MSYS2 build error help: "missing" file
chennes
Post by chennes »
I'm working on updating our MSYS2/MinGW build instructions (https://wiki.freecadweb.org/index.php?t ... e_on_MinGW). I've made good progress through a number of errors, and have the initial cMake run actually working now, but I'm getting a build error that is over my head. The error I get when I try to run cmake --build ./ is:
ninja: error: 'D:/a/_temp/msys/msys64/mingw64/lib/libopenvr_api.dll.a', needed by 'bin/libSMDS.dll', missing and no known rule to make it
The path it's looking in is garbage, there's nothing there. But E:/msys/msys64/mingw64/lib/libopenvr_api.dll.a does exist. The build.ninja file shows a number of libraries that are being searched for in that incorrect path. Does anyone have any idea where it might be coming from?
Chris Hennes
Pioneer Library System
chennes
Re: MSYS2 build error help: "missing" file
Post by chennes »
Update: I've poked around at this some, and that path (D:/a/_temp/) looks suspiciously like a GitHub CI thing. If I compile OpenCASCADE from scratch on my MSYS2 installation and use that version instead, I don't get this particular error.
Chris Hennes
Founder
Post by wmayer »
chennes wrote: Tue Sep 14, 2021 3:27 am If I compile OpenCASCADE from scratch on my MSYS2 installation and use that version instead, I don't get this particular error.
How well does it work to build OCCT on your own? When I have built it 10 years ago with MSYS/MinGW inside a command line prompt it was a major PITA because for a lot of dlls there were a few thousand source files included that has exceeded the maximum number of allowed characters of the program parameters.
I had to split these dlls into several static libs and afterwards build a dll out of them. It took me several days to finish it.
kwahoo
Post by kwahoo »
chennes wrote: Mon Sep 13, 2021 12:20 am The path it's looking in is garbage, there's nothing there. But E:/msys/msys64/mingw64/lib/libopenvr_api.dll.a does exist.
I am curious why there is dependency on OpenVR? SMESH should not need it, at least for the functionality needed by FreeCAD.
chennes
Post by chennes »
wmayer wrote: Wed Sep 15, 2021 10:28 am How well does it work to build OCCT on your own?
I used the MinGW packaging setup here: https://github.com/msys2/MINGW-packages ... pencascade
Then just ran
MINGW_ARCH=mingw64 makepkg-mingw -sLf
It compiled out of the box with no changes from me, except I had to do a little sed work after to remove those extraneous unreplaced variables. And of course, it doesn't seem to actually work for compiling :x
I don't know why it's being compiled with VR support enabled, but I suspect that that's a red herring, and if I removed VR support I'd get an identical error on some other package.
Chris Hennes
Founder
Post by wmayer »
Ah great. Maybe I should retry the MinGW version again.
Btw, when I did the initial MinGW build of OCCT I also ported the source code to that compiler: https://dev.opencascade.org/content/cma ... cc-builder
Founder
Post by wmayer »
chennes wrote: Mon Sep 13, 2021 12:20 am I'm working on updating our MSYS2/MinGW build instructions (https://wiki.freecadweb.org/index.php?t ... e_on_MinGW). I've made good progress through a number of errors, and have the initial cMake run actually working now, but I'm getting a build error that is over my head. The error I get when I try to run cmake --build ./ is:
Currently I am testing the MSYS2/MinGW build and succeeded to set up the environment.
Now when trying to build the SMESH sources I immediately get an error due to the cast of a pointer to a long and back. How did you got this working? gcc is version 10.3.0. For now I disabled FEM and MeshPart to avoid to build the SMESH libs.
Founder
Post by wmayer »
chennes wrote: Mon Sep 13, 2021 12:20 am ninja: error: 'D:/a/_temp/msys/msys64/mingw64/lib/libopenvr_api.dll.a', needed by 'bin/libSMDS.dll', missing and no known rule to make it
Inside the bin directory of minwg64 you will find a file env.bat and this uses this odd path.
However, when I change it and rerun CMake the build.make files still use the wrong path. So, for now I work around it by creating that path and putting the affected libs.
When searching inside /mingw64 for all files that has included this paths then there are more than 5000 hits. So I guess it must have come from the build process to create the MSYS tools, libs, ...
chennes
Post by chennes »
It looks like we're not alone having that path problem, but I don't think the MSYS folks are seeing that there's a pattern:
https://github.com/msys2/MINGW-packages/issues/9411
https://github.com/msys2/MINGW-packages/issues/9615
Chris Hennes
chennes
Post by chennes »
wmayer wrote: Sat Sep 18, 2021 12:13 pm Now when trying to build the SMESH sources I immediately get an error due to the cast of a pointer to a long and back.
In the function at src/3rdParty/salomesmesh/inc/ObjectPool.hxx around line 133, I replaced all of the int data types with int64_t. I had to make the same change at src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_ProjectionUtils.cpp +109
That still left me with one more error (well, a whole set of errors) related to the DLL generation:
In file included from E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_QuadFromMedialAxis_1D2D.cpp:32:
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:85:18: error: function 'SMESH_MeshEditor::ElemFeatures::ElemFeatures(SMDSAbs_ElementType, bool, bool)' definition is marked dllimport
   85 |     SMESH_EXPORT ElemFeatures( SMDSAbs_ElementType type=SMDSAbs_All, bool isPoly=false, bool isQuad=false )
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:88:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(SMDSAbs_ElementType, bool, bool)' definition is marked ort
   88 |     SMESH_EXPORT ElemFeatures& Init( SMDSAbs_ElementType type, bool isPoly=false, bool isQuad=false )
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:93:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(double)' definition is marked dllimport
   93 |     SMESH_EXPORT ElemFeatures& Init( double diameter )
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:96:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(std::vector<int>&, bool)' definition is marked dllimpor
   96 |     SMESH_EXPORT ElemFeatures& Init( std::vector<int>& quanities, bool isQuad=false )
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:100:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(const std::vector<int>&, bool)' definition is marked drt
  100 |     SMESH_EXPORT ElemFeatures& Init( const std::vector<int>& quanities, bool isQuad=false )
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:104:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetPoly(bool)' definition is marked dllimport
  104 |     SMESH_EXPORT ElemFeatures& SetPoly(bool isPoly) { myIsPoly = isPoly; return *this; }
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:105:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetQuad(bool)' definition is marked dllimport
  105 |     SMESH_EXPORT ElemFeatures& SetQuad(bool isQuad) { myIsQuad = isQuad; return *this; }
E:/msys64/tmp/FreeCAD-chennes/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:106:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetID(int)' definition is marked dllimport
  106 |     SMESH_EXPORT ElemFeatures& SetID  (int ID)      { myID = ID; return *this; }
I hacked around those by modifying src/3rdParty/salomesmesh/inc/SMESH_SMESH.hxx and #define SMESH_EXPORT to nothing just to advance to the next error.
Did you resolve the bad cast in src/Base/TimeInfo.cpp +69?
Chris Hennes
