Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
Re: Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
Hi - I'm following this development and just had a look at your installation - looks good ! Keep up the good work
Thank you @LHC,
New update in the Smart Extrude.
I had a big problem regarding finding objects in the document. App.ActiveDocument.Objects bring you things that is not what you draw inside the document. You have to filter out them.
Was difficult to understand.
There is something left and need to be fixed. but in general extrude-merge , extrude-cut is working.
More testing and bug hunting required.
Another bug that FreeCAD has, when you have different objects with transparency and you merge, cut them .. when you put the transparency of the produced object to 0 , it doesn't reset all of them.. so you get some of your parts still with transparency colors.
Look at the tool. It is pushed to the main .. so update your copy.
https://youtu.be/9at7Cq1BnTg
- extrude-cut.JPG (75.07 KiB) Viewed 4002 times
Design456 Direct Modeling. Coin3D GUI Toolkit. Objects get simplified.
https://github.com/MariwanJ/Design456 - https://wiki.freecadweb.org/Design456_Workbench
https://www.youtube.com/watch?v=6agcHPd ... utbTDH93m_
SmartExtrude works for many faces but when the face has no angle it fails.
I need to find a way to calculate the angle.
See the video.
See the video.
https://youtu.be/mHYloULuOUI
Release of Smart Extrude:
How it works:
We have to recreate the object each time we change the radius.
This means that the redrawing must be optimized later. Maybe if someday we change this to cpp make that issue be resolved.
1-If we have a 2D face, we just extrude it.
2-If we have a face from a 3D object, we extract that face and extrude it
3-Created object either it will remain as a new object or would be merged.
But if it is used as a tool to cut another 3D object, the object will disappear.
Known issue:
There are circumstances where this tool will fail. Pushing is not correct yet.
Pushing should be developed later.
To find out where this tool fails in other places I need to get help from FreeCAD community.
Please report the bugs to my github.
Thanks.
https://youtu.be/rvbkx-esfqk
How it works:
Known issue:
Thanks.
- smartExtrude.JPG (160.47 KiB) Viewed 3816 times
Adding DocObserver to draw plane when file opened or created.
Long time didn't know how to do that.
Thanks go to @OpenBrain and others who answered the thread
https://forum.freecadweb.org/viewtopic. ... 5&start=10
that helped me to understand the concept.
I looked even to this thread to understand more how it works.
https://forum.freecadweb.org/viewtopic. ... =3&t=36709
FreeCAD 0.19. Windows 7 x64
OS: Windows 7 SP 1 (6.1)
Version: 0.19.23463 (Git)
Hash: adc6db8f32c17e9f67cb82aa7962d1e42ce061c6
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
Python 3.6.8 (v3.6.8:3c6b436a57, Mar 26 2019, 15:45:44) [MSC v.1916 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> ### Begin command Std_Workbench
>>> Gui.activateWorkbench("Design456_Workbench")
>>> ### End command Std_Workbench
10:25:41 No module named 'dataclasses'
10:25:41 Traceback (most recent call last):
File "<string>", line 58, in Initialize
File "E:\FreeCAD\FreeCAD\Mod\Design456\DirectModeling\directModelingCommands.py", line 27, in <module>
import DirectModeling.Design456_SmartScale
File "E:\FreeCAD\FreeCAD\Mod\Design456\DirectModeling\Design456_SmartScale.py", line 36, in <module>
import ThreeDWidgets.fr_line_widget as wlin
File "E:\FreeCAD\FreeCAD\Mod\Design456\ThreeDWidgets\fr_line_widget.py", line 33, in <module>
from ThreeDWidgets import fr_draw
File "E:\FreeCAD\FreeCAD\Mod\Design456\ThreeDWidgets\fr_draw.py", line 39, in <module>
from dataclasses import dataclass
Please use latest weekly build. It is a python issue in your freecad that dosent have the latest libraries.
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Grateful for your answer, but.... the 0.20. of this week did not work for me under win 7x64.
Will try under Linux.
New FR_WIDGET - Fr_Wheel_Widget:
This widget will be used to rotate, move, extrusion by rotating a face .. and many more tools. The video shows one kind of the widget. There will be a 3D dimension version of it.
I discovered the draw_label wasn't so proper. I have to re-write it.
At the moment you cannot control the label well using only 2 vertices.
Keep tuned for further tools based on this widget.
https://youtu.be/i0dKk49dloU
- fr_wheel_widget.JPG (95.39 KiB) Viewed 3290 times
I am working on a new tool for extrusion which should make it easy to extrude a face and combined that with a rotation.
This tool can allow free-extrusion .. i.e. you use the mouse to extend the face to the direction you want.
I am still in the early stages and many questions must be answered.
This post is not about that.
Long time I had a problem of mouse-release when I wanted to release the mouse while the mouse was on another drawn FreeCAD object( not coin).
A user told me that FreeCAD eats up the events and doesn't allow me to capture that event while the mouse is over a FreeCAD object. Because of that I had to find another way to activate the callback (Release callback).
I introduce now the usage of ENTER, KEYPAD-ENTER and the key "E" to activate a callback. Using these keys make sure that you can release COIN3D FR_Widgets (for example the arrow of smart-extrusion I made) easily without any mistakes.
Main branch is updated but please be aware that the new tool is not finished . You can try it out but I don't promise you any good usage of it yet.
https://www.youtube.com/watch?v=9ZSJVeoCCVM
- freeExtrude.JPG (146.61 KiB) Viewed 2971 times
