I've been trying to compile the latest code on my Fedora 34 and I've come across a problem with the current FreeCAD source as it uses VTK8 and Fedora 34 ships with VKT9.
As part of my bug investigation I've come across this patch from Fedora and I was was wondering if I've missed this fix in the tracker or shall I test it out and if it works create a pull request?
https://src.fedoraproject.org/rpms/free ... vtk9.patch
Regards
[solved] Fedora 34 and VTK9 patch
Last edited by keepitsimplejim on Fri Jun 25, 2021 9:42 am, edited 1 time in total.
Re: Fedora 34 and VTK9 patch
Pretty sure void Linux also has a vtk9 patch implemented. Iirc it came from werner's GitHub.
Re: [solved] Fedora 34 and VTK9 patch
Main branch updated: Make smesh compile with vtk9
