Ticket #4500 - segfault on focus change
mlampert
Postby mlampert » Tue Nov 17, 2020 8:15 pm
I have a task panel where I can deterministically generate a segfault by changing the focus from one a QLineEdit widget to a GUI::QuantitySpinBox. The only "non-standard" thing is that the quantity spin boxes are created programmatically with FreeCADGui.UiLoader.createWidget('Gui::QuantitySpinBox') - no idea if this is the root cause though.
When editing a ToolBit ("Endmill" in attached file) - and one first clicks into the "Shape File" entry field, and then into the "Cutting Edge Height" field, FC segfaults. The code that generates the dialog is here: https://github.com/FreeCAD/FreeCAD/blob ... dit.py#L62
If anybody has an idea what would be causing such a behaviour, and what to do about it - much appreciated!
box.FCStd
(16.49 KiB) Downloaded 12 times
Reason: Added ticket number to thread title
Re: segfault on focus change
Postby chrisb » Tue Nov 17, 2020 8:59 pm
I cannot help, but I can confirm.
OS: macOS 10.15
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
sliptonic
Postby sliptonic » Thu Nov 19, 2020 9:58 pm
100% reproducible for me too.
OS: Linux Mint 19.3 (i3/i3)
Version: 0.19.23029 +16 (Git)
Build type: Unknown
Branch: feature/toolbitdock
Hash: 26eac120b80e3570413fbe2050835128085b332a
Python version: 3.6.9
Qt version: 5.9.5
mlampert
Postby mlampert » Sun Nov 22, 2020 8:10 pm
filed an issue for it for tracking: issue #4500
Re: Ticket #4500 - segfault on focus change
Postby Kunda1 » Tue Dec 08, 2020 5:19 pm
issue #4500 marked as 'Confirmed' and target set to v0.19
Site Admin
Postby wmayer » Thu Dec 17, 2020 2:02 pm
The crash is caused by this line in PathToolBitEdit.py
self.form.shapePath.editingFinished.connect(self.updateShape)
When you click inside the line edit and afterwards into the quantity spin box the line edit emits the signal editingFinished. This invokes the connected slot updateShape() that calls setupTool(). setupTool() cleans up the layout and thus destroys the widgets and afterwards it re-creates them. However, Qt internally has stored a pointer to the focus widget that becomes dangling due to the destruction.
This dangling pointer then leads to the crash.
mlampert
Postby mlampert » Thu Dec 17, 2020 4:52 pm
There's some serious kung-fu happening here - first off, thanks! I'll look into it tonight and try to fix it.
Second - how did you figure this out?
Site Admin
Postby wmayer » Thu Dec 17, 2020 9:36 pm
I needed the Qt source code and a debug build. Now when looking at the address of the pointer of the focus widget I could see that it was a dangling pointer.
But from the dangling pointer it wasn't possible to see what the actual class name is. Thus, in a second step I set a break point at the constructor and destructor of QLineEdit. So, I could confirm that the focus widget was a QLineEdit by comparing the pointer addresses.
Now when looking at the call stack I saw the emitted signal editingFinished() and a couple of Python function calls. This looked suspicious to me so I went straight to the file PathToolBitEdit.py and checked what's connected to the signal.
mlampert
Postby mlampert » Thu Dec 17, 2020 9:57 pm
I bow low before the master and am deeply humbled!
Thank You! For your skills, the explanation and the dedication to track this down.
