Reload Workbenches for Development
usbhub
Post by usbhub »
Hello,
sorry for my newbie questions :roll:
I'm programming my first bigger workbench and if I make a change in the code, I have to restart FreeCAD completly. I searched through the forum and found this old thread https://forum.freecadweb.org/viewtopic.php?t=320. If I understood right, if you do things in the GUI manually, a simple reload doesn't work.
But the thread is 10 years old and so I ask again, if there is another, better possibility already? What are developers of FEM or TechDraw doing?
PS: If not, maybe a script/maco exist, that restarts FreeCAD automatically and load the right workbench and opened model again?
Re: Reload Workbenches for Development
Post by wmayer »
Let's consider a simple workbench called MyTestWorkbench with this code in its InitGui.py file:
class MyTestWorkbench (Workbench):
    "Mesh workbench object"
    def __init__(self):
        self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/Mesh/Resources/icons/MeshWorkbench.svg"
        self.__class__.MenuText = "My Test workbench"
        self.__class__.ToolTip = "My Test workbench"
    def Initialize(self):
        pass
    def Activated(self):
        import MyTest
        print (dir(MyTest))
Gui.addWorkbench(MyTestWorkbench())
This file is executed at start of FreeCAD and an instance of the workbench class is created and registered to the application. If you now make changes to this InitGui.py file then this won't affect the already created instance. You have to unregister the workbench first and then re-execute the code.
If you instead make changes to the module MyTest.py then the procedure is simpler. In the Python console you have to enter import MyTest and then reload it again with:
from importlib import reload
reload(MyTest)
Assuming you have added a new top-level function to MyTest.py then the next time you activate your workbench you will see it in the output window.
You need an additional step. Here an example for generic_post.py:
import generic_post
reload(generic_post)
Post by Kunda1 »
Is this documented somewhere?
vocx
Post by vocx »
wmayer wrote: Tue Mar 03, 2020 6:18 pm ...
I think the question is more about the graphical user interface. That is, what happens if you already defined toolbars and context menus in the Initialize method.
        # Some code here that creates toolbars
        pass
Then what? Can this code be re-initialized. Can the workbench be completely unregistered, and its InitGui.py loaded again? That's the basic premise.
Is there something like the following?
FreeCADGui.removeWorkbench("MyWorkbench")
FreeCADGui.reloadWorkbench("src/Mod/MyWorkbench/InitGui.py")
If you instead make changes to the module MyTest.py then the procedure is simpler. In the Python console you have to enter import MyTest and then reload it again...
Reloading a single Python module is not a big deal. But what if you have set up other things in Initialize, in ContextMenu, in Deactivated, etc?
Can the entire GUI setup (appendToolbar, appendContextMenu, addPreferencesPage) be included in a single Python module, so the entire interface can be reloaded?
        import MyTest # this module sets up all toolbars, context menus, preferences pages, as well as the individual commands
        print(dir(MyTest))
usbhub
Post by usbhub »
Hello,
thanks a lot to everybody! I will try it out and report to you :)
usbhub
Post by usbhub »
Sorry for may late reply, but now I tested it:
I tried the version from crisb, but it doesn't work. In the InitGui.py I load ExportCommand, but when I reload it, the changes in ExportCommand aren't applied :/
I used this to reimport the module (the workbench was already activated/selected)
import ExportCommand
reload(ExportCommand)
My FreeCAD version:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
DeepSOIC
Post by DeepSOIC »
I had little luck with reloading.
I have set up a full-blown system to reload the whole Part-o-magic with one command. It kinda worked, but commands stop working. I don't really know why.
The effort of setting up such a system outweighs the inconvenience of having to restart FreeCAD every time, and doesn't even work properly in many situations (e.g., you need yet another system to scan and update proxy instances of parametric objects)... So my recommendation is: use reload only for isolated module that you test by running its methods from py console. For everything else, it's a waste of time.
usbhub
Post by usbhub »
DeepSOIC wrote: Sat Mar 21, 2020 8:16 pm I had little luck with reloading.
Okay, that sounds not so good :(
But is there a way, that you can restart FreeCAD via python and load the current model again? That would make it a bit easier :)
Post by wmayer »
import FreeCADGui
from PySide import QtGui,QtCore
args = QtGui.QApplication.arguments()[1:]
if FreeCADGui.getMainWindow().close():
    QtCore.QProcess.startDetached(QtGui.QApplication.applicationFilePath(),args)
This restarts the FreeCAD process with the same arguments it has been started before. If in your running FreeCAD instance you have manually created a new document you want to restore then you must extend the above code snippet. Save the document under a certain file path and add it to args.
