Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
Re: Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
After several weeks, and many problems, I have the basic functionality of my new tool. It is yet not perfect and not completed.
But since many of the options are working now, I would like to share it with you and maybe you leave your suggestion, comments here.
Basically it is 4 direction + Rotation of a face - Extrusion. It uses LOFT and the rotation (I am still not finished how to implement).
These might be useful, or useless .. Don't know .. depending on some applications they might be useful. But in general, this tool will get more functionality in the future as I learn and learn more (hopefully )
It can be also combined with other tools (direct modeling) to achieve other manipulations. It was hard and it wasn't easy.
There are several bugs that needs to be targeted, even in COIN widget. For example I wanted to show the rotation angels in number but the text is misplaced and just not working yet.
Hope you find it useful or at least get you inspired.
Thanks go to Mario for his rotation script which I really needed to make this rotation works better. Depending on that function I will make a better rotation tool soon after this tool.
https://www.youtube.com/watch?v=l4wzVcbrDls
- ExtractFaceRotate.png (464.52 KiB) Viewed 3035 times
Design456 Direct Modeling. Coin3D GUI Toolkit. Objects get simplified.
https://github.com/MariwanJ/Design456 - https://wiki.freecadweb.org/Design456_Workbench
https://www.youtube.com/watch?v=6agcHPd ... utbTDH93m_
Just a small heads up: your WB currently cannot be installed with Std_AddonMgr:
Error: Unable to download https://github.com/MariwanJ/Design456/a ... master.zip
I just downloaded the WB using the Addon Manager.Roy_043 wrote: ↑Mon Oct 11, 2021 8:20 pm Just a small heads up: your WB currently cannot be installed with Std_AddonMgr:
My version is :
OS: Windows 10 Version 2009
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Maybe you have git installed? I don't.
Would you please try to download latest build?
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
And try to look at this video?marja1 wrote: ↑Tue Oct 12, 2021 5:19 amWould you please try to download latest build?
https://www.youtube.com/watch?v=RomaDFQ1WoA
I have worked on the documentation of the Std_AddonMgr command, so I know how it should work. Most (all?) addons can be installed without having git installed. For your addon this is apparently not the case.
OS: Windows 8.1 (6.3)
Version: 0.20.25997 (Git)
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
If you are able to look at the link .. please don't use master --> mine has no master .. It is main branch.
The problem is there.
It works for me so really don't know what to say. Maybe just downloading manually and extracting the zip file at the MOD folder?
- adrianinsaval
wouldn't that then be a bug in the addon manager that asumes the main branch is called master?Roy_043 wrote: ↑Mon Oct 11, 2021 8:20 pm Just a small heads up: your WB currently cannot be installed with Std_AddonMgr:
could you check it out? I think you've been working with the addon manager lately? sorry to bother if that's not the case.chennes wrote:
I checked the github.
if you write
it works.. but not the master ..
It is working for me without changing anything. Don't know why it is not working for you. And regarding the git, FreeCAD uses some executable file which comes with the FreeCAD. You shouldn't be needing git to install the WB
if you write
https://github.com/MariwanJ/Design456/archive/main.zip
