As always, I only post them for information. I have no clue if we need to act and if so how.
Here the warnings grouped by type:
Type A: C26495
Severity Code Description Project File Line Suppression State
Warning C26495 Variable 'App::PropertyData::parentPropertyData' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\App\PropertyContainer.h 136
Warning C26495 Variable 'PartDesign::Hole::CutDimensionSet::thread_type' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 157
Warning C26495 Variable 'PartDesign::Hole::CutDimensionSet::cut_type' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 157
Warning C26495 Variable 'PartDesign::Hole::CutDimensionSet::angle' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.cpp 1602
Warning C26495 Variable 'PartDesign::Hole::CutDimensionSet::angle' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.cpp 1608
Warning C26495 Variable 'PartDesign::Hole::CutDimensionSet::angle' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 157
Warning C26495 Variable 'PartDesign::Hole::CounterSinkDimension::diameter' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 149
Warning C26495 Variable 'PartDesign::Hole::CounterBoreDimension::diameter' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 143
Warning C26495 Variable 'PartDesign::Hole::CounterBoreDimension::depth' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.h 143
Warning C26495 Variable 'Part::ShapeHistory::type' is uninitialized. Always initialize a member variable (type.6). PartDesign D:\FreeCADGit\src\Mod\Part\App\PropertyTopoShape.h 108
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\App\ObjectIdentifier.h 92
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\App\ObjectIdentifier.h 158
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\App\ObjectIdentifier.h 255
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 95
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 168
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 186
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 204
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 224
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 245
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 280
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 295
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 315
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 336
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 352
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 367
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 383
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 398
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 414
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 430
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 442
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 454
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 470
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 486
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 502
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 517
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 533
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 549
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 566
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 581
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 596
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 612
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 628
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 644
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 661
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Exception.h 679
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Base\Interpreter.h 148
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Mod\Part\App\Attacher.h 470
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Mod\Part\App\AttachExtension.h 56
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Mod\Part\App\TopoShape.h 56
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesign D:\FreeCADGit\src\Mod\Part\App\TopoShape.h 69
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesignGui D:\FreeCADGit\src\Gui\Selection.h 135
Warning C26439 This kind of function may not throw. Declare it 'noexcept' (f.6). PartDesignGui D:\FreeCADGit\src\Gui\Selection.h 139
Warning C26812 The enum type 'TechDraw::GeomType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). TechDraw D:\FreeCADGit\src\Mod\TechDraw\App\Geometry.h 129
Warning C26812 The enum type 'TechDraw::ExtractionType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). TechDraw D:\FreeCADGit\src\Mod\TechDraw\App\Geometry.h 129
Warning C26812 The enum type 'TechDraw::edgeClass' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). TechDraw D:\FreeCADGit\src\Mod\TechDraw\App\Geometry.h 129
Warning C26812 The enum type 'SoVectorizeAction::DimensionUnit' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCAD-build\FreeCADLibs_12.4.2_x64_VC17\include\Inventor\annex\HardCopy\SoVectorizeAction.h 131
Warning C26812 The enum type 'SoMultiTextureImageElement::Wrap' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCAD-build\FreeCADLibs_12.4.2_x64_VC17\include\Inventor\elements\SoMultiTextureImageElement.h 184
Warning C26812 The enum type 'SoMultiTextureImageElement::Model' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCAD-build\FreeCADLibs_12.4.2_x64_VC17\include\Inventor\elements\SoMultiTextureImageElement.h 184
Warning C26812 The enum type 'PyGILState_STATE' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Base\Interpreter.h 167
Warning C26812 The enum type 'PartDesign::Hole::CutDimensionSet::ThreadType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.cpp 1535
Warning C26812 The enum type 'PartDesign::Hole::CutDimensionSet::CutType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.cpp 1602
Warning C26812 The enum type 'PartDesign::FeatureAddSub::Type' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Mod\PartDesign\App\FeatureHole.cpp 546
Warning C26812 The enum type 'Gui::ViewStatus' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\ViewProvider.h 373
Warning C26812 The enum type 'Gui::TaskView::TaskDialog::ButtonPosition' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\TaskView\TaskDialog.h 57
Warning C26812 The enum type 'Gui::SelectionChanges::MsgType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\Selection.h 83
Warning C26812 The enum type 'Gui::MDIView::ViewMode' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\MDIView.h 113
Warning C26812 The enum type 'Gui::FileChooser::AcceptMode' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\FileDialog.h 182
Warning C26812 The enum type 'Gui::Command::TriggerSource' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesignGui D:\FreeCADGit\src\Gui\Command.h 356
Warning C26812 The enum type 'Base::QuantityFormat::NumberFormat' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Base\Quantity.h 97
Warning C26812 The enum type 'Base::PyStreambuf::Type' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Base\Stream.h 259
Warning C26812 The enum type 'Attacher::eRefType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\Mod\Part\App\Attacher.h 384
Warning C26812 The enum type 'App::Property::Status' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\App\Property.h 205
Warning C26812 The enum type 'App::ObjectStatus' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\App\DocumentObject.h 176
Warning C26812 The enum type 'App::ObjectIdentifier::Component::typeEnum' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\App\ObjectIdentifier.h 160
Warning C26812 The enum type 'App::Material::MaterialType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). PartDesign D:\FreeCADGit\src\App\Material.h 273
Warning C26812 The enum type '?A0x6a5bdc34::DrawViewType' is unscoped. Prefer 'enum class' over 'enum' (Enum.3). TechDraw D:\FreeCADGit\src\Mod\TechDraw\App\DrawViewDimension.cpp 198
Warning C26451 Arithmetic overflow: Using operator '+' on a 4 byte value and then casting the result to a 8 byte value. Cast the value to the wider type before calling operator '+' to avoid overflow (io.2). PartDesign D:\FreeCADGit\src\zipios++\virtualseeker.h 67
