Full log: https://gitlab.com/PrzemoF/FreeCAD/-/jobs/1448350608
test50 (PathTests.TestPathCore.TestPathCore)
Test Path.Length calculation ... ok
test00 (PathTests.TestPathDeburr.TestPathDeburr)
Verify chamfer depth and offset for an end mill. ... Traceback (most recent call last):
File "<string>", line 40, in <module>
File "/builds/PrzemoF/FreeCAD/build/Mod/Test/TestApp.py", line 70, in TestText
retval = r.run(s)
File "/usr/lib/python3.8/unittest/runner.py", line 176, in run
test(result)
File "/usr/lib/python3.8/unittest/suite.py", line 84, in __call__
return self.run(*args, **kwds)
File "/usr/lib/python3.8/unittest/suite.py", line 122, in run
test(result)
test(result)
test(result)
File "/usr/lib/python3.8/unittest/case.py", line 736, in __call__
File "/usr/lib/python3.8/unittest/case.py", line 649, in run
result.startTest(self)
File "/usr/lib/python3.8/unittest/runner.py", line 54, in startTest
self.stream.write(self.getDescription(test))
<class 'UnicodeEncodeError'>: 'ascii' codec can't encode character '\xb0' in position 89: ordinal not in range(128)
Recompute......
Cleaning up file based variables 00:01
ERROR: Job failed: exit code 1
