Changes at TravisCI- affecting open source
bernd
Re: Changes at TravisCI- affecting open source
Post by bernd »
I am still tryieng to get such a nice merge check ...
https://docs.gitlab.com/ee/user/project ... ithub.html
At the moment this only would work if we would create the branches on the github repository, but IMHO according the documentation it should be possible without create feature branches for each PR on the github repository.
abdullah
Post by abdullah »
You are doing a great job. Thank you!
If Bernd's "pipeline" would work for PRs, then it would be a very nice and flexible integration.
Regarding the security and deployment of artifacts, we do have some free minutes on GitHub Actions. Maybe we could automatically build and deploy artifacts of master using these free minutes.
Travis is also giving us some free minutes. The end solution does not need to be to ditch Travis. Travis' free minutes could also be used (provided their platform fixes any reported vulnerability).
If we manage to certify one server as "secure", then we could also make the artifacts of PRs available to improve testing.
I see you do not have many hands. I offer mines. How could I help?
abdullah
Post by abdullah »
I am sure you are aware, but the master build in gitlab-ci is timing out after 3 hours:
https://gitlab.com/freecad/FreeCAD-CI/-/jobs/1636177464
abdullah
Post by abdullah »
I found this:
https://docs.gitlab.com/ee/ci/runners/c ... r-a-runner
Example 1 - Runner timeout bigger than project timeout
You set the maximum job timeout for a runner to 24 hours
You set the CI/CD Timeout for a project to 2 hours
You start a job
The job, if running longer, times out after 2 hours
Example 2 - Runner timeout not configured
You remove the maximum job timeout configuration from a runner
You start a job
Example 3 - Runner timeout smaller than project timeout
You set the maximum job timeout for a runner to 30 minutes
You start a job
The job, if running longer, times out after 30 minutes
chennes
Post by chennes »
abdullah wrote: Thu Sep 30, 2021 12:08 pm I am sure you are aware, but the master build in gitlab-ci is timing out after 3 hours:
What is the pipeline in gitlab.com/FreeCAD supposed to be doing right now? I've been using https://gitlab.com/berndhahnebach/FreeC ... e=branches
Chris Hennes
Pioneer Library System
bernd
Post by bernd »
chennes wrote: Thu Sep 30, 2021 12:47 pm
ATM the FreeCAD CI runs on https://gitlab.com/berndhahnebach/FreeC ... e=branches Just use the links provided as comments in each PR.
bernd
Post by bernd »
Yes I am. This will be the future version. Just use the links provided in the PRs They point to the correct repository. This repo I am working on. Right now this does not run on my local machine but uses runners from gitlab. The maximum time limit gitlab runners provide are 3h thus 3h. The runners on my local machine for the current CI has time limit of 7h but only needs 1h for a full build.
bernd
Post by bernd »
abdullah wrote: Thu Sep 30, 2021 11:40 am You are doing a great job. Thank you!
It has been working for a few days allready for PRs. Just click into the PRs and use the links provided either by me (older) or the new freecadci bot user. 8-)
bernd
Post by bernd »
great news even the nice status for PRs works. see https://github.com/FreeCAD/FreeCAD/pull/5074
If you log into github you will see this nice status check for CI. ATM only this PR will pass the check ...
bernd
Post by bernd »
In the future this will replace the one in my repo. But just watch for the links in the PRs. Just use the repo they point too.
