Setup to debug OCCT
abdullah
Setup to debug OCCT
Post by abdullah »
Hi folks!
There is probably nothing special in what I am going to write here, but I think it may make sense to share it with you.
Since quite a while I wanted to be able to debug FreeCAD with a debug version of OpenCascade, so that I could investigate OpenCascade bugs. Finally today I have gone for it.
Opencascade GIT
It is possible to publicly clone the Opencascade git like this:
git clone https://git.dev.opencascade.org/repos/occt.git
There are instructions to build Opencascade here:
https://www.opencascade.com/doc/occt-6. ... cmake.html
The advise of using 3 directories, one for sources, one for build and a third one for installation is very useful. This allows to have the installation on a local folder and to not interfere with system libraries.
I have used ccmake as they recommend to configure the build options. I used Kurt's balsa settings as reference:
https://salsa.debian.org/science-team/o ... bian/rules
But setting the build type to Debug and my INSTALL_DIR to /mylocalfolder/usr.
After make and make install, you are set to configure FreeCAD to use this library.
Building FreeCAD
I build FreeCAD out of tree, so I use this:
cmake -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DCMAKE_BUILD_TYPE=Debug -DOCC_INCLUDE_DIR=/mylocalfolder/usr/include/opencascade ../free-cad-code
I was having problems that cmake wanted to use my OCCT build directory instead of the install directory even with the commands above, because it was finding the .cmake files of the build directory instead of the ones from the install directory. The only solution I could find was to delete the cmake files in the OCCT build directory.
N.B: Make sure you use a current version of master, as OCCT has introduced a change to a function in current master and Werner just pushed a fix for this today (I could have avoided having to do it myself if I waited just some hours...)
Running FreeCAD
Now you have a locally built FreeCAD compiled against your locally built OCCT, but when you run it, it will take your system OCCT library (and it will eventually crash). To avoid this, you can use:
env LD_LIBRARY_PATH=/mylocalfolder/usr/lib ./FreeCAD
I use kdevelop and have created an environment for launch which sets this variable.
Now you can start debugging FreeCAD and it will jump to OCCT code, which you could fix, recompile OCCT, recompile FreeCAD,...
Example
Today I was looking at this:
https://tracker.freecadweb.org/view.php?id=4129
And I ended up filing a report and a possible patch with them to solve a crash:
https://tracker.dev.opencascade.org/view.php?id=31585
As I was saying, nothing special, just trying to show it is actually easier than it looks.
Re: Setup to debug OCCT
Post by Kunda1 »
Great! I'll add a section on Debugging OCC/OCCT to the Debugging page.
Edit:
Debugging#Debugging_OpenCasCade
Founder
Post by wmayer »
abdullah wrote: Sat May 30, 2020 2:39 pm Now you have a locally built FreeCAD compiled against your locally built OCCT, but when you run it, it will take your system OCCT library (and it will eventually crash). To avoid this, you can use:
I wonder why this happens. On my old Linux box I once locally built OCC 7.3 and a FreeCAD version that links this OCC version. I could start the application without dealing with LD_LIBRARY_PATH.
For example open the link.txt file for Part.so of the build directory. There you should be able to find the content "-rpath" followed by a list of paths which should include the path of your OCC installation.
If the path is listed then ldd Part.so should be able to locate the OCC libraries. To get the embedded paths you can do:
objdump -p Part.so | grep RUNPATH
For more details see:
https://www.man7.org/training/download/ ... slides.pdf
https://gitlab.kitware.com/cmake/commun ... H-handling
https://software.intel.com/sites/defaul ... ohowto.pdf (page 40)
abdullah
Post by abdullah »
wmayer wrote: Sat May 30, 2020 6:17 pm I wonder why this happens. On my old Linux box I once locally built OCC 7.3 and a FreeCAD version that links this OCC version. I could start the application without dealing with LD_LIBRARY_PATH.
