testing modifications of Asm3
Hello
I wanted to test a modification of Asm3 in daily.
Here is the situation: now that we have asm3 included in conda appimage, I began to test this awesome assembly workbench. Now I detected what I think to be a regression python2->python3.
[edit]: issue described here https://github.com/realthunder/FreeCAD_ ... issues/284
I then cloned realthunder's asm3 repository https://github.com/realthunder/FreeCAD_assembly3. Now my question is: how to use this cloned repository (in daily for example) to test my modifications. I tried to link the local clone to ~/.FreeCAD/Mod, but this didn't work.
Any clue?
EDIT: I also tried to configure the addon manager to use my clone, without success (asm3 doen't appear in the addon manager)
Any clue?
- 2020-02-04_08-29.png (21.31 KiB) Viewed 1967 times
Re: testing modifications of Asm3
Now, I tried to unpack appimage. I the remove squashfs-root/usr/lib/python3.8/site-packages/freecad/asm3 and linked my modified version to the same place.
I then fired up the appimage using. I was able to switch to asm3 WB, but my assembly looks now dead. The following message is issued in the console:
or
[edit] The same assembly is still working in non-unpacked appimage
./AppRun
<asm3.sys> solver.py(340): no assembly found
<asm3.proxy> proxy.py(180): test#Assembly has unknown System type 1
- 2020-02-04_08-54.png (11.9 KiB) Viewed 1962 times
Modifying **inplace** works good and solved the bug. So why cannot I link this to my own clone repo? that's a question....
anyway
Still learning git (coming from mercurial, git looks so... complex).
I pushed my change to https://github.com/numenic/FreeCAD_asse ... /fixXrange (therefore new branch).
Now I don't understand why my repo says I'm "50 commits behind realthunder:master. ", although I cloned latest realthunder's master...
@realthunder, should I proceed with pull request?
You may need to run
This rebases your changes on top of the Upstream master branch. You can look up the differences between git rebase and git merge.
The TL;DR is that rebase applies your changes to ontop of master 'cleanly' (but erases other commits that weren't from your branch from the history)
Checkout the FC wiki page on git for more guidance working with git
git pull
git rebase
There is currently no way to "overwrite" an included 3rd-party module of the appimage. But I will update the asm3 package which is shipped with the appimage once a week (every sunday, or more often if I see important commits). So the mentioned commit should be available soon.
Just for information, has the Asm3 License issue been solved, to allow the Asm3 package to be shipped with FreeCAD AppImage?
I'm referring to SolveSpace License
https://forum.freecadweb.org/viewtopic. ... 30#p235073
https://github.com/solvespace/solvespace#license
EDIT:
Moreover, I cannot see any mention to SolveSpace License in the bundled application.
I asked about this some time ago:easyw-fc wrote: ↑Wed Feb 05, 2020 10:08 pmJust for information, has the Asm3 License issue been solved, to allow the Asm3 package to be shipped with FreeCAD AppImage?
EDIT:
https://forum.freecadweb.org/viewtopic.php?f=8&t=42853
Yes, this is basically what we have discussed in the other thread. Having Assembly 3 module included by default can lead to such outcomes. I guess lets try it out and see how it goes on a longer run.
P.S. As for some technical solution, to add an additional list of dependencies under Help -> About FreeCAD. I plan to return to that discussion on February or March. Hopefully we will be able to find an acceptable technical solution, before release.
i contacted the solvespace author regarding special licence for freecad but he did not want to. i think its mentioned somewhere in the first 50 pages of the asm3 thread :p
also asm3 is not supposed to be solver dependant.there was some python solver alternative? atleast in the beginning.
