[completed] Release notes for FreeCAD 0.20
uwestoehr
Post by uwestoehr »
This is the forum thread for new 0.20 features.
Here is the Wiki page for the release notes: https://wiki.freecadweb.org/Release_notes_0.20
We already have the first one: the hole dialog allows now to model real threads. Implemented via PR https://github.com/FreeCAD/FreeCAD/pull/4274
Re: Release notes for FreeCAD 0.20
Post by Kunda1 »
Thank you for starting this!
matthijskooijman
Post by matthijskooijman »
I've submitted a PR to update the link to this forum thread in the pull request template as well: https://github.com/FreeCAD/FreeCAD/pull/4781
Edit: It was merged
Last edited by matthijskooijman on Thu May 13, 2021 11:29 am, edited 1 time in total.
david69
Post by david69 »
can you put this page for translation, pls?
edit: thank you!
Roy_043
Post by Roy_043 »
We currently have a situation where images from the command reference are sometimes used in the release notes of a version. IMO that is not a good idea. Editors are not aware of this and can by uploading a new image (with the same name) inadvertently mess with the accuracy of those release notes.
To prevent this I'd like to propose that we add a suffix to the names of the images used on the Release_notes_0.20 page. And to then of course only use the images on this page.
Maybe?:
Roy_043
Post by Roy_043 »
I have now added a suffix to the image names.
jnxd
Post by jnxd »
Please add to Mesh Never mind I just discovered I actually had edit access for quite a while:
Fixed false negatives during self-intersection tests when facets are coplanar: PR #5002.
openBrain
Post by openBrain »
beding wrote: Fri Sep 10, 2021 3:34 pm Please solve the topology naming problem in 0.20, merge the real thunder branch.
It appears you don't understand the difference between Release Notes and Wish List...
ragohix769
Post by ragohix769 »
It appears not up to date?
The recent Draft Hatch tool, IE, made by Yorik, it's not present in the list.
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough :-(
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same :-)
Roy_043
Post by Roy_043 »
What is the policy, if any, regarding bug fixes? Do some, or all, of them deserve a mention in the Release notes?