FreeCAD starts without the env variable. But it crashes for example when loading a file due to an undefined symbol:
FreeCAD 0.19, Libs: 0.19R21328 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
libpng warning: iCCP: known incorrect sRGB profile
connect failed: No existe el archivo o el directorio
Cannot create object 'Body': (/usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7: undefined symbol: _ZN19Geom_BSplineSurface15CheckAndSegmentEdddd)
The path is indeed there:
RUNPATH              /usr/lib/x86_64-linux-gnu/hdf5/openmpi:/usr/lib/openmpi/lib:/usr/lib/x86_64-linux-gnu/openmpi/lib:/mylocalfolder/usr/lib:/home/abdullah/github/freecad-build/lib:
Using the dynamic linker output on FreeCAD executable (LD_DEBUG, see last slide of your first link), this is the library search:
Part.so
      3338:     find library=Part.so [0]; searching
      3338:      search path=/usr/lib/x86_64-linux-gnu/hdf5/openmpi:/usr/lib/x86_64-linux-gnu/openmpi/lib:/mylocalfolder/usr/lib:/home/abdullah/github/freecad-build/Mod/Part/tls/haswell/x86_64:/home/abdullah/github/freecad-buil
d/Mod/Part/tls/haswell:/home/abdullah/github/freecad-build/Mod/Part/tls/x86_64:/home/abdullah/github/freecad-build/Mod/Part/tls:/home/abdullah/github/freecad-build/Mod/Part/haswell/x86_64:/home/abdullah/github/freecad-build/Mod
/Part/haswell:/home/abdullah/github/freecad-build/Mod/Part/x86_64:/home/abdullah/github/freecad-build/Mod/Part:/home/abdullah/github/freecad-build/lib:tls/haswell/x86_64:tls/haswell:tls/x86_64:tls:haswell/x86_64:haswell:x86
_64:           (RUNPATH from file ./FreeCAD)
      3338:       trying file=/usr/lib/x86_64-linux-gnu/hdf5/openmpi/Part.so
      3338:       trying file=/usr/lib/x86_64-linux-gnu/openmpi/lib/Part.so
      3338:       trying file=/mylocalfolder/usr/lib/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/tls/haswell/x86_64/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/tls/haswell/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/tls/x86_64/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/tls/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/haswell/x86_64/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/haswell/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/x86_64/Part.so
      3338:       trying file=/home/abdullah/github/freecad-build/Mod/Part/Part.so
libTKGeomBase.so (the one creating the segmentation fault above):
      3338:     find library=libTKGeomBase.so.7 [0]; searching
      3338:      search cache=/etc/ld.so.cache
      3338:       trying file=/usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7
libTKMesh.so
      3338:     find library=libTKMesh.so.7 [0]; searching
      3338:      search path=/usr/lib/x86_64-linux-gnu/hdf5/openmpi:/usr/lib/x86_64-linux-gnu/openmpi/lib:/mylocalfolder/usr/lib:/home/abdullah/github/freecad-build/lib:tls/haswell/x86_64:tls/haswell:tls/x86_64:tls:haswell/x86_64:haswell:x86_64:               (RUNPATH from file ./FreeCAD)
      3338:       trying file=/usr/lib/x86_64-linux-gnu/hdf5/openmpi/libTKMesh.so.7
      3338:       trying file=/usr/lib/x86_64-linux-gnu/openmpi/lib/libTKMesh.so.7
      3338:       trying file=/mylocalfolder/usr/lib/libTKMesh.so.7
In the case of libTKGeomBase.so, it appears to be found on the ld.so.cache, which appears to have lower priority than RUNPATH:
https://www.man7.org/linux/man-pages/man8/ld.so.8.html
This however does not happen for (for example) libTKMesh.so, in which the RUNPATH order is followed and the library found in the right directory.
Founder
Post by wmayer »
IIRC the system wide OCC on my old Linux box was 6.x and because the major version is added to the linking library name it didn't pick up the system version.
Now in your case both of your OCC versions are 7.x. I wonder whether there is a way that also the minor version number can be added to the linking library.
Founder
Post by wmayer »
abdullah wrote: Sun May 31, 2020 4:56 am ping
You may try to change the soname of the shared libraries of OCC. When you call
objdump -p libTKGeomBase.so | grep SONAME
you will get libTKGeomBase.so.7, i.e. it only includes the major version number.
