Nice!!! This is excellent news, now the little green checkmarks will be back next to the PRs in the list.
Changes at TravisCI- affecting open source
Re: Changes at TravisCI- affecting open source
Not only that, you can click on details to directly go to the actual build on your docker runner, and download the artifacts...bernd wrote: ↑Thu Sep 30, 2021 1:32 pm great news even the nice status for PRs works. see https://github.com/FreeCAD/FreeCAD/pull/5074
If you log into github you will see this nice status check for CI. ATM only this PR will pass the check ...
Very nice! Thank you for your hard work!
Greetings
user1234
Greetings
user1234
status check runs too ... !
The machine needs to rebuild all PRs to make the status check recognize the pipeline ... Done for https://github.com/FreeCAD/FreeCAD/pull/5077 and https://github.com/FreeCAD/FreeCAD/pull/5076
Done, all rebased PRs do have the status check in the regard of CI. Watch for the green heel or the orange Dot.
ATM still I need to manually push the PRs to the CI. To automate this too is one of the next things to do.
0.19 branch was added to the CI too https://github.com/FreeCAD/FreeCAD/comm ... eeCAD-0-19 and https://gitlab.com/berndhahnebach/FreeC ... eeCAD-0-19
I switched from my repo to https://gitlab.com/freecad/FreeCAD-CI Just keep using the links which will be generated at the github repository. They should direct to the correct repository.
Time to rename this thread?
Also is there a place where discussions are happening about FreeCAD CI code logisitics? I'd like to see if we can add the possibility to create on demand experiemental builds of PRs (think Toponaming)
Currently PR CI is still launched manually by @bernd. First step first, a solution should be found for this IMO.
