unit defined in src/Base/Unit.h? Or why do some units have an App::Property but most do not? Is there are reason for this?
Re: Should every Unit have an App::Property?
Postby yorik » Mon Nov 04, 2019 3:14 pm
Not for every unit, because in a same field you must be able to write inches or centimeters.
But I would say for every unit type yes. Lengths, weights, areas.. Basically one that cannot be converted to another and where you would want the user to specifically have to use a certain unit and not another.
But to me this can come as the need arises, no need to rush to add complexity before it's actually needed by someone.
vocx
Postby vocx » Mon Nov 04, 2019 3:42 pm
I agree. There is no need to add complexity. But that's why I asked this question.
As mentioned in the thread, FreeCAD as pre-post procesor for MBDyn, the developer could use an App::PropertyMass property, but this currently does not exist. So the question is, should there be a Mass property? Why not expose more properties (or property types) already so that if somebody needs them, they can use them?
DeepSOIC
Postby DeepSOIC » Mon Nov 04, 2019 4:21 pm
There is a generic PropertyQuantity, which can have any unit, and possibly can enforce it. It lacks proper python interface.
Postby yorik » Sun Nov 17, 2019 4:26 pm
In any case, a PropertyMass seems a good idea to me...
mfasano
Postby mfasano » Mon Nov 18, 2019 8:19 pm
I would think density would be the property you want.
would the material editor work for this?
