why is handleChangedPropertyType not called
uwestoehr
Post by uwestoehr »
We got bug reports that changes in property types are not taken into account for some features. (e.g. this post: https://forum.freecadweb.org/viewtopic.php?f=3&t=59771)
Take for example this example:
HelixTest-019.FCStd
FC 0.19 example file
(534.22 KiB) Downloaded 62 times
It has a helix with 6 turns in FC 0.19 but when opening with latest FC 0.20 the task dialog or property editor only shows 3 turns.
The fact is that the property type was changed in FC 0.20 but when debugging I see that the
void handleChangedPropertyType
is not called on opening the file. How can be assured that handleChangedPropertyType is executed?
I had a brief look and other PartDesign features are affected from this too:
- PolarPattern: property Occurrences
- LinearPattern: property Occurrences
What I don't understand is that the PartDesign feature Draft has a void handleChangedPropertyType too and this is called on opening a file.
I spent now an hour to find a difference between Draft and Helix that could trigger the problem but failed.
Has anybody an idea?
Syres wrote: .
abdullah wrote: .
wmayer wrote: .
Founder
Re: why is handleChangedPropertyType not called
Post by wmayer »
The reason is a bad re-implementation of ProfileBased::Restore(). It overrides the virtual function Restore() of PropertyContainer but doesn't handle the case that a property of a sub-class could have been renamed or has changed its type.
See git commit f712f5e4acd407b.
However, at that time we hadn't the functions handleChangedPropertyType/handleChangedPropertyName and the procedure to handle changed property types/names was to fully re-implement the Restore() function. Since this caused a lot of code duplication we have added the above two functions.
git commit a2cdd5201917577e
So, to fix the issue we have to remove ProfileBased::Restore() and move the part that handles the sketch stuff to ProfileBased::handleChangedPropertyType()
Founder
Post by wmayer »
Fixed with git commit 9fe1f56824
The issues for the LinearPattern/PolarPattern classes are likely fixed with: git commit e273954135ccfe2
Can you test and if still not working as expected could you upload a small example project, please?
user1234
Post by user1234 »
This fixes this issue:
https://forum.freecadweb.org/viewtopic.php?t=59831, which is, or was, a significant bug.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.25723 (Git)
Hash: 9fe1f568246dd63573e6d12aaffbcd8ebaf7cf51
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.3
thanks!
Greetings
user1234
uwestoehr
Post by uwestoehr »
wmayer wrote: Wed Sep 15, 2021 1:46 pm Fixed with git commit 9fe1f56824
Many thanks! This fixes the bug.
I would never be able to fix this on my own without the knowledge of the code history.
p.s. could you please have a look to your private messages, since it would be great if you could join our meeting next week. Write me a private message in case you have too many to read them, then I will send you the relevant info on a short reply.
Founder
Post by wmayer »
uwestoehr wrote: Wed Sep 15, 2021 3:01 pm p.s. could you please have a look to your private messages, since it would be great if you could join our meeting next week. Write me a private message in case you have too many to read them, then I will send you the relevant info on a short reply.
OK, I will have a look but may take me a while because there quite a lot of posts...
