[Solved] FC Crashes after opening sketcher FC 0.20(Debug mode)
MikeLemon
Post by MikeLemon »
After building FC 0.20 (git clone https://github.com/FreeCAD/FreeCAD.git) with VS following the guide: https://wiki.freecadweb.org/Compile_on_ ... io_15_2017
I couldn't find PYTHON_DEBUG_LIBRARY path and the other cmake parameters and after bulding and setting FreeCADMain as Start up Project and running it in debug mode x64 the FreeCAD launches and created a file a a body alright but when switching to the sketcher workbench it pop's up the next error and crashes:
Could it be that python parameter thing? where do you find the cmake file that holds this parameters?
GeneFC
Re: FC Crashes after opening sketcher FC 0.20(Debug mode)
Post by GeneFC »
As you have discovered, if not already known, cmake stuff is scattered all over in the source.
I use grepwin to quickly find the target.
Gene
MikeLemon
Post by MikeLemon »
Looking at it now in the CMakeCache.txt in build bin folder in says that python was set to the python 3.8 in the libpack and yet sketcher would still crash and that's the only workbench I want to work on right now!!! :evil: :x
I assume it was indeed suppose to use python 3.8 for 0.20 build, could I have missed something compiling FC in debug mode?
jais
Post by jais »
I also had problems with finding the Python settings in the CMake GUI, so I ran it from the Visual Studio developer command prompt like this:
cmake -S .\source -B .\build -DFREECAD_LIBPACK_DIR=.\libpack -DPYTHON_DEBUG_LIBRARY=.\libpack\bin\libs\python38_d.lib -DPYTHON_EXECUTABLE=.\libpack\bin\python.exe -DPYTHON_INCLUDE_DIR=.\libpack\bin\include -DPYTHON_LIBRARY=.\libpack\bin\libs\python38.lib
msbuild ALL_BUILD.vcxproj /p:Configuration=Debug
and then I could run it from Visual Studio. Change the source, build and libpack folders to match your folders.
I also had some errors from the Qt code generation, but they went away by running msbuild a few more times - I suspect it is some concurrency problem
MikeLemon
Post by MikeLemon »
jais wrote: Wed Sep 08, 2021 4:52 pm I also had problems with finding the Python settings in the CMake GUI, so I ran it from the Visual Studio developer command prompt like this:
Well I tryed a fresh build with your commands and still even after running it more than once when loading sketcher in FC the program collapses...
chennes
Post by chennes »
Did you hit "Retry" there and look at the backtrace? That often helps figure out what's going wrong. I really wouldn't suspect Python as the culprit here.
Chris Hennes
Pioneer Library System
MikeLemon
Post by MikeLemon »
chennes wrote: Thu Sep 09, 2021 12:39 pm Did you hit "Retry" there and look at the backtrace? That often helps figure out what's going wrong. I really wouldn't suspect Python as the culprit here.
Yeah Said something about QT old error message, I'm currentlly building the release version which atleast somewhat works with just a conserning warning error at the end of the build :|
chennes
Post by chennes »
When you have a moment, can you re-run your debug version and paste in the backtrace?
Chris Hennes
sgrogan
Post by sgrogan »
MikeLemon wrote: Wed Sep 08, 2021 8:42 pm Well I tryed a fresh build with your commands and still even after running it more than once when loading sketcher in FC the program collapses...
Do you have a system installed Python? I've had trouble with this in the past to get CMake to use the one in the Libpack.
"fight the good fight"
MikeLemon
Post by MikeLemon »
chennes wrote: Thu Sep 09, 2021 2:35 pm When you have a moment, can you re-run your debug version and paste in the backtrace?
Yes just done building it, there it is(right after entering sketcher)
sgrogan wrote: Thu Sep 09, 2021 5:28 pm
Yes python 3.9 though with QT5 installed I'm pretty sure.
