As I am reading, modifying and trying to get this code converted to the format I use, which must be classes and clean definition of commands, I understand little bit more of Microelly's code.
Many of his commands are more like experiment rather than a real tool that you use. They are made for special purposes (many of them not all).
Some comes with specific file which he has in data folder.
My roadmap here is to :
- Convert them ALL to the way I can find them easily in toolbar and their original files
- try to run them and if possible try to get them to works.(Notice that I get many problems at the moment, I don't know how to use many of them)
- Ask community to help in understanding the commands as they might been involved in developing them(please if you with to do so now, make issue in my github, write the command and write how it should be used .. and I will put your notes in the code..Please in English)
- After understanding how the commands should be used
- Make them more like a command, with error detection(usage warning ..etc)
- Remove duplicated commands
- Great clean up of the code
- Document the code (Translate the German comments (someone would take this hopefully), document all commands
-There are many YouTube videos. I am afraid that these videos might be lost if he delete his account ..etc. Is there a way to preserve them? How should I do?
-Threads regarding each commands might have valuable documentation and howto.. I might need help later to find them out and put it in the WIKI page.
I hope you will be interested and help when this will be required (I don't mean coding, I know you don't have time ). Thanks for reading.
