Couple of Qt Questions.
keithsloan52
Post by keithsloan52 »
I am trying to control the size of a LineEdit box
I am trying
self.value = QtGui.QLineEdit()
self.value.setMaxLength = len
self.value.setGeometry(QtCore.QRect(0,0,10,5))
But the setGeometry does not seem to have any effect.
I would also like to drive a FocusOutEvent on when the mouse moves outside of the dialog
the c++ doc has
void QLineEdit::focusOutEvent(QFocusEvent *e)
But how do I do it in python
I tried adding to the class that defines the task and to. the panel widget
       def focueOutEvent(self, event) :
              print('Went out of focus')
But did not seem to be driven.
openBrain
Re: Couple of Qt Questions.
Post by openBrain »
keithsloan52 wrote: Sun May 23, 2021 4:08 pm I am trying to control the size of a LineEdit box
I am trying
setMaxLength is a function, not an attribute.
Also geometry is quite complex as real effects mainly depend on SizePolicy.
the c++ doc has
Did you try without making a typo in the function name?
keithsloan52
openBrain wrote: Sun May 23, 2021 4:13 pm
I am trying
Changed it but still no effect on the size of the box. Think MaxLength applies to amount of
text that can be entered. setGeometry did not seem to work.
added a function
      def sizeHint(self) :
           return(Qtcore.QSize(10,5))
But that did not help either
the c++ doc has
:-) Yes, cut and pasted from code this time
def focusOutEvent(self, event) :
        print('Out of Focus')
openBrain
Post by openBrain »
Can you share full code?
keithsloan52
Okay by reading the docs worked out that I needed a leaveEvent rather than a focusOutEvent .
Which gets driven when I Ieave the Task panel, but if I try closeDialog it crashed FreeCAD
def leaveEvent(self, event) :
        print('Leave Event')
        FreeCADGui.Control.closeDialog()
Is there a way to close the panel from one of its events?
keithsloan52
openBrain wrote: Sun May 23, 2021 6:02 pm Can you share full code?
Full code https://github.com/KeithSloan/GDML branch Gmsh
Widget code
class oField(QtGui.QWidget) :
    def __init__(self,label,len, value,parent=None) :
        super(oField, self).__init__(parent)
        self.label = QtGui.QLabel(label)
        self.value.setMaxLength(len)
        self.value.setReadOnly(True)
        self.value.setText(value)
        self.label.setBuddy(self.value)
        layout = QtGui.QHBoxLayout()
        layout.addWidget(self.label)
        layout.addWidget(self.value)
        self.setLayout(layout)
        return(QtCore.QSize(10,5))
openBrain
Post by openBrain »
keithsloan52 wrote: Sun May 23, 2021 6:17 pm Okay by reading the docs worked out that I needed a leaveEvent rather than a focusOutEvent .
I'm with a mobile now but something like
QtCore.QMetaObject.invokeMethod(Gui.Control, 'closeDialog', QtCore.Qt.QueuedConnection)
keithsloan52
openBrain wrote: Sun May 23, 2021 7:10 pm
Had to change the Gui.Control to FreeCADGui.Control to get further but then got
09:56:54  Traceback (most recent call last):
09:56:54    File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/GDML/freecad/gdml/GDMLCommands.py", line 697, in leaveEvent
09:56:54      QtCore.QMetaObject.invokeMethod(FreeCADGui.Control, 'closeDialog', QtCore.Qt.QueuedConnection)
09:56:54  TypeError: 'PySide2.QtCore.QMetaObject.invokeMethod' called with wrong argument types:
  PySide2.QtCore.QMetaObject.invokeMethod(Control, str, ConnectionType)
Supported signatures:
  PySide2.QtCore.QMetaObject.invokeMethod(PySide2.QtCore.QObject, str, PySide2.QtCore.Qt.ConnectionType, PySide2.QtCore.QGenericReturnArgument, PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ...)
  PySide2.QtCore.QMetaObject.invokeMethod(PySide2.QtCore.QObject, str, PySide2.QtCore.QGenericReturnArgument, PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ...)
  PySide2.QtCore.QMetaObject.invokeMethod(PySide2.QtCore.QObject, str, PySide2.QtCore.Qt.ConnectionType, PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ...)
  PySide2.QtCore.QMetaObject.invokeMethod(PySide2.QtCore.QObject, str, PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ..., PySide2.QtCore.QGenericArgument = ...)
openBrain
Post by openBrain »
Hmm IIRC I had this in C++ too but I don't think we can qobject_cast in Python. I'll eventually have a look at this, but in between maybe the dirty method may work
QtCore.QTimer.singleShot(0, FreeCADGui.Control, SLOT('closeDialog()'))
keithsloan52
openBrain wrote: Mon May 24, 2021 9:46 am Hmm IIRC I had this in C++ too but I don't think we can qobject_cast in Python. I'll eventually have a look at this, but in between maybe the dirty method may work
11:43:24  Leave Event
11:43:24  Traceback (most recent call last):
11:43:24    File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/GDML/freecad/gdml/GDMLCommands.py", line 698, in leaveEvent
11:43:24      QtCore.QTimer.singleShot(0, FreeCADGui.Control, SLOT('closeDialog()'))
11:43:24  NameError: name 'SLOT' is not defined
Not urgent but would be good to have a vanilla solution
