openBrain wrote: ↑Thu Jun 03, 2021 8:20 am
1) Not only Edge16 isn't cut, but also Edge27
delete some lines fix this for Edge27
... maybe is there any limit? if not, then I still think this is a bug.
_______________________________________________________________________
UR_ wrote: ↑Thu Jun 03, 2021 9:09 am
You can simply explode sketch with DowngradeToEdges using Lattice2 WB and apply BooleanFragments afterwards.
maybe this work but we lost the parametric feature, I found 2 alternatives to this problem
1) Split manually each Intersection
2) Separate Horizontal and Vertical Lines in 2 Sketches then Apply boolean again.
... in both cases we still have parametric features, but is an extra task
chrisb wrote: ↑Thu Jun 03, 2021 7:49 am
Besides: may I ask for the use case of such boolean fragments?
https://forum.freecadweb.org/viewtopic.php?f=3&t=58731
with nested Faces Edges and Vertex, we can create an entire pre-project just with 3 Sketches, in theory.
