Nope, that is where I startedopenBrain wrote: ↑Wed May 26, 2021 2:40 pmI don't really understand. Of course it has no 'Vertex' attribute if you didn't modify other lines of the snippet.keithsloan52 wrote: ↑Wed May 26, 2021 2:35 pmSo it does not show up in the form or the layoutCode: Select all
5:33:37 Traceback (most recent call last): 15:33:37 File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/GDML/freecad/gdml/GDMLCommands.py", line 798, in actionMesh 15:33:37 print(self.form.meshInfoLayout.Vertex) 15:33:37 AttributeError: 'PySide2.QtWidgets.QHBoxLayout' object has no attribute 'Vertex'
Maybe the simple so you hopefully understand. Take the snippet as it was some post above and changetoCode: Select all
print(dir(self.form.meshinfoLayout))
and you'll see 'Vertex'Code: Select all
print(dir(self.form))
My first course of action was a print(dir(self.form)) and it is still there
When I go in a second time it shows
15:33:37 Check Form
15:33:37 ['DrawChildren', 'DrawWindowBackground', 'IgnoreMask', 'PaintDeviceMetric', 'PdmDepth', 'PdmDevicePixelRatio', 'PdmDevicePixelRatioScaled', 'PdmDpiX', 'PdmDpiY', 'PdmHeight', 'PdmHeightMM', 'PdmNumColors', 'PdmPhysicalDpiX', 'PdmPhysicalDpiY', 'PdmWidth', 'PdmWidthMM', 'RenderFlag', 'RenderFlags', 'Vlayout', '__class__', '__delattr__', '__dict__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'acceptDrops', 'accessibleDescription', 'accessibleName', 'actionEvent', 'actions', 'activateWindow', 'addAction', 'addActions', 'adjustSize', 'autoFillBackground', 'backgroundRole', 'backingStore', 'baseSize', 'blockSignals', 'buttonMesh', 'changeEvent', 'childAt', 'childEvent', 'children', 'childrenRect', 'childrenRegion', 'clearFocus', 'clearMask', 'close', 'closeEvent', 'colorCount', 'connect', 'connectNotify', 'contentsMargins', 'contentsRect', 'contextMenuEvent', 'contextMenuPolicy', 'create', 'createWinId', 'createWindowContainer', 'cursor', 'curveLen', 'customContextMenuRequested', 'customEvent', 'deleteLater', 'depth', 'destroy', 'destroyed', 'devType', 'devicePixelRatio', 'devicePixelRatioF', 'devicePixelRatioFScale', 'disconnect', 'disconnectNotify', 'dragEnterEvent', 'dragLeaveEvent', 'dragMoveEvent', 'dropEvent', 'dumpObjectInfo', 'dumpObjectTree', 'dynamicPropertyNames', 'effectiveWinId', 'emit', 'ensurePolished', 'enterEvent', 'event', 'eventFilter', 'find', 'findChild', 'findChildren', 'focusInEvent', 'focusNextChild', 'focusNextPrevChild', 'focusOutEvent', 'focusPolicy', 'focusPreviousChild', 'focusProxy', 'focusWidget', 'font', 'fontInfo', 'fontMetrics', 'foregroundRole', 'frameGeometry', 'frameSize', 'geometry', 'getContentsMargins', 'grab', 'grabGesture', 'grabKeyboard', 'grabMouse', 'grabShortcut', 'graphicsEffect', 'graphicsProxyWidget', 'hasFocus', 'hasHeightForWidth', 'hasMouseTracking', 'hasTabletTracking', 'height', 'heightForWidth', 'heightMM', 'hide', 'hideEvent', 'inherits', 'initPainter', 'inputMethodEvent', 'inputMethodHints', 'inputMethodQuery', 'insertAction', 'insertActions', 'installEventFilter', 'internalWinId', 'isActiveWindow', 'isAncestorOf', 'isEnabled', 'isEnabledTo', 'isEnabledToTLW', 'isFullScreen', 'isHidden', 'isLeftToRight', 'isMaximized', 'isMinimized', 'isModal', 'isRightToLeft', 'isSignalConnected', 'isTopLevel', 'isVisible', 'isVisibleTo', 'isWidgetType', 'isWindow', 'isWindowModified', 'isWindowType', 'keyPressEvent', 'keyReleaseEvent', 'keyboardGrabber', 'killTimer', 'layout', 'layoutDirection', 'leaveEvent', 'locale', 'logicalDpiX', 'logicalDpiY', 'lower', 'mapFrom', 'mapFromGlobal', 'mapFromParent', 'mapTo', 'mapToGlobal', 'mapToParent', 'mask', 'maxLen', 'maximumHeight', 'maximumSize', 'maximumWidth', 'meshInfoLayout', 'meshParmsLayout', 'metaObject', 'metric', 'minimumHeight', 'minimumSize', 'minimumSizeHint', 'minimumWidth', 'mouseDoubleClickEvent', 'mouseGrabber', 'mouseMoveEvent', 'mousePressEvent', 'mouseReleaseEvent', 'move', 'moveEvent', 'moveToThread', 'nativeEvent', 'nativeParentWidget', 'nextInFocusChain', 'normalGeometry', 'objectName', 'objectNameChanged', 'overrideWindowFlags', 'overrideWindowState', 'paintEngine', 'paintEvent', 'painters', 'paintingActive', 'palette', 'parent', 'parentWidget', 'physicalDpiX', 'physicalDpiY', 'pointLen', 'pos', 'previousInFocusChain', 'property', 'raise_', 'receivers', 'rect', 'redirected', 'registerUserData', 'releaseKeyboard', 'releaseMouse', 'releaseShortcut', 'removeAction', 'removeEventFilter', 'render', 'repaint', 'resize', 'resizeEvent', 'restoreGeometry', 'retranslateUi', 'saveGeometry', 'scroll', 'sender', 'senderSignalIndex', 'setAcceptDrops', 'setAccessibleDescription', 'setAccessibleName', 'setAttribute', 'setAutoFillBackground', 'setBackgroundRole', 'setBaseSize', 'setContentsMargins', 'setContextMenuPolic...
The panel shows the Vertex and Facet Widgets
And if I add code to add them I get a second set.
