[Fixed] Regression : Intersect do not accept plane as argument
Cyril
Postby Cyril » Mon Sep 28, 2020 9:59 am
There is apparently a regression with intersect. It does not accept anymore a plane as argument :
  • Using my build on commit 2a510a23b480a24bac424383a663200e2c293f10 doesn't work
    >>> pl1 = Part.Plane()
    >>> pl2 = Part.Plane(FreeCAD.Vector(0, 0, 0), FreeCAD.Vector(1, 0, 0))
    >>> pl1.intersect(pl2)
    TypeError: argument 1 must be Part.Curve, not Part.Plane
  • Using my build on commit f09d48d0fe00590997b88b52b610210ac606951c works :
    >>> pl1 = Part.Plane()
    >>> pl1.intersect(pl2)
    [<Line object>]
Raw code to reproduce :
pl1 = Part.Plane()
pl1.intersect(pl2)
Edit : intersectSS which is specialized for this case also return an error :
>>> pl1.intersectSS(pl2)
SystemError: Objects/listobject.c:353: bad argument to internal function
OS: Manjaro Linux (GNOME/gnome-xorg)
Version: 0.19 (Git)
Hash: see above
Python version: 3.8.5
Qt version: 5.15.0
OCC version: 7.4.0
Locale: C/Default (C)
Reason: Added [Fixed] to thread title
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
Cyril
Re: Regression : Intersect do not accept plane as argument
Postby Cyril » Fri Oct 09, 2020 3:07 pm
Anyone can confirm so I can open an issue on bug tracker ?
Postby Kunda1 » Fri Oct 09, 2020 3:30 pm
<off topic> I would love it if there was an option to copy/paste from code snippets but automagically edit out the preceding >>> so I can easily paste in to Python console
Can anyone tweak phpbb to do that?
</off topic>
Postby Kunda1 » Fri Oct 09, 2020 3:34 pm
Can reproduce on
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.22665 (Git) AppImage
Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99
Python version: 3.8.6
Qt version: 5.12.9
OCC version: 7.4.0
Here is the output:
>>> pl1 = Part.Plane()
>>> pl1.intersect(pl2)
Edit:
Also breaks with intersectSS()
>>> pl1 = Part.Plane()
SystemError: /home/conda/feedstock_root/build_artifacts/python-split_1602094424782/work/Objects/listobject.c:353: bad argument to internal function
vocx
Postby vocx » Fri Oct 09, 2020 6:05 pm
[*] Using my build on commit 2a510a23b480a24bac424383a663200e2c293f10 doesn't work
[*] Using my build on commit f09d48d0fe00590997b88b52b610210ac606951c works :
This is a month of difference.
* git commit 2a510a23b4, 2020 September 28
* git commit f09d48d0fe, 2020 August 26
A lot of commits were made in that period which could be responsible. It would be good if you tried narrowing down the issue.
I can confirm as well with 0.19.22668.
Postby Kunda1 » Fri Oct 09, 2020 6:18 pm
Mod edit: Moved to Developer Corder
Cyril
Postby Cyril » Fri Oct 09, 2020 7:41 pm
</off topic>
This is why I added a raw code to reproduce section :lol:
I know there is a long period between these commits I compiled before my holidays then when I came back I compiled once see the issue and waited for while to make sure it was not a temporary issue.
I tried to investigate myself in the C++ code but git blame shows that there was no change in intersect / intersectSS for years. I really don't know from where this issue come from and I don't know how to perform a step by step debug with C++ code.
I did not understand why you moved the post. It is an issue in Part. I thought Part Design sub-forum was the right place to post.
Thank you all for your confirmations.
Postby Kunda1 » Fri Oct 09, 2020 8:07 pm
Because we want wmayer to see it.
Cyril
Postby Cyril » Fri Oct 09, 2020 8:34 pm
vocx
Postby vocx » Fri Oct 09, 2020 8:41 pm
Intersect is a method of the Part TopoShape class, so the change may not be in the method itself, but somewhere in the TopoShape pipeline. You can see Werner made tons of changes to Part in that period, maybe something isn't passed to the internal classes as it was done before.
You can browse all commits before this one, and see if there is something interesting in the Part module. Compile a few versions and see if you can narrow it down.
https://github.com/FreeCAD/FreeCAD/commits/2a510a23b4
