lambda
Posts: 91 Joined: Sat Feb 25, 2017 3:10 pm
Post
by lambda » Tue Jul 21, 2020 12:24 pm
Hi!
I'm trying to cut a face with a solid, but the result is not what I expect: It extends outside the original face. See the attached file.
Since there is a warning about boolean operations on faces, I also tried extruding it first. However this even throws an exception:
14:14:28 <Exception> Intersection failed
14:14:28 90.9013 <App> Document.cpp(3746): Failed to recompute testFuse#Common: Intersection failed
14:14:28 Recompute failed! Please check report view.
Is this a bug in OCC or FreeCAD? Is it already known? Are there any workarounds?
TIA,
Harald
boolean_common_bug.FCStd
(16.12 KiB) Downloaded 34 times
lambda on Tue Jul 21, 2020 10:58 pm, edited 1 time in total.
vocx
Posts: 5197 Joined: Thu Oct 18, 2018 9:18 pm
Post
by vocx » Tue Jul 21, 2020 2:56 pm
lambda wrote: ↑ Tue Jul 21, 2020 12:24 pm
Hi!
Your file shows the a
Part Common operation, not a
Part Cut . However, with
Part Cut I also get a strange result.
Original Plane_cut_1.png (8.19 KiB) Viewed 812 times
Cut Plane_cut_2.png (8.07 KiB) Viewed 812 times
Common (intersection) Plane_cut_3.png (6.5 KiB) Viewed 812 times
The OCCT version is important. I'm still in 7.3, but the
AppImage and others already use 7.4. Some people have noted a few regressions from 7.3 to 7.4 as well.
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22104 (Git)
Hash: d30e4a508865b02d1545e694dff659e4f8f40a94
Python version: 3.6.9
Qt version: 5.9.5
lambda
Post
by lambda » Tue Jul 21, 2020 5:03 pm
Yes, it seems general fuse gets confused and everything, that relies on it.
I'm sorry, I forgot the version information:
OS: Debian GNU/Linux bullseye/sid
Version: 0.19.22040 (Git)
Build type: Unknown
Branch: rt-FixTransactionDynamicProp
Hash: a8540c962015e3938e0d908eeacece15675a4f40
Python version: 3.8.4
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: German/Austria (de_AT)
Chris_G
Posts: 2602 Joined: Tue Dec 31, 2013 4:10 pm
Post
by Chris_G » Tue Jul 21, 2020 5:26 pm
I don't think there is any bug in the boolean operation.
I think you obtained your "Test" object by a replaceShape() operation, that lead to an unreasonable tolerance :
o2.Shape.getTolerance(1)
#>>>240.00002400000002
Here is a view of the real geometries :
Obtained with :
doc1 = FreeCAD.getDocument('boolean_common_bug')
o1 = doc1.getObject('Gel__nde_001_body')
o2 = doc1.getObject('Test')
def geometric_wireframe(sh):
edges = []
for e in sh.Edges:
edges.append(e.Curve.toShape(e.FirstParameter, e.LastParameter))
return Part.Compound(edges)
Part.show(geometric_wireframe(o1.Shape))
Part.show(geometric_wireframe(o2.Shape))
lambda
Post
by lambda » Tue Jul 21, 2020 11:00 pm
Chris_G wrote: ↑ Tue Jul 21, 2020 5:26 pm
Indeed.
Improving replaceShape() usage as described in
https://forum.freecadweb.org/viewtopic.php?f=10&t=48660 fixed the problem with boolean operations.
