Windows High DPI with different screen DPIs
apeltauer
Postby apeltauer » Thu Nov 19, 2020 2:17 pm
Hi all,
during developing another qt application i came accross the following articel
https://vicrucann.github.io/tutorials/osg-qt-high-dpi/
Since i am working with a notebook and an external 4k screen, i am facing some display issues when it comes to the high DPI problematic.
I kwow that windows(10) does not fully support a high dpi scalling for all appplications. Some of them just look blurry, depending on what screen it is opened.
Also working with FC shows some minor display issues. I tried the code suggested in the articel. See the differents.
The Code change in src\Gui\Application.cpp line 1906
#if QT_VERSION >= 0x050600
    //Enable automatic scaling based on pixel density of display (added in Qt 5.6)
    //QCoreApplication::setAttribute(Qt::AA_EnableHighDpiScaling);
    SetProcessDPIAware(); // call before the main event loop
    QApplication::setAttribute(Qt::AA_DisableHighDpiScaling);
#endif
Maybe some windows user also can test and check if this improves the behaviour.
PS:
A set of links to dpi topics
https://forum.freecadweb.org/viewtopic.php?t=41193
https://forum.freecadweb.org/viewtopic.php?t=34916
https://forum.freecadweb.org/viewtopic.php?f=34&t=48719
vanuan
Re: Windows High DPI with different screen DPIs
Postby vanuan » Fri Nov 20, 2020 3:29 am
Please read the master plan:
https://wiki.freecadweb.org/HiDPI_support
The flag AA_EnableHighDpiScaling should only be disabled after the part two is complete. That is, first we should make sure that we get the correct font metrics from the system and rescale all the widgets in units of font size.
If we disable the flag AA_EnableHighDpiScaling right now, we'll have the issue of widgets not being scaled to fit the text, thus the text would be larger than the widget size. The most prominent example is the Navigation Cube: https://forum.freecadweb.org/viewtopic.php?f=3&t=42835
Instead of choosing the readable size and scaling the cube to fit it, they opted to introducing a new user option: https://github.com/FreeCAD/FreeCAD/pull/2967
Hacks like this lead to a bad UX and should be discouraged.
Disabling the AA_EnableHighDpiScaling might work fine for Windows where font metrics are rarely changed while on other systems (Linux) font sizes vary significantly and should be figured out first.
apeltauer
Postby apeltauer » Fri Nov 20, 2020 7:15 am
Thanks for your feedback.
I forgot to mention that disabling the hidpi on qt should only happen when the os is windows. also the mentioned call "SetProcessDPIAware();" only works on windows.
apeltauer
Postby apeltauer » Mon Nov 23, 2020 6:46 am
