MSYS2 build error help: "missing" file
Founder
Re: MSYS2 build error help: "missing" file
Post by wmayer »
chennes wrote: Sat Sep 18, 2021 6:49 pm Did you resolve the bad cast in src/Base/TimeInfo.cpp +69?
void TimeInfo::setCurrent(void)
#if defined (FC_OS_BSD) || defined(FC_OS_LINUX)
    struct timeval t;
    gettimeofday(&t, NULL);
    timebuffer.time = t.tv_sec;
    timebuffer.millitm = t.tv_usec / 1000;
#elif defined(__MINGW32__)
    ftime(&timebuffer); // deprecated
#elif defined(FC_OS_WIN32)
    _ftime(&timebuffer);
#else
#endif
But it seems that there exists a special version of gettimeofday for MinGW but I haven't looked at this yet.
So far I succeeded to build almost all App modules but it failed for FreeCADGui since it raised a weird linker error with the static QtUiTools lib.
To build the Part module I had to cheat a bit with the class GeometryDefaultExtension. To make the compiler accept it I had to comment out the line
TYPESYSTEM_HEADER_WITH_OVERRIDE();
and all the lines
TYPESYSTEM_SOURCE_TEMPLATE_T
of the source file.
Note: I have used clang instead of gcc because the latter raised hundreds of linker errors for FreeCADApp. If you want to use clang too you must set these two variables before running cmake:
export CC=clang
export CXX=clang++
chennes
Post by chennes »
Odd, my build is hanging after "Linking CXX shared library Mod\Path\area.pyd" -- did you experience that?
Chris Hennes
Pioneer Library System
chennes
Post by chennes »
Switching to clang seems to have fixed the hang. Now I'm stuck where you are (I think), with the weird
[3/832] Linking CXX shared library bin\libFreeCADGui.dll
FAILED: bin/libFreeCADGui.dll src/Gui/libFreeCADGui.dll.a
cmd.exe /C "cd . && E:\msys64\mingw64\bin\clang++.exe -Wall -Wextra -Wpedantic -Wno-write-strings  -mthreads -Wno-attributes  -mthreads -Wl,--export-all-symbols -shared -o bin\libFreeCADGui.dll -Wl,--out-implib,src\Gui\libFreeCADGui.dll.a -Wl,--major-image-version,0,--minor-image-version,0 @CMakeFiles\FreeCADGui.rsp  && cd ."
E:/msys64/mingw64/lib/libQt5UiTools.a(quiloader.o): duplicate section `.rdata$_ZTS7QObject[_ZTS7QObject]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_quiloader.o): duplicate section `.rdata$_ZTS7QObject[_ZTS7QObject]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_quiloader.o): duplicate section `.rdata$_ZTS9QUiLoader[_ZTS9QUiLoader]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_quiloader.o): duplicate section `.rdata$_ZTI9QUiLoader[_ZTI9QUiLoader]' has different size
E:/msys64/mingw64/bin/ld: E:/msys64/mingw64/lib/libQt5UiTools.a(abstractformbuilder.o):abstractformbuilder.cpp:(.data$_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id[_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id]+0x0): multiple definition of `QMetaTypeIdQObject<QWidget*, 8>::qt_metatype_id()::metatype_id'; src/Gui/CMakeFiles/FreeCADGui.dir/ToolBox.cpp.obj:ToolBox.cpp:(.bss$_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id[_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id]+0x0): first defined here
E:/msys64/mingw64/bin/ld: E:/msys64/mingw64/lib/libQt5UiTools.a(abstractformbuilder.o):abstractformbuilder.cpp:(.data$_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id[_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id]+0x0): multiple definition of `QMetaTypeId<QtMetaTypePrivate::QSequentialIterableImpl>::qt_metatype_id()::metatype_id'; src/Gui/CMakeFiles/FreeCADGui.dir/SoFCDB.cpp.obj:SoFCDB.cpp:(.bss$_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id[_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id]+0x0): first defined here
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS7QObject[_ZTS7QObject]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS12QPaintDevice[_ZTS12QPaintDevice]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS7QWidget[_ZTS7QWidget]' has different size
E:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTI7QWidget[_ZTI7QWidget]' has different size
E:/msys64/mingw64/bin/ld: error: export ordinal too large: 68198
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
ninja: build stopped: subcommand failed.
