sliptonic
Posts: 3460 Joined: Tue Oct 25, 2011 10:46 pm
Post
by sliptonic » Fri Jul 09, 2021 6:37 pm
I have a top-level PythonFeature object with the Group extension applied. It has child groups that are regular DocumentObjectGroups. But the child group visibility doesn't behave like I expect. I can toggle visibility at the parent level and it works but at the intermediate group level, it only turns visibility off, not back on. Is there something else I need to do to make the intermediate group behave normally?
Here's a macro that sets up the situation.
class MyObject():
def __init__(self,obj):
obj.Proxy = self
obj.addExtension("App::GroupExtensionPython")
class ViewProvider_MyObject():
def __init__(self,vobj):
#vobj.Proxy = self
vobj.addExtension("Gui::ViewProviderGroupExtensionPython")
obj=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","parent")
MyObject(obj)
obj.ViewObject.Proxy = ViewProvider_MyObject(obj.ViewObject)
child = FreeCAD.ActiveDocument.addObject("App::DocumentObjectGroup", "child")
obj.addObject(child)
box = App.ActiveDocument.addObject("Part::Box","Box")
child.addObject(box)
carlopav
Posts: 2062 Joined: Mon Dec 31, 2018 1:49 pm
Post
by carlopav » Sun Jul 11, 2021 8:29 am
Indeed it behaves strange...
What's the desired result of this setting? What do you want to achieve?
Why using a Part::FeaturePython instead of an App::FeaturePython?
sliptonic
Post
by sliptonic » Sun Jul 11, 2021 2:39 pm
Sorry. The part::featurepython was already in my script. I get the same behaviour in app::featurepython.
I want the groups to behave the same as nested documentobjectgroups. Toggling the parent should toggle all children off and on.
carlopav
Post
by carlopav » Sun Jul 11, 2021 3:19 pm
hmmm, yes, I get your same behaviour with Part::Feature Python, while it's working with App::FeaturePython:
class MyObject():
obj.Proxy = self
#vobj.Proxy = self
def __getstate__(self):
return None
def __setstate__(self, _state):
return None
obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","parent")
MyObject(obj)
I guess It still misses some methods cause the viewprovider has a bad icon in the tree...
can you try?
sliptonic
Post
by sliptonic » Sun Jul 11, 2021 3:53 pm
It doesn't work with App::featurepython for me either.
If the child group is not visible, toggling the parent makes it visible but not the reverse.
carlopav
Post
by carlopav » Sun Jul 11, 2021 4:01 pm
this is quite odd... i confirm that App::FeaturePython works with the following setup:
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Italian/Italy (it_IT)
I'm interested in the topic, hope you can find a solution...
sliptonic
Post
by sliptonic » Sun Jul 11, 2021 4:15 pm
I'm on the current master branch.
OS: Linux Mint 20 (i3/i3)
Version: 0.20.25220 (Git)
Build type: Unknown
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.5
Qt version: 5.12.8
carlopav
Post
by carlopav » Sun Jul 11, 2021 4:41 pm
No time now to compile, sorry. I tried with 0.19.2
Version: 0.19.24291 (Git)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
toggle visibility.gif (41.72 KiB) Viewed 1344 times
Roy_043
Posts: 8585 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Sun Jul 11, 2021 7:01 pm
It does work partially. And this is maybe what Carlo is seeing?
Use the code from the OP.
Make all objects invisible.
Toggling the visibility of the intermediate group now works.
