Thank you for the report. I will check.
Extension Manager (ExtMan)
Re: Extension Manager
I tried to reproduce the issue in my environment without success, I need to do more tests.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.21125 (Git) AppImage
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
I get this errors in terminal and FreeCAD report view after installing extman from github.
Some UX feedback:
The first thing I tried to do was to do was search for a workbench I wanted to download, but it wasn't found. You have to click Cloud > Addons and then search for the addon. If possible, it would be better if there's only one search that could show both installed and available cloud addons.
When looking at the Workbench list, you have to click the small blue readme text. Could clicking the Workbench/Macro name also bring up the same readme?
watsug@kebab:~/Documents/freeCAD/freecad-build/bin$ ./FreeCAD
FreeCAD 0.19, Libs: 0.19R23961 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Tried to run Gui::Application::initApplication() twice!
<string>:410: DeprecationWarning: an integer is required (got type PySide2.QtCore.Qt.WindowFlags). Implicit conversion to integers using __int__ is deprecated, and may be removed in a future version of Python.
<string>:410: DeprecationWarning: an integer is required (got type PySide2.QtCore.Qt.WindowType). Implicit conversion to integers using __int__ is deprecated, and may be removed in a future version of Python.
During initialization the error "No module named 'git'" occurred in freecad.extman
File "<string>", line 156, in InitApplications
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/watsug/.FreeCAD/Mod/ExtMan/freecad/extman/init_gui.py", line 26, in <module>
from freecad.extman.gui.browser import install_router, start_browser
File "/home/watsug/.FreeCAD/Mod/ExtMan/freecad/extman/gui/browser.py", line 25, in <module>
from freecad.extman.gui.controller import actions, message_handlers
File "/home/watsug/.FreeCAD/Mod/ExtMan/freecad/extman/gui/controller.py", line 22, in <module>
from freecad.extman.sources.source_installed import InstalledPackageSource
File "/home/watsug/.FreeCAD/Mod/ExtMan/freecad/extman/sources/source_installed.py", line 25, in <module>
from git.objects import base
ModuleNotFoundError: No module named 'git'
connect failed: No such file or directory
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.23961 (Git)
Build type: Unknown
Hash: 3e2780a5117fb7a5d9c1ce9ed663ce34e6decd9e
Python version: 3.8.5
Qt version: 5.12.8
Fixed in master: https://github.com/mnesarco/FreeCAD_ExtMan
I still get this error line with removed and recloned from git.mnesarco wrote: ↑Tue Feb 09, 2021 1:37 pm Fixed in master: https://github.com/mnesarco/FreeCAD_ExtMan
This is not ExtMan specific as I get this also without ExtMan installed. I don't know which is the source of that warning.watsug wrote: ↑Thu Feb 11, 2021 4:18 pm I still get this error line with removed and recloned from git.Code: Select all
For me it disappears if I remove the ExtMan folder from .FreeCAD/Modmnesarco wrote: ↑Thu Feb 11, 2021 4:32 pmThis is not ExtMan specific as I get this also without ExtMan installed. I don't know which is the source of that warning.watsug wrote: ↑Thu Feb 11, 2021 4:18 pm I still get this error line with removed and recloned from git.Code: Select all
I get a crash when invoking ExtMan from
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.23882 (Git)
Hash: bead9bb9381d039d6dda438b07e30dace7cf33ae
Python version: 3.9.1
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
PS I know it's an now old compiled version of FC. I'm waiting for a good time to compile from source again (it's strenuous on my poor laptop)
This crash may not be an issue on the latest bleeding edge v0.19_pre
Edit: I'm running the most up to date version of ExtMan
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
[0220/082008.002295:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources_100p.pak
Some features may not be available.
[0220/082008.002324:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources_200p.pak
[0220/082008.002336:ERROR:resource_bundle.cc(932)] Failed to load /home/foo/.FreeCAD/qtwebengine_resources.pak
[0220/082008.003321:WARNING:resource_bundle_qt.cpp(115)] locale_file_path.empty() for locale
[64763:64763:0220/082008.096260:ERROR:extension_system_qt.cpp(121)] Failed to parse extension manifest.
#0 /lib/libc.so.6(+0x3cf80) [0x7fe666de0f80]
#1 /lib/libQt5WebEngineCore.so.5(+0x2996760) [0x7fe62d0b5760]
#1 /lib/libQt5WebEngineCore.so.5(+0x2c68b82) [0x7fe62d387b82]
corrupted double-linked list
Segmentation fault (core dumped)
