[0220/082008.002295:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources_100p.pak
Some features may not be available.
[0220/082008.002324:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources_200p.pak
[0220/082008.002336:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources.pak
[0220/082008.003321:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for locale
[64763:64763:0220/082008.096260:ERROR:extension_system_qt.cpp(121)] Failed to parse extension manifest.
#0 /lib/libc.so.6(+0x3cf80) [0x7fe666de0f80]
#1 /lib/libQt5WebEngineCore.so.5(+0x2996760) [0x7fe62d0b5760]
#1 /lib/libQt5WebEngineCore.so.5(+0x2c68b82) [0x7fe62d387b82]
corrupted double-linked list
Segmentation fault (core dumped)
It looks like a Qt5WebEngine installation problem, but it is hard to guess as you are running a custom FreeCAD version. Note that Qt5WebEngine is a Qt plugin (not part of the core).
I hope this will not be a problem with official FreeCAD versions.
mnesarco wrote: ↑Sat Feb 20, 2021 2:32 pm
I know nothing about AUR packages, but qt-webkit is deprecated and it is different from qt-webenginecore. Anyway I have just commited a fix to the double init problem and also fixed another non-related bug, I don't think that affects your case, but please do update to be sure that we are talking about the same version.
mnesarco wrote: ↑Sat Feb 20, 2021 4:09 pm
11:25:00 [ExtMan] ExtMan Initialized
11:25:01 [ExtMan] Path does not exists: /home/foo/.FreeCAD/Mod/FreeCAD_ExtMan/freecad/extman/resources/html/img/package_macro.svg
11:25:01 [ExtMan] Path does not exists: /home/foo/.FreeCAD/Mod/FreeCAD_ExtMan/freecad/extman/resources/html/img/workbench.svg
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.24054 (Git) AppImage
Hash: ed873038025277f220dfaa058599a0dfbb435835
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
This one is very weird because the files are actually there:
The path is not hardcoded. So probably the problem is because there are some old cached files. If you change the folder name, you must delete the cache folder:
mnesarco wrote: ↑Sat Feb 20, 2021 5:34 pm
$HOME/.FreeCAD/ExtManCache
If a user removes ExtMan via the Addon manager, do these cache files get removed as well ?
