[SOLVED] Failed to build on mips64el arch
brep
Postby brep » Sat Feb 15, 2020 5:26 am
While tring to build FreeCAD on a mips64el-arch machine (Loongson 3A4000 for specific), I got many build errors like this:
relocation truncated to fit: R_MIPS_CALL16
Add this line to CMakeLists.txt solved the problem:
SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}" -mxgot")
PrzemoF
Re: [SOLVED] Failed to build on mips64el arch
Postby PrzemoF » Sat Feb 15, 2020 7:14 am
Welcome to the forum!
I edited the title of your post as it sugested you need help, which is not the case. Thanks for sharing the solution! Is it something that should end up up in the main tree? If so, maybe you could preapre an official pull request - then it would be tested on other architectures to make sure it doesn't break existing builds.
Postby chrisb » Sat Feb 15, 2020 7:35 am
Should this go to the Compile/Install forum?
sgrogan
Postby sgrogan » Sat Feb 15, 2020 12:43 pm
Yes, please
PrzemoF
Postby PrzemoF » Sat Feb 15, 2020 5:30 pm
Moved.
kkremitzki
Postby kkremitzki » Sat Feb 15, 2020 10:18 pm
Very cool to hear that you're getting FreeCAD to work on a mips64el machine! I had heard about these Loongsons recently (https://jonathancarter.org/2020/02/13/i ... son-pi-2k/). I'm surprised this issue didn't show up already for the Debian mips64el builds.
