Discussion: removing Ply from FreeCAD's source code
vocx
Postby vocx » Thu Jan 16, 2020 5:09 am
Ply (Python-lex-yacc) is a dependency of the OpenSCAD Workbench.
However, as of now, the entire Ply package is included inside the subdirectory of OpenSCAD.
src/Mod/OpenSCAD/ply/
Apparently this was for historical reasons, because in the past, around 2013, Ply was not easily installable from Linux repositories.
Nowadays, Ply can be installed from apt, pip, and I guess other packagers.
apt-cache policy python3-ply
python3-ply:
  Installed: 3.11-1
  Candidate: 3.11-1
  Version table:
 *** 3.11-1 500
        500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu bionic/main i386 Packages
        100 /var/lib/dpkg/status
Therefore, there is no need to carry this library in the source of FreeCAD itself. Like other Python dependencies, it should be listed as a dependency on installation, so FreeCAD packages in every platform should be updated accordingly.
In pull request #2890, KeithSloan updates the package in FreeCAD's source, due to issue #4228. Obviously we don't want to manually update it every time there is a new version.
In pull request #2904 (#2953), Keith removes the package. So, after this is done, then all platforms Linux, Windows, Mac, should include Ply as a dependency on installation.
I guess this is already done for Debian/Ubuntu, because in this version I don't see the Ply directory inside the OpenSCAD subdirectory. I don't know how Windows or Mac handle this. Is Ply included in the conda packages?
looo
Re: Discussion: removing Ply from FreeCAD's source code
Postby looo » Thu Jan 16, 2020 5:38 am
This one here?
https://anaconda.org/conda-forge/ply/files
We do not support openscad/openscad wb via conda-packages. So I don't see a reason to include a pure python package only to satisfy dependencies of a external installable tool (openscad).
So from my point it's fine to remove ply. Source copying is really not a good way of package-handling...
In the long run someone might come up with a PR to build openscad for conda-forge. This is the only way to improve the support of openscad for the appimage and the dmg. But the interest in this seems to be not very high, therefore better to avoid this work for now.
vocx
Postby vocx » Thu Jan 16, 2020 6:07 am
I don't understand what you mean here. OpenSCAD is obviously an external tool, but the OpenSCAD Workbench is part of FreeCAD, so its dependencies are also FreeCAD dependencies, just like Pivy is a dependency of FreeCAD through the Draft Workbench.
So, Ply is a dependency of FreeCAD and it should be installed when the user installs the FreeCAD stable or daily package in Debian/Ubuntu, and it should be in the *.7z for Windows, and in the AppImage.
Are you saying that you will not include Ply in the AppImage, nor Windows build?
I told Keith to remove the Ply package from FreeCAD's source because surely this can be included in the Windows and Mac packages, and AppImage. But if this is not the case, then Ply needs to remain in the FreeCAD source so that the OpenSCAD Workbench won't break.
looo
Postby looo » Thu Jan 16, 2020 7:28 am
So, Ply is a dependency of FreeCAD and it should be installed when the users installs the FreeCAD stable or daily package in Debian/Ubuntu, and it should be in the *.7z for Windows, and in the AppImage.
So you are saying that ply is a direct dependency of freecad? If this is the case you are right. On the other hand I guess ply is useless without an installed openscad?
But you are right, including the package for the appimage/dmg is not a big deal. I will do it for the next iteration.
vocx
Postby vocx » Thu Jan 16, 2020 7:56 am
Ply is a dependency of OpenSCAD Workbench. If you consider OpenSCAD Workbench being FreeCAD, then yes, it's a direct dependency of FreeCAD.
If Ply is not installed, OpenSCAD Workbench will not work, whether OpenSCAD executable is installed or not. Although the rest of FreeCAD should work normally, as far as I know.
Okay, so this is what I think is best.
looo
Postby looo » Thu Jan 16, 2020 9:16 am
I guess every dependency of an internal workbench is a direct dependency of freecad.
The dependency list is growing:
https://github.com/looooo/freecad-feeds ... 234e8f0ec2
vocx
Postby vocx » Thu Jan 16, 2020 3:59 pm
That's my idea as well.
The dependency list isn't growing, it was already as big. It's just now more organized.
sgrogan
Postby sgrogan » Thu Jan 16, 2020 10:22 pm
I little of both maybe. Anyway if we don't need to maintain 3rd party code in FreeCAD that is good.
As far as I can tell, ply is only used here: importCSG.py#L45 for .csg file support. I also see in the Mesh and Points WB's .ply files are supported, but it doesn't seem to depend on this library. I could of course be wrong.
It looks to me that it would only be a runtime dependency, although Kurt has it as a Build-Depends here: ppa/daily
I'll add the lib to the win dev builds and the libpack (that Travis uses) in case there are tests that check .csg file support. I will try to do this over the weekend.
I think we should make an announcement in the install/compile or packaging sub-forum for those packaging for non Debian/Ubuntu distros. Maybe I should also add this to the releases page for 0.19_pre? Not sure because it should be transparent there?
"fight the good fight"
kkremitzki
Postby kkremitzki » Thu Jan 16, 2020 11:26 pm
+1 to including something like "removed bundled copy of ply, aka python lex-yacc." in 0.19 changelog.
vocx
Postby vocx » Fri Jan 17, 2020 1:56 am
... I also see in the Mesh and Points WB's .ply files are supported, but it doesn't seem to depend on this library. I could of course be wrong.
It seems that Mesh (and maybe Points) utilizes the OpenSCAD indirectly, so Ply may be an indirect depedency.
https://github.com/FreeCAD/FreeCAD/blob ... py#L36-L45
class OpenSCADWorkbench ( Workbench ):
    "OpenSCAD workbench object"
    def __init__(self):
        self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg"
        self.__class__.MenuText = "OpenSCAD"
        self.__class__.ToolTip = (
            "OpenSCAD is an application for creating solid 3D CAD.\n"
            "FreeCAD utizes OpenSCAD's capability as a script-only based modeller that uses its own description language\n"
            "Note: the Mesh workbench heavily uses the boolean operations of this workbench because they are quite robust"
Sounds good to me. Thank you both.
