[API Documentation] Volunteers to improve descriptions for several attributes
Post by Kunda1 »
  • FreeCADGui.Command.(All attributes)
  • FreeCADGui.Control.(All attributes)
  • FreeCADGui.Document.(All attributes)
  • FreeCADGui.Selection.(All attributes)
  • FreeCADGui.ViewProvider.(All attributes)
Edit: drawing inspiration from flachyjoe in git commit f94b3c3f583a6
flachyjoe wrote: pinged by pinger macro
Re: [API Documentation] Volunteers to improve descriptions for several attributes
Post by Kunda1 »
bump
flachyjoe
Post by flachyjoe »
- Flachy Joe -
Post by Kunda1 »
:+1:
flachyjoe
Post by flachyjoe »
  • Can you tell me where FreeCADGui.Control. API is defined ?
  • Is FreeCADGui.Selection. only in SelectionObjectPy.xml ?
It might be possible to parse *PyImp.cpp for PyArg_ParseTuple and auto-find methods args and inject them in xml.
Are regexp experts here ?
- Flachy Joe -
Post by Kunda1 »
wmayer wrote: pinged by pinger macro
wmayer, do you mind weighing in?
Post by wmayer »
https://github.com/FreeCAD/FreeCAD/blob ... thon.h#L34
No, it's here: https://github.com/FreeCAD/FreeCAD/blob ... ion.h#L639 and here https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L1819
Post by Kunda1 »
flachyjoe wrote: Sun Apr 18, 2021 12:22 pm It might be possible to parse *PyImp.cpp for PyArg_ParseTuple and auto-find methods args and inject them in xml.
We can use regex101.com to help figure this out.
Edit: what are the patterns we're searching for exactly ?
flachyjoe
Post by flachyjoe »
Hi !
Can somebody check this :?: : https://github.com/FlachyJoe/FreeCAD/co ... ae10a88adb
Kunda1 wrote: Mon Apr 19, 2021 2:24 pm what are the patterns we're searching for exactly ?
the call of PyArg_ParseTuple is
PyArg_ParseTuple(args, "arg_def", &arg1, &arg2, ...)
or
PyArg_ParseTuple(args, "arg_def", ..., &typeN, &argN, ...)
where "args_def" defines arguments types :
s for string
i for integer
b for boolean
O for object
O! for object preceded by type
and | precedes the first optional argument
sometimes we can also find ";an error message" at the end.
- Flachy Joe -