Now you can try to also include the minor version number. Then I hope FreeCAD will find them without using LD_LIBRARY_PATH. Therefore open the file occt_toolkit.cmake and replace the line
SOVERSION     "${OCC_VERSION_MAJOR}"
with
SOVERSION     "${OCC_VERSION_MAJOR}.${OCC_VERSION_MINOR}"
Now rebuild OCC and FreeCAD.
abdullah
Post by abdullah »
wmayer wrote: Tue Jun 02, 2020 7:05 pm Now rebuild OCC and FreeCAD.
Something very interesting happens. The library is not found:
libTKGeomBase
     32198:     find library=libTKGeomBase.so.7.4 [0]; searching
     32198:      search cache=/etc/ld.so.cache
     32198:      search path=/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/lib:/usr/lib              (system search path)
     32198:       trying file=/lib/x86_64-linux-gnu/libTKGeomBase.so.7.4
     32198:       trying file=/usr/lib/x86_64-linux-gnu/libTKGeomBase.so.7.4
     32198:       trying file=/lib/libTKGeomBase.so.7.4
     32198:       trying file=/usr/lib/libTKGeomBase.so.7.4
     32198:
Cannot create object 'Body': (libTKGeomBase.so.7.4: cannot open shared object file: No such file or directory)
However, other OCCT libraries are indeed found:
libTKernel
     32198:     find library=libTKernel.so.7.4 [0]; searching
     32198:      search path=/usr/lib/x86_64-linux-gnu/hdf5/openmpi:/usr/lib/x86_64-linux-gnu/openmpi/lib:/mylocalfolder/usr/lib:/home/abdullah/github/freecad-build/Mod/Part:/home/abdullah/github/freecad-build/lib:tls/haswell/x86_64:tls/haswell:tls/x86_64:tls:haswell/x86_64:haswell:x86_64:              (RUNPATH from file ./FreeCAD)
     32198:       trying file=/usr/lib/x86_64-linux-gnu/hdf5/openmpi/libTKernel.so.7.4
     32198:       trying file=/usr/lib/x86_64-linux-gnu/openmpi/lib/libTKernel.so.7.4
     32198:       trying file=/mylocalfolder/usr/lib/libTKernel.so.7.4
It is like if the path that I pass to FreeCAD when building is taken into account for searching some OCCT libraries but not others...
Founder
Post by wmayer »
Hmm, that's bad. I don't know if there is any other way than copying the shared libraries to one of the standard search directories.
In the meantime I have built occ from git with the above change. When I do
ldd libTKGeomBase.so
for the installed libraries it doesn't find the dependencies even if looking from the same directory. However, when doing so from within the build directory it finds the dependencies. With objdump you can see that RUNPATH is set for the shared libraries in the build directory but removed for the installed files.
sgrogan
Post by sgrogan »
Maybe the problem begins in CMake?
https://github.com/FreeCAD/FreeCAD/blob ... Cade.cmake Is heavily tuned for FreeCAD, specifying only the include directory may not find/link a consistent solution.
OCC_DIR should point to the directory containing OpenCASCADEConfig.cmake in the locally installed OCC.
A quick look on windows I can only find OCE_DIR, in my case NOT-FOUND
There is also FREECAD_USE_OCC_VARIANT, in my case Community Edition (I'm using official OCCT)
I also found OCCT_CMAKE_FALLBACK, in my case unchecked
And I found it, OpenCASCADE_DIR points to the directory containing OpenCASCADEConfig.cmake, in my case C:/Libpacks/FreeCADLibs_12.1.6_x64_VC15/cmake
"fight the good fight"
Founder
Post by wmayer »
This is a workaround how I got it working:
  1. From the installation directory copy the folder "cmake" to the build directory underneath lin64/gcc/lib
  2. Copy the folder include to the build directory underneath lin64/gcc
  3. When configuring FreeCAD select for OpenCASCADE_DIR lin64/gcc/lib/cmake underneath the OCC build directory
The point is that the RUNPATH section is added to the shared OCC libraries in the build directory but get removed after installing them.