Chris Hennes
chennes
Post by chennes »
OK, I figured it would be good to try to just recompile Qt5-Tools locally to see if that resolved the linker issue, but I can't even do that. The steps should have been simple enough:
cd /tmp
git clone https://github.com/msys2/MINGW-packages
cd MINGW-packages/mingw-w64-qt5-tools
MINGW_ARCH=mingw64 makepkg-mingw -sLf
But when I do this, the compilation fails because it can't find an include:
g++ -c -include .pch/release/lib_pch.h -fno-keep-inline-dllexport -O2 -g -std=c++1z -fno-exceptions -Wall -Wextra -Wextra -Wvla -Wdate-time -Wshift-overflow=2 -Wduplicated-cond -Wno-stringop-overflow -Wno-format-overflow -DUNICODE -D_UNICODE -DWIN32 -DMINGW_HAS_SECURE_API=1 -DWINVER=0x0601 -D_WIN32_WINNT=0x0601 -DQT_NO_LINKED_LIST -DQT_NO_JAVA_STYLE_ITERATORS -DQT_NO_LINKED_LIST -DQDESIGNER_SDK_LIBRARY -DQDESIGNER_EXTENSION_LIBRARY -DQDESIGNER_UILIB_LIBRARY -DQDESIGNER_SHARED_LIBRARY -DQT_DESIGNER -DQT_USE_QSTRINGBUILDER -DQT_NO_NARROWING_CONVERSIONS_IN_CONNECT -DQT_BUILD_DESIGNER_LIB -DQT_BUILDING_QT -D_CRT_SECURE_NO_WARNINGS -D_USE_MATH_DEFINES -DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_DEPRECATED_WARNINGS -DQT_DISABLE_DEPRECATED_BEFORE=0x040800 -DQT_DEPRECATED_WARNINGS_SINCE=0x060000 -DQT_NO_EXCEPTIONS -DQT_NO_DEBUG -DQT_UIPLUGIN_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -DQT_UIPLUGIN_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib -I. -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/extension -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/sdk -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/shared -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/shared/qtpropertybrowser -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/shared/deviceskin -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/shared/findwidget -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/shared/qtgradienteditor -IE:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/uilib -I../../../../include -I../../../../include/QtDesigner -I../../../../include/QtDesigner/5.15.2 -I../../../../include/QtDesigner/5.15.2/QtDesigner -Itmp -I../../../../include/QtUiPlugin -IE:/msys64/mingw64/include/QtWidgets/5.15.2 -IE:/msys64/mingw64/include/QtWidgets/5.15.2/QtWidgets -IE:/msys64/mingw64/include/QtGui/5.15.2 -IE:/msys64/mingw64/include/QtGui/5.15.2/QtGui -IE:/msys64/mingw64/include/QtCore/5.15.2 -IE:/msys64/mingw64/include/QtCore/5.15.2/QtCore -IE:/msys64/mingw64/include/QtWidgets -IE:/msys64/mingw64/include/QtGui -IE:/msys64/mingw64/include/QtXml -IE:/msys64/mingw64/include/QtCore -I.moc/release -I.uic -I/include -I/include -I@@QT_REAL_PREFIX/dir@@/include/mariadb -IE:/msys64/mingw64/share/qt5/mkspecs/win32-g++  -o .obj/release/qdesigner_taskmenu.o E:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/shared/qdesigner_formbuilder.cpp
In file included from E:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/shared/qdesigner_formbuilder.cpp:35:
../../../../include/QtDesigner/5.15.2/QtDesigner/private/ui4_p.h:1:10: fatal error: ../../../../../../../../../../../../tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/uilib/ui4_p.h: No such file or directory
    1 | #include "../../../../../../../../../../../../tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/uilib/ui4_p.h"
compilation terminated.
The catch is, the necessary files appear to be there. If I:
cd E:/msys64/tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/shared/
cat ../../../../include/QtDesigner/5.15.2/QtDesigner/private/ui4_p.h
I get
So then I:
cd ../../../../include/QtDesigner/5.15.2/QtDesigner/private/
cat ../../../../../../../../../../../../tmp/MINGW-packages/mingw-w64-qt5-tools/src/qttools/src/designer/src/lib/uilib/ui4_p.h
... the file is there, and looks fine. So while that path is sort of absurd, as far as I can tell it should be working. Honestly, I was sort of hoping that while typing this out I'd have one of those Eureka! moments... it didn't happen. :?
Chris Hennes
Founder
Post by wmayer »
chennes wrote: Sun Sep 19, 2021 1:18 am OK, I figured it would be good to try to just recompile Qt5-Tools locally to see if that resolved the linker issue, but I can't even do that.
Unfortunately, Qt has become a huge monster in the last years and it's quite difficult now to get it compiled locally.
