Back port commits to 0.19 branch
Re: Back port commits to 0.19 branch
we could make compile the CI all branches down to 0.13 ... we would just need an appropriate docker image of old ubuntu ... live is just to short to do all the funny stuff which makes no sense at all ...
I have no idea why this is needed but it did the trick ...openBrain wrote: ↑Fri Oct 01, 2021 3:58 pm Maybe you need a complete refspec :Code: Select all
git push origin FreeCAD-0-19:releases/FreeCAD-0-19
$ git status
Auf Branch FreeCAD-0-19
Ihr Branch ist 1 Commit vor 'origin/releases/FreeCAD-0-19'.
(benutzen Sie "git push", um lokale Commits zu publizieren)
nichts zu committen, Arbeitsverzeichnis unverändert
$ git push origin FreeCAD-0-19:releases/FreeCAD-0-19
Username for 'https://github.com': berndhahnebach
Password for 'https://berndhahnebach@github.com':
Objekte aufzählen: 7, Fertig.
Zähle Objekte: 100% (7/7), Fertig.
Delta-Kompression verwendet bis zu 4 Threads.
Komprimiere Objekte: 100% (4/4), Fertig.
Schreibe Objekte: 100% (4/4), 407 bytes | 407.00 KiB/s, Fertig.
Gesamt 4 (Delta 2), Wiederverwendet 0 (Delta 0)
remote: Resolving deltas: 100% (2/2), completed with 2 local objects.
To https://github.com/FreeCAD/FreeCAD
1f024523e6..de7cba4669 FreeCAD-0-19 -> releases/FreeCAD-0-19
It fails during build https://gitlab.com/berndhahnebach/FreeC ... /381034570
https://forum.freecadweb.org/viewtopic.php?f=4&t=58090bernd wrote: ↑Fri Oct 01, 2021 5:06 pm It fails during build https://gitlab.com/berndhahnebach/FreeC ... /381034570
someone an idea why it fails ... https://gitlab.com/berndhahnebach/FreeC ... 202840/raw
I gave a link just above... Something else needed?bernd wrote: ↑Fri Oct 01, 2021 5:51 pm someone an idea why it fails ... https://gitlab.com/berndhahnebach/FreeC ... 202840/raw
does it mean I need to patch occt on the docker container?
BTW: Why does it not fail on FreeCAD 0.20 build?
I am pretty sure, that FreeCAD 0.19 will not compile with OCCT7.5.2, but maybe with OCCT7.5.0. OCCT7.5.2 came 2 day out before the release of 0.19.2.
https://git.dev.opencascade.org/gitweb/ ... ags/V7_5_2
https://github.com/FreeCAD/FreeCAD/releases/tag/0.19.2
Greetings
user1234
Greetings
user1234
Nope, the workaround fix in FreeCAD is this line : https://github.com/FreeCAD/FreeCAD/blob ... mp.cpp#L31
I think 0.19 wasn't compiled against OCC 7.5.2 so it doesn't fail. You have to backport the workaround if you want to compile 0.19 with this version of OCC.
Edit : commit hash if you want to cherry pick : git commit 91b0409c48fd726e81f498b8a77ec51efd1683f2
