In my local checkout I've done a few small of these improvements, but I'm a bit hesitant to submit them as a pull request, since it's essentially changes that do not improve the functionality at all, do require some non-negligable effort to change and review, and I'm not so sure if such changes would be welcomed. Also, there's a thin line between objectively improving the code, and forcing my own ideas of beatiful code on others.
However, regardless of *changing* the current code in such a way is welcome, I suspect that it would be good to at least flag such issues, so people can form an opinion (maybe some of these things are intentionally simple) and maybe use my suggestions at least in new code that is written. So below, I'll describe some of these patterns that I've found. I'll try to do this using a diff showing the improvement, to hopefully make things easy to understand.
Let me know what you think, both of the examples/patterns themselves (to see whether we should apply them), as well as of the form of my suggestions (to see if I should offer more when I find them).
1. hasattr() or getattr()
In a lot of places, hasattr() is used to check whether a property exists, and if so it is queried using two nested ifs as shown below. Often, there is also an else to handle the case where the attribute does not exist, which is often identical to inner if. A lot more concise is to use the getattr() function, which retrieves an attribute and if the attribute does not exist, returns a configurable default (the second argument). Consider below:
--- a/src/Mod/Draft/draftobjects/wire.py
+++ b/src/Mod/Draft/draftobjects/wire.py
@@ -102,10 +102,7 @@ def execute(self, obj):
if obj.Base.isDerivedFrom("Sketcher::SketchObject"):
shape = obj.Base.Shape.copy()
if obj.Base.Shape.isClosed():
- if hasattr(obj,"MakeFace"):
- if obj.MakeFace:
- shape = Part.Face(shape)
- else:
+ if getattr(obj,"MakeFace",True):
obj.Shape = shape
elif obj.Base and obj.Tool:
The default value can of course be any value, so sometimes it can help to use it with an empty list, e.g.:
--- a/src/Mod/Arch/ArchComponent.py
+++ b/src/Mod/Arch/ArchComponent.py
@@ -1426,14 +1426,12 @@ def claimChildren(self):
c = []
else:
c = [self.Object.Base]
- if hasattr(self.Object,"Additions"):
- c.extend(self.Object.Additions)
+ c.extend(getattr(self.Object, "Additions", [])
- if hasattr(self.Object,"Subtractions"):
- for s in self.Object.Subtractions:
+ for s in getattr(self.Object, "Subtractions", []):
if Draft.getType(self.Object) == "Wall":
if Draft.getType(s) == "Roof":
continue
Note that the above makes two changes, one which takes advantage of the fact that extend([]) is a no-op, the second of the fact that looping over an empty list is a no-op.
In addition to make the code shorter, these changes also help to reduce the nesting level, which often also makes the code easier to read.
2. Nested if or combined with and
In a lot of places, there's a lot of nested ifs. When these ifs contain nothing else than another if, they're essentially just a single if with a logical and of their conditions, and I would usually write them as such. For example:
@@ -737,9 +737,7 @@ def processSubShapes(self,obj,base,placement=None):
base = base.fuse(add)
elif hasattr(o,'Shape'):
- if o.Shape:
- if not o.Shape.isNull():
- if o.Shape.Solids:
+ if o.Shape and not o.Shape.isNull() and o.Shape.Solids:
s = o.Shape.copy()
if placement:
s.Placement = s.Placement.multiply(placement)
Again, this reduces nesting level, making the code easier to read. Also the fact that the and operator is used makes it IMHO more clear what the code does. There is a tradeoff here: Nesting is reduced, but line length is increased. For even longer expressions, you can use parenthesis around the condition to make it span multiple lines, or introduce variables for parts of the expression. Note that that increases the line count again, but not the nesting level.
3. Duplicate code in if branches
Here's another pattern, which is essentially similar to the 1. above, where multiple if branches have the same code. This makes it harder to quickly see that the same thing happens in two situations, and also makes the code prone to breakage when one place is changed and the other is not. Consider:
@@ -1420,9 +1418,7 @@ def claimChildren(self):
if hasattr(self,"Object"):
c = []
if hasattr(self.Object,"Base"):
- if Draft.getType(self.Object) != "Wall":
- c = [self.Object.Base]
- elif Draft.getType(self.Object.Base) == "Space":
+ if Draft.getType(self.Object) == "Wall" and Draft.getType(self.Object.Base) == "Space":
c = []
else:
c = []
- c = []
- else:
+ if not (Draft.getType(self.Object) == "Wall" and Draft.getType(self.Object.Base) == "Space"):
4. Using set() to prevent duplicates
In some places, a list must be produced without duplicates, which then often produces a list, and then produces a second list checking for duplicates. This takes a lot of code, and is not quite efficient, especially for longer lists. In Python the `set` type can be used instead, which is a container, like list, but cannot contain duplicate items. Removing duplicates from a list by simply converting it to a set is a common idiom in Python:
--- a/src/Mod/Draft/draftutils/groups.py
+++ b/src/Mod/Draft/draftutils/groups.py
@@ -245,13 +245,7 @@ def get_group_contents(objectslist,
if walls:
newlist.extend(get_windows(obj))
- # Clean possible duplicates
- cleanlist = []
- for obj in newlist:
- if obj not in cleanlist:
- cleanlist.append(obj)
- return cleanlist
+ return set(newlist)
Also, the above diff does change the return type from list to set. This is often a good idea, since the fact that it produces unique values is part of the interface (especially if that also means they're unordered), but if a list return type is required, you can simply use the list constructor to convert the set after producing it.
Finally, the above first builds a list and then uses a set to remove duplicates, but it would of course be even cleaner to just produce a set in the first place (but that would be a bigger diff, so I didn't for this example).
5. Using generators and yield instead of building lists
There is a lot of code that produces a list of things, which is then iterated over by the caller once. For these cases, Python supports generators / generator functions. These are function that do not produce a list, but a generator that can produce elements one by one. When iterating over such a generator, there is no need to first calculate the complete list and return that, but instead the for loop in the caller just starts executing and whenever it needs the next value, the generator runs for a bit to produce the next value. This saves a lot of memory and allocation, and makes code simpler because there is less boilerplate for initializing a list and returning it. Generators are also automatically nested: If you call a generator function that internally calls another generator function, iterates over its result, and yields a modified version of each element, then whenever the caller needs a new value from the outer generator function, that will ask the inner generator for the next value, modify it and then yield the result, still no lists need to be allocated.
For example:
@@ -66,16 +66,12 @@ def get_group_names(doc=None):
if not found:
_err(_tr("No active document. Aborting."))
- return []
+ return
- glist = []
for obj in doc.Objects:
if (obj.isDerivedFrom("App::DocumentObjectGroup")
or utils.get_type(obj) in ("Floor", "Building", "Site")):
- glist.append(obj.Name)
+ yield obj.Name
- return glist
One caveat is that a generator is not a list, so it means that it cannot be indexed and can be iterated only once. In most cases, this is exactly what happens, so this should be enough (though there is the issue of backward compatibility with third party code that might prevent converting things to generators immediately). If you have a generator but need indexing or multiple iteration, then you can always just use the list() constructor to convert a generator to a list.