Founder
Post by wmayer »
Now I am not sure if Qt5-Tools is even the problem. As a hack I have implemented a dummy class QUiLoader in WidgetFactory.h and disabled the include of QUiLoader.h. This has fixed all the warnings:
C:/msys64/mingw64/bin/ld: C:/msys64/mingw64/lib/libQt5UiTools.a(abstractformbuilder.o):abstractformbuilder.cpp:(.data$_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id[_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id]+0x0): multiple definition of `QMetaTypeIdQObject<QWidget*, 8>::qt_metatype_id()::metatype_id'; CMakeFiles/FreeCADGui.dir/objects.a(ToolBox.cpp.obj):ToolBox.cpp:(.bss$_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id[_ZZN18QMetaTypeIdQObjectIP7QWidgetLi8EE14qt_metatype_idEvE11metatype_id]+0x0): first defined here
C:/msys64/mingw64/bin/ld: C:/msys64/mingw64/lib/libQt5UiTools.a(abstractformbuilder.o):abstractformbuilder.cpp:(.data$_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id[_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id]+0x0): multiple definition of `QMetaTypeId<QtMetaTypePrivate::QSequentialIterableImpl>::qt_metatype_id()::metatype_id'; CMakeFiles/FreeCADGui.dir/objects.a(SoFCDB.cpp.obj):SoFCDB.cpp:(.bss$_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id[_ZZN11QMetaTypeIdIN17QtMetaTypePrivate23QSequentialIterableImplEE14qt_metatype_idEvE11metatype_id]+0x0): first defined here
C:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS7QObject[_ZTS7QObject]' has different size
C:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS12QPaintDevice[_ZTS12QPaintDevice]' has different size
C:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTS7QWidget[_ZTS7QWidget]' has different size
C:/msys64/mingw64/lib/libQt5UiTools.a(moc_properties_p.o): duplicate section `.rdata$_ZTI7QWidget[_ZTI7QWidget]' has different size
but what still appears is this error message:
C:/msys64/mingw64/bin/ld: error: export ordinal too large: 67248
make[3]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/build.make:5875: bin/libFreeCADGui.dll] Error 1
make[2]: *** [CMakeFiles/Makefile2:6355: src/Gui/CMakeFiles/FreeCADGui.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:6362: src/Gui/CMakeFiles/FreeCADGui.dir/rule] Error 2
make: *** [Makefile:2262: FreeCADGui] Error 2
So, the reason must be something else.
EDIT: The problem might be the linker flag -Wl,--export-all-symbols. I have disabled this line and added an explicit dllexport where needed. Just waiting for FreeCADGui to be finished...
EDIT2: Apparently both of the above issues lead to a failure. After re-adding my hack and removing -Wl,--export-all-symbols the linker has created libFreeCADGui.dll
Founder
Post by wmayer »
Here is my patch with all the changes to make it compile with MSYS2/clang.
Before running the GUI version you must do
export FC_PYTHONHOME=/mingw64
as otherwise the Python interpreter fails to find its modules and crashes.
The GUI then shows the splash screen but then crashes when loading the Part module. The reason is that the macros for the type declaration are commented out due to this weird build failure.
HINT: The Import module raises a lot of warnings due to OCCT. If you want to fix it you must edit TDF_DerivedAttribute.hxx and remove the semicolon in line 26.
mingw.diff.txt
(25.65 KiB) Downloaded 53 times
chennes
Post by chennes »
Nice, thanks. I didn't know about intptr_t -- that sounds like it's safe on all systems, right? Then, with the exception of the TYPESYSTEM hack, all of these changes should be safe to make?
Any clue what's happening with the TYPESYSTEM stuff? I didn't look at it at all, just took your advice and removed it.
Chris Hennes
Founder
Post by wmayer »
chennes wrote: Sun Sep 19, 2021 3:23 pm Nice, thanks. I didn't know about intptr_t -- that sounds like it's safe on all systems, right?
Yes, that should be safe on all platforms. intptr_t is a typedef of int64 for 64-bit platforms and a normal int for 32-bit platforms.
The changes of GeometryDefaultExtension.cpp and GeometryDefaultExtension.h must not be checked-in as that causes the crash when starting FreeCAD.
Not really. The compiler complains about the static classTypeId member of the template class. When searching on SO for that error message I think the compiler is right and it's probably only luck that it works on Windows and Linux.
After a while I found a way to fix the warnings when re-enabling TYPESYSTEM_HEADER_WITH_OVERRIDE but I failed to find a solution for the compile error for the TYPESYSTEM_SOURCE_TEMPLATE_T.
