add App::PropertyQuatity per Python
bernd
Post by bernd »
from FreeCAD import Units
from femobjects import base_fempythonobject
class MyNewObject(base_fempythonobject.BaseFemPythonObject):
    Type = "Fem::MyNewObject"
    def __init__(self, obj):
        super(MyNewObject, self).__init__(obj)
        obj.addProperty(
            "App::PropertyQuantity",
            "MyNewProperty",
            "MyPropertyGroup",
            "Set my new PropertyQuantity"
newobj = App.ActiveDocument.addObject("Fem::ConstraintPython", "FunnyObject")
MyNewObject(newobj)
newobj.MyNewProperty = Units.Quantity("1 s^4*A^2 / (m^3*kg)")
newobj.MyNewProperty = Units.Quantity("1 mm")
...     Type = "Fem::MyNewObject"
...     def __init__(self, obj):
...         super(MyNewObject, self).__init__(obj)
...         obj.addProperty(
...             "App::PropertyQuantity",
...             "MyNewProperty",
...             "MyPropertyGroup",
...             "Set my new PropertyQuantity"
>>> MyNewObject(newobj)
<__main__.MyNewObject object at 0x7f6e3d351b70>
ArithmeticError: Not matching Unit!
I am not able to assign any value to the App.PropertyQuantity
vocx
Re: add App::PropertyQuatity per Python
Post by vocx »
bernd wrote: Wed Jun 24, 2020 8:03 pm "App::PropertyQuantity",
Is PropertyQuantity used by itself at all?
Maybe it's just subclassed and used in PropertyLength, PropertyArea, PropertyVolume, etc.
https://github.com/FreeCAD/FreeCAD/blob ... its.h#L121
https://github.com/FreeCAD/FreeCAD/blob ... its.h#L145
https://github.com/FreeCAD/FreeCAD/blob ... its.h#L157
https://github.com/FreeCAD/FreeCAD/blob ... its.h#L169
bernd
Post by bernd »
Ahh that would mean the correct way to do it would be adding this to FreeCAD App ...
https://github.com/berndhahnebach/FreeC ... 00ca933966 and use it this way ...
        obj.addProperty(
            "App::PropertyVacuumPermittivity",
            "MyNewProperty",
            "MyPropertyGroup",
MyNewObject(newobj)
newobj.MyNewProperty = Units.Quantity("1 s^4*A^2 / (m^3*kg)")  # ok
newobj.MyNewProperty = Units.Quantity("1 mm")  # error
Founder
Post by wmayer »
PropertyQuantity is a generic quantity property and it handles arbitrary units. However, you are not allowed to change the unit by assigning a quantity with a different unit. This is to avoid to unintentionally change the unit.
To change it you must do:
newobj.MyNewProperty = Units.Length
Afterwards you can assign
bernd
Post by bernd »
wmayer wrote: Thu Jun 25, 2020 6:29 am PropertyQuantity is a generic quantity property and it handles arbitrary units. However, you are not allowed to change the unit by assigning a quantity with a different unit. This is to avoid to unintentionally change the unit.
Aha, thus the following works before a unit is assigned.
Units.Unit(newobj.MyNewProperty)
newobj.MyNewProperty = Units.Quantity("1")
newobj.MyNewProperty = Units.Quantity(2)
newobj.MyNewProperty = 3
newobj.MyNewProperty = "4"
Unit:  (0,0,0,0,0,0,0,0)
bernd
Post by bernd »
for the sake of completeness
        obj.addProperty(
            "MyNewProperty",
            "MyPropertyGroup",
        obj.MyNewProperty = Units.VacuumPermittivity
MyNewObject(newobj)
...         obj.MyNewProperty = Units.VacuumPermittivity
>>> MyNewObject(newobj)
<__main__.MyNewObject object at 0x0000023CC146B6A0>
1e-09 s^4*A^2/(mm^3*kg)
vocx
Post by vocx »
Should every Unit have an App::Property?
I raised this question in the past. It seems every unit should have its own property type. Otherwise, the use of App::PropertyQuantity should be more documented, like Werner explains in this thread.
bernd
Post by bernd »
I was asking myself the same question today.
I will implement the property for vacuum permittivity. IMHO the generic property quantity.should be used if one can not just change source and compile FreeCAD. Might be because one has to stay with stable release version or one is just not able to compile, or whatever.
josegegas
Post by josegegas »
Hello.
When I use the code above to create a scripted object:
        obj.addProperty(
            "MyNewProperty",
            "MyPropertyGroup",
MyNewObject(newobj)
It works fine, it creates the object with a property of the adequate units:
FreeCAD.getDocument('Cubo').getObject('FunnyObject').MyNewProperty.Unit
returns:
Unit: s^4*A^2/(mm^3*kg) (-3,-1,4,2,0,0,0,0) [VacuumPermittivity]
However when I save the file, close and open it again, the units of "MyNewProperty" are gone. After opening the document again MyNewProperty has no units:
returns:
I am using FreeCAD 0.20 version 26155.
I would appreciate any ideas...
Thanks in advance.
josegegas
Post by josegegas »
Here is the relevant part of my code:
import FreeCAD
class Rigidbody:
        obj.addProperty("App::PropertyQuantity",
                        "absolute_angular_velocity_X",
                        "Initial conditions: absolute angular velocity [deg/s]",
                        "X component of the absolute initial angular velocity").absolute_angular_velocity_X = 10.0
        obj.absolute_angular_velocity_X = FreeCAD.Units.Unit('deg/s')
a = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","MyObject")
Rigidbody(a)
This works perfectly, except that when the FreeCAD document is saved, closed and open again, the units of the "absolute_angular_velocity_X" property have disappeared.
Any ideas why?
