Under %APPDATA%\FreeCAD\user.cfg
[Solved] FC Crashes after opening sketcher FC 0.20(Debug mode)
Re: FC Crashes after opening sketcher FC 0.20(Debug mode)
It was so simple an unrelated you solved it in the 17th's of september and didn't notice it LOL.
the thing that caused FC to crash was overlapping shortcuts for actions I did in 0.19 when experimenting with it so resetting all shortcuts to default like you said actually fixed it.
Thanks again for the help didn't have much time messing around with it (opening a new conventional and CNC machine shop so I'll probably have to play with FC alot by then).
I Guess I'll start with improving the sketcher or atleast try to and I'm interested in making some nice looking UI macros and tools to create some of the missing tools that their need pops up sometimes.
OK, but even then the application shouldn't simply crash. I set the same shortcut for two actions but for me it doesn't crash.the thing that caused FC to crash was overlapping shortcuts for actions I did in 0.19 when experimenting with it so resetting all shortcuts to default like you said actually fixed it.
So, since it works for you now I marked this topic as Solved. In case you manage to reproduce the crash then let us know, please.
