Introduction and Bearing Creator Tool
javiermg
Re: Introduction and Bearing Creator Tool
Postby javiermg » Mon Sep 23, 2013 10:18 pm
I have realized that some of my changes are the same that jreinhardt did, so I am going to work in that direction. I also found an online document that has very useful information about bearings, and tables with standard (I think so) sizes: http://www.neita.nl/lagers/koyocat203e.pdf
Finally, this is a script that creates caseless needle bearings, like this one:
In a shaft with a bit of color:
The function is called NB(outer radius, inner radius, width)
Code:
import Part
import math
def NB(rout,rin,bth):
    rnd=(rout-rin)/2.00
    cnd=((rout-rin)/2)+rin
    nnd=2*math.pi*cnd/(1.8*2*rnd) #Needle number
    nnd=math.floor(nnd)
    nnd=int(nnd)
    #needle cage--------------
    ncrout=cnd+0.175*(rout-rin)
    ncrin=cnd-0.175*(rout-rin)
    nc1=Part.makeCylinder(ncrout,bth)
    nc2=Part.makeCylinder(ncrin,bth)
    nc=nc1.cut(nc2)
    #needle space on the cage-
    rsnd=rnd*1.2
    thsnd=bth*0.8
    for i in range(nnd):
      snd=Part.makeCylinder(rsnd,thsnd)
      Alpha=(i*2*math.pi)/nnd
      nv=(cnd*math.cos(Alpha),cnd*math.sin(Alpha),0.1*bth)
      snd.translate(nv)
      nc=nc.cut(snd)
    #Needle creation----------
      nd=Part.makeCylinder(rnd,thsnd)
      nd.translate(nv)
      Part.show(nd)
    Part.show(nc)
    Gui.SendMsgToActiveView("ViewFit")
Next thing I want to do is searching about how to change the material to give it a better look, and possibly merge all bearing creators in the same script creating a more complex function.
jreinhardt
Postby jreinhardt » Tue Sep 24, 2013 8:49 am
I incorporated both of these functions into BOLTS, using dimension data from http://medias.schaeffler.de/medias/de!hp/ (The SKF page suggested by mario was less convenient to copy-paste the hundreds of rows). This worked as planned, but the current graphical interface is not very well suited to choose from the 300 different kinds of needle bearings that it now knows about. (And now it is perfectly clear to me why Javier wants to have a search feature). So I will have to think about that.
Greetings
Johannes
BOLTS, standard parts library for FreeCAD Thread, Help with Translation
javiermg
Postby javiermg » Tue Sep 24, 2013 7:42 pm
Hi all.
I want to ask two things which are slowing down my work. I have not found them anywhere (nothing that I am able to understand, at least)
First, I am working at more complex bearings which need from creating sketches. I have managed to arrange lines and create a wire object easily, but now I need to revolve it in order to cut a solid, and I am facing a wall.
This is the wire I am trying to revolve and convert into a solid (to cut "our" with it)
import Part
import math
from FreeCAD import Base
rout=100
rin=50
bth=50
RR=1
cbr=0.25*bth
#outer rin-----------
our1=Part.makeCylinder(rout,bth)
our2=Part.makeCylinder(rin,bth)
our=our1.cut(our2)
oure=our.Edges
our.makeFillet(RR,oure)
#Points:
bt2=bth/2.00
roin=rout-rin
A=Base.Vector(rout+0.1*rout, 0, bt2+bt2*0.15)
B=Base.Vector(rout-roin*0.2, 0, bt2+bt2*0.15)
C=Base.Vector(rout-roin*0.2, 0, bt2+cbr)
D=Base.Vector(rin+roin*0.2, 0, bt2+bt2*0.15)
E=Base.Vector(rin-0.1*rin, 0, bt2+bt2*0.15)
F=Base.Vector(rin-0.1*rin, 0, bt2-bt2*0.15)
G=Base.Vector(rin+roin*0.2, 0, bt2-bt2*0.15)
H=Base.Vector(rout-roin*0.2, 0, bt2-cbr)
I=Base.Vector(rout-roin*0.2, 0, bt2-bt2*0.15)
J=Base.Vector(rout+0.1*rout, 0, bt2-bt2*0.15)
#Lines
LA=Part.Line(A,B)
LB=Part.Line(B,C)
LC=Part.Line(C,D)
LD=Part.Line(D,E)
LE=Part.Line(E,F)
LF=Part.Line(F,G)
LG=Part.Line(G,H)
LH=Part.Line(H,I)
LI=Part.Line(I,J)
LJ=Part.Line(J,A)
CV=Part.Shape([LA,LB,LC,LD,LE,LF,LG,LH,LI,LJ])
CV=Part.Wire(CV.Edges)
RV=(0,0,1)
CV.revolve(RV,360)
Part.show(CV)
The command "CV.revolve(RV,360)" only gives errors and errors not matter what I try or in which order. Also I have not found any documentation of it.
Anyone knows how to revolve a wire and cut it to a solid? Is just impossible?
The second question is less important, but will complete the bearing script:
Is there any way to modify by command the color/material of a shape?
Thank you!! :)
