I could not resist and did this nowuwestoehr wrote: ↑Sun Jan 23, 2022 1:55 pm Yes. This is valuable info. I created now a section to list the new, removed or changed APIs:
https://wiki.freecadweb.org/Release_notes_0.20#API
Please add there the changes you see in the commit logs.
[completed] Release notes for FreeCAD 0.20
Re: Release notes for FreeCAD 0.20
I think we could mention 1) the new freecad.org domain and 2) the switch from mantis to github issues.. Not sure this is appropriate on a release notes page?
Done:
https://wiki.freecadweb.org/Release_notes_0.20#General
Can you please review this since I don't know if KiCAD sponsored the new domain or who else.
wandererfan implemented in TechDraw: Grid
- is/are a view property/ies of the object page
- default preferences for new pages can be set in the preferences menu
https://forum.freecadweb.org/viewtopic.php?t=66416
Greetings
user1234
Greetings
user1234
@wandererfan, can you please have a look and update the Wiki page(s) accodingly?
wandererfan wrote: .
I just added this to the release notes but of course you may want to expand it.wandererfan wrote: .
- wandererfan
Done! Thanks!
New properties in the Arch Structure objects:
BasePerpendicularToTool : it copies the Base (extrusion profile) at the begining of the Tool (extrusion path) and places it perpendicular to the first edge of the tool. It is the same as attaching the Base with MapMode=NormalToEdge, but its automatic and allows to reuse the same Base object for multiple Structures.
When BasePerpendicularToTool = True, more properties control the placement of the Base relative to the Tool axis. They are shown in the attached image.
ToolOffsetFirst and ToolOffsetLast : extend/trim the Structure at the start and end respectively (the real length of the Structure is available in the ComputedLength readonly property)
BaseRotation : rotate the Base (the rotation is around the Base's "(0,0)" point which is the center for Arch Profiles, the origin for Sketches and usually the first point for Draft Wires)
BaseOffsetX and BaseOffsetY : move the Base (extrusion profile)
BaseMirror : mirror the Base (extrusion profile)
A new command Create multiple Arch Structure was also added. It uses the first selected object as a Base, and creates Arch Structures objects for every Edge of the other selected objects. Then, the properties of individual Structure objects can be adjusted in the Property editor. This command was added for workflow with a master Sketch (there is risk of topological naming problem unless you create non-parametric copy of the master Sketch or use Realthunder's version)
Original forum discussion: https://forum.freecadweb.org/viewtopic. ... 8&start=60
Main pull request: https://github.com/FreeCAD/FreeCAD/pull/3229
- NewArchStructureProperties.JPG (51.71 KiB) Viewed 5191 times
