0.19: Why is there a ID in document object?
ickby
Postby ickby » Tue Apr 28, 2020 2:28 pm
I port some custom code from 0.18 to 0.19 rigth know, and detected a difference in the DocumentObject. There is a new ID field in Document Object. Why is that? Did we not have name as a unique identifier?
I'm also interested for what it is used, to see if I need to handle it somehow in my code.
Site Admin
Re: 0.19: Why is there a ID in document object?
Postby wmayer » Tue Apr 28, 2020 3:14 pm
See git commit ff1d1cd3414360e
* getID(), return object internal identifier. Each object is now
assigned an integer identifier that is unique within its containing
document.
* getObjectByID(), get object by its identifier
From the commit message it's not very clear why this has been added but I think it's to speed up the search for an object. Searching an object by string is much more time intensive than by an integer.
It's mainly for internal use so you probably won't have to handle it in your code.
ickby
Postby ickby » Tue Apr 28, 2020 4:44 pm
thanks for the infos.
I'm a bit worried, as this ID gets saved in the document file. Hence it seems to be important that the exact number stays the same over file reloads. Maybe it is used somewhere as reference to objects, maybe the links?
I'm asking as my code duplicates objects to exact and interchangeable copies. Right now in 0.19 that is not possible, the ID will be different. If this is a transient number only used for some searches that's fine, it can be different However, if someone stores the id as kind of reference to a certain object my code fails.
I will try to search the code a bit more.
Site Admin
Postby wmayer » Tue Apr 28, 2020 5:08 pm
So far I have found two places where the id is used. It's in the tree view and for the links. For the former a transient behaviour might be OK but I guess for the latter it's not.
vocx
Postby vocx » Tue Apr 28, 2020 5:40 pm
realthunder wrote: ping
realthunder
Postby realthunder » Tue Apr 28, 2020 11:00 pm
The object ID has an important role in my TopoNaming algorithm. The ID is expected to be persistent and unique within the same document.
ickby
Postby ickby » Wed Apr 29, 2020 4:31 am
ok, thanks for the info. That means a object has two unique and persistent identifiers, Name and ID, one string and one int. For my code I need to make exact copies of objects, however, ID cannot be chosen the same way Name can, it is dependent on creation order. I see two solutions:
1. Make ID accessible to the user via the "addObject" function as optional parameter
2. Make the ID dependent on Name: ID == hash(Name)
Option 2 seems for me the most sensible. This would also allow to remove it from the file again and make it fully compatible to 0.18. From what I have seen now this does not affect the purpose of ID in any way.
@realthunder what do you think is the best option?
realthunder
Postby realthunder » Wed Apr 29, 2020 4:48 am
But there is no guarantee of uniqueness in hash. The same goes for option 1, because the ID may have been taken. Can you please explain first what's the intended use of the "exact copy". How are you going to deal with the duplication of name? Are you copying the object into a new document?
ickby
Postby ickby » Wed Apr 29, 2020 5:04 am
I'm aware that neither of those methods is perfect. However, this is a significant change to 0.18 behavior and we need to deal with it somehow.
probability of same hash for different names is "1.0/std::numeric_limits<size_t>::max()" with std::hash, so pretty close to a guarantee.
The same goes for option 1, because the ID may have been taken.".
But than addObject can easily fail with an error.
Yes, i rebuild part of a document in a new one. For that all links and references need to still work. As I not entirely sure how ID is to be used in either your code or any python code out there I need to duplicate it.
realthunder
Postby realthunder » Wed Apr 29, 2020 5:19 am
Forgot to mention, there is another requirement of ID, that it cannot be reused (within the same document), unlike Name. Because the ID will be used for tracing back model history. If a historical object is deleted, the tracing can continue to the previous step. If the ID can be reused, then the trace may be trapped to the wrong object.
I don't think ID will cause any problem for copying. BTW, maybe you can try the Document.copyObject() API. I have made many changes to make sure the copied object continues to work with all the dependencies, in various use case, like copy objects from multiple documents, copy into the same document, etc. Also with App::Link, it is possible to copy to another document without dependency. It takes quite some effort to make sure everything works, such as expression, spreadsheet, and the need to recompute topo names, etc. There is also the moveObject() API in case you want to move.