Founder
Post by wmayer »
I have merged as much as possible of the patch. So, the things I left are:
diff --git a/src/Gui/WidgetFactory.h b/src/Gui/WidgetFactory.h
index d1d1ecf6eb..0ab46d1a84 100644
--- a/src/Gui/WidgetFactory.h
+++ b/src/Gui/WidgetFactory.h
@@ -24,8 +24,34 @@
 #ifndef GUI_WIDGETFACTORY_H
 #define GUI_WIDGETFACTORY_H
-#include <vector>
+#if defined (__MINGW32__)
+class QDir;
+class QUiLoader : public QObject
+    Q_OBJECT
+public:
+    explicit QUiLoader(QObject *parent = nullptr) : QObject(parent) {
+    void clearPluginPaths() {
+    void setLanguageChangeEnabled(bool) {
+    QWidget *load(QIODevice *, QWidget * = nullptr) {
+        return nullptr;
+    void setWorkingDirectory(const QDir &) {
+    QStringList availableWidgets() const {
+        return QStringList();
+    virtual QWidget *createWidget(const QString &, QWidget * = nullptr, const QString & = QString()) {
+        return nullptr;
+#else
 #include <QUiLoader>
+#endif
+#include <vector>
 #include <QGraphicsItem>
 #include <Base/Factory.h>
diff --git a/src/Mod/Mesh/App/CMakeLists.txt b/src/Mod/Mesh/App/CMakeLists.txt
index 187b2115de..2d661aea12 100644
--- a/src/Mod/Mesh/App/CMakeLists.txt
+++ b/src/Mod/Mesh/App/CMakeLists.txt
@@ -372,6 +372,15 @@ SET(Mesh_SRCS
     Segment.h
+# Suppress -Wundefined-var-template
+if (MINGW AND CMAKE_COMPILER_IS_CLANGXX)
+    unset(_flag_found CACHE)
+    check_cxx_compiler_flag("-Wno-undefined-var-template" _flag_found)
+    if (_flag_found)
+        set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wno-undefined-var-template")
+    endif()
+endif()
 if(FREECAD_USE_PCH)
     add_definitions(-D_PreComp_)
     GET_MSVC_PRECOMPILED_SOURCE("PreCompiled.cpp" PCH_SRCS ${Core_SRCS} ${Mesh_SRCS})
diff --git a/src/Mod/Part/App/GeometryDefaultExtension.cpp b/src/Mod/Part/App/GeometryDefaultExtension.cpp
index b4435d13f7..1efd652ba0 100644
--- a/src/Mod/Part/App/GeometryDefaultExtension.cpp
+++ b/src/Mod/Part/App/GeometryDefaultExtension.cpp
@@ -108,7 +108,7 @@ namespace Part {
 //typedef Part::GeometryStringExtension<std::string> GeometryStringExtension;
 // ---------- GeometryIntExtension ----------
-TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryIntExtension,Part::GeometryPersistenceExtension)
+//TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryIntExtension,Part::GeometryPersistenceExtension)
 template <>
 PyObject * GeometryDefaultExtension<long>::getPyObject(void)
@@ -125,7 +125,7 @@ void GeometryDefaultExtension<long>::restoreAttributes(Base::XMLReader &reader)
 // ---------- GeometryStringExtension ----------
-TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryStringExtension,Part::GeometryPersistenceExtension)
+//TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryStringExtension,Part::GeometryPersistenceExtension)
 template <>
 PyObject * GeometryDefaultExtension<std::string>::getPyObject(void)
@@ -134,7 +134,7 @@ PyObject * GeometryDefaultExtension<std::string>::getPyObject(void)
 // ---------- GeometryBoolExtension ----------
-TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryBoolExtension,Part::GeometryPersistenceExtension)
+//TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryBoolExtension,Part::GeometryPersistenceExtension)
 template <>
 PyObject * GeometryDefaultExtension<bool>::getPyObject(void)
@@ -151,7 +151,7 @@ void GeometryDefaultExtension<bool>::restoreAttributes(Base::XMLReader &reader)
 // ---------- GeometryDoubleExtension ----------
-TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryDoubleExtension,Part::GeometryPersistenceExtension)
+//TYPESYSTEM_SOURCE_TEMPLATE_T(Part::GeometryDoubleExtension,Part::GeometryPersistenceExtension)
 template <>
 PyObject * GeometryDefaultExtension<double>::getPyObject(void)
diff --git a/src/Mod/Part/App/GeometryDefaultExtension.h b/src/Mod/Part/App/GeometryDefaultExtension.h
index 246f55d185..7221a1a41c 100644
--- a/src/Mod/Part/App/GeometryDefaultExtension.h
+++ b/src/Mod/Part/App/GeometryDefaultExtension.h
@@ -32,7 +32,7 @@ namespace Part {
     template <typename T>
     class PartExport GeometryDefaultExtension: public Part::GeometryPersistenceExtension
-        TYPESYSTEM_HEADER_WITH_OVERRIDE();
+    //    TYPESYSTEM_HEADER_WITH_OVERRIDE();
     public:
         inline GeometryDefaultExtension();
         GeometryDefaultExtension(const T& val, std::string name = std::string());
